Author Topic: MSO/DSO oscilloscope as logic analyzer  (Read 2586 times)
Offline bobwidlarTopic starter
  • analog IC design engineer
« on: May 18, 2016, 07:54:50 pm »
Dear all,
I've been trying to measure the ADC I designed, and I would like to capture 3-bit digital data @ 25MHz via an oscilloscope. Currently I have Agilent DSO 3054A available. The problem is,  I couldn't find a way to synchronize the data to the clock of 25MHz I'm providing on the CLK line of the digital inputs. A normal logic analyzer would do this, but is it impossible with the oscilloscopes?
Online nctnico
Re: MSO/DSO oscilloscope as logic analyzer
« Reply #1 on: May 18, 2016, 08:09:04 pm »
AFAIK there are MSO oscilloscopes with external clock inputs but they are very rare. You'll have better luck with a real logic analyser.
Offline tautech
« Reply #2 on: May 18, 2016, 08:36:37 pm »
Dear all,
Can't you do that with the analogue inputs?  :-//
Then the full trigger suite available can be used.
Did you watch Dave's recent vid where he's looking at a bus with his Agilent DSO?
https://www.eevblog.com/forum/blog/eevblog-879-rs-1202-scope-bandwidth-hack-investigation/
Offline rstofer
« Reply #3 on: May 19, 2016, 03:39:32 am »
most of the time, I have to invent a trigger pulse.  My projects tend to revolve around uCs or FPGAs so it is usually possible to output a synch pulse some time before things get interesting.
Offline 2x2l
« Reply #4 on: May 19, 2016, 06:17:17 am »
Dear all,
I skipped to about 15 minutes in just because I wanted to see what sort of visualization software he was going to use off that hack (I've never seen R&S' protocol analyzer software and I wanted to see how similar it was to the "Gold Standard" (at least in my mind,) Teledyne). Instead I saw a deformed chip with half of the wafers protective layer had been killed. Did he take fuming nitric acid to it or something?!
« Reply #5 on: May 19, 2016, 08:58:28 am »
Well, the one I have has a CLK input but only active on protocol decoding mode.
I can give it a trigger, actually I can use digital lines as trigger too (assuming acquisition trigger?). But the problem is the internal clock and the ADC's clock are not synchronized. You see a big bit error rate if the both sampling frequencies get close as expected. I want to get like 4 million data points, so I want to use the oscilloscope sampling as close as to ADC's Fs for maximum data rate. I didn't try to sync both clocks with external trigger in though.
Online nctnico
« Reply #6 on: May 19, 2016, 10:47:08 am »
How about getting a long record, save it to disk and post-process it with PC software?
