Author Topic: getting the most from a gieger tube?:  (Read 940 times)
Offline SArepairman
  • wannabee bit hunter
« on: July 28, 2013, 12:13:29 pm »
So what are methods from getting the most out of your gieger tube?
I know that you can improve dead time by driving the input into a negative high voltage after a pulse is detected. Are there any other methods for getting more out of your tube?
I'm guessing you can get some significant improvements if you switch in a negative voltage using a fast transistor.
« Last Edit: July 28, 2013, 12:15:10 pm by SArepairman »
