Author Topic: Gigatronics 8652A power meter  (Read 3429 times)
Offline romal76Topic starter
  • Country: ru
« on: April 22, 2021, 06:01:05 pm »
Hi All!
Looking for operation manual, maintenance(service) manual and firmware binaries for Gigatronics 8652A power meter
Offline yus
Re: Gigatronics 8652A power meter
« Reply #1 on: August 22, 2021, 02:05:26 pm »
Did you find anything ?
  • Country: ru
« Reply #2 on: August 22, 2021, 02:26:57 pm »
Unfortunately, no
only two eeprom dumps from my burned 80701
Offline yus
« Reply #3 on: August 22, 2021, 03:36:06 pm »
I may have to disassemble mine because the cal ref level is off, and there is no menu option for adjusting it. If you have Gigatronics 8652A, do you know: What is its controller ? Is the rom outside the controller and is readable?
  • Country: ru
« Reply #4 on: August 22, 2021, 06:19:39 pm »
I was find some service manual, but  information is not much
more info what is inside of 8652A will be in a few days
  • Country: ru
« Reply #5 on: August 22, 2021, 06:28:16 pm »
option 12 calibrator 50mhz/1ghz fotos from web
Offline yus
« Reply #6 on: August 22, 2021, 07:56:51 pm »
There is nothing to adjust there. Gigatronics calibrator ref level is set up by setting a CALFAC number. The older meters like 8541\8542 had access to this through menu:
   MENU -> SERVICE MENU ->CALIBRATOR -> EEPROM -> SNumb (unit serial number) -> CALFAC change
but their calibrators were fixed 50MHz.
The newer 8651/8651 series apart from 50MHz also have a range of frequencies from 800MHz to 1GHz, option 12. So they may probably have two or more cal factors.
What I need is know is how to access, change and save the  CALFAC-s on the newer models. There must be an external programming protocol or hidden service menu or both.
The cal-labs calibrating these meters certainly know how to access the CALFAC-s.
  • Country: ru
« Reply #7 on: August 22, 2021, 08:08:48 pm »
p.21 in service manual, maybe it is what you need
2.2.3 1 mW Reference Output Adjustment
Offline yus
« Reply #8 on: August 22, 2021, 08:26:41 pm »
Do you have a service manual for 8652A ?
  • Country: ru
« Reply #9 on: August 22, 2021, 08:28:25 pm »
attachment in this post is service
Offline yus
« Reply #10 on: August 22, 2021, 08:57:40 pm »
Looks like this is EXACTLY what I was looking for. MANY THANKS. I was not able to find this manual.
And what are you looking for: schematics ?
If you get something else please keep me posted.
« Last Edit: August 22, 2021, 09:19:21 pm by yus »
  • Country: ru
« Reply #11 on: August 23, 2021, 04:44:19 am »
Yes, now I still looking for schematics on all gigatronics power meters and maybe firmware files, for example to make 8542C from 8542B as I was do with anritsu ML2407 and ML2437
Offline picburner
« Reply #12 on: August 23, 2021, 05:12:48 am »
Attached are the firmware v1.35 and v1.55 for Giga-tronics 8650A series (8651A & 8652A).
I don't own these instruments so all the help I can provide ends here.
The following users thanked this post: smaultre
  • Country: ru
« Reply #13 on: August 23, 2021, 05:57:20 am »
Thanks, will try.  :-+
Offline yus
« Reply #14 on: August 24, 2021, 09:55:40 am »
@ picburner. Thanks a lot for the files.
@ romal 76. I have  8652A and I was also curious if it is possible to convert 8652A into 8652B. I only have schematics of 8540C, if you have something else, can you share ?
« Last Edit: August 24, 2021, 10:02:14 am by yus »
  • Country: ru
« Reply #15 on: August 24, 2021, 04:00:43 pm »
I'm interested in schematics of 8540C too, please share all you have.
Offline rainbow
« Reply #16 on: November 09, 2022, 04:39:43 pm »
Someone has found the schematics for the 8650(A/B) series? And how to update the firmware via RS232?
thanks
« Last Edit: November 10, 2022, 11:13:03 am by rainbow »
Offline rainbow
« Reply #17 on: April 13, 2023, 06:12:21 am »
At https://web.archive.org/web/20071018084015/http://gigatronics.com/support/index.php?p=5 I have found that giga-tronics was distributing the utility to upgrade/reflash the firmware. Unfortunately, the binary is not archived. Someone has the file? I am desperately searching it since my 8651A is dead and everything seems ok. Thank you
Offline delat
« Reply #18 on: July 05, 2023, 02:36:33 pm »
I'm looking on photos of the Giga-tronics and HP sensors on eBay and looks like power meter connectors are the same. Is it possible to use HP sensors with Giga-tronics meter and vice-versa?
Offline rainbow
« Reply #19 on: July 05, 2023, 02:48:14 pm »
No, they are different. See attachment.
Offline delat
« Reply #20 on: July 05, 2023, 03:05:47 pm »
Thank you. Probably it is stupid question, but is anybody tried to repair probe with BAT24-02LS? https://www.infineon.com/dgdl/Infineon-BAT24-02LS-DS-v02_00-EN.pdf?fileId=5546d46265f064ff016638964eed4e95
Of course, it will require to full recalibration but looks like it is possible as for me.
Offline delat
« Reply #21 on: July 10, 2023, 05:09:43 pm »
Is it possible to test measurement unit without sensor? I got one as broken. But I still haven't any sensors. The unit is booting properly. And allow to change calibrator frequency up to 1GHz while missing Option 12 lable on backside.
Offline rainbow
« Reply #22 on: October 31, 2023, 09:17:14 pm »
Any news about schematics and/or software upgrade? thank you
Offline rainbow
« Reply #23 on: November 01, 2023, 04:32:48 pm »
In attachment the firmware with the procedure. Get the latest firmware version from the picburner's post.
