Author Topic: Symmetric Power Supply with HP 6632B  (Read 2454 times)
Offline baluTopic starter
« on: July 03, 2014, 10:22:02 am »
Sometimes I need a symmetric power supply for test and development. I used two 6632B (System DC Power Supply) in series to get a symmetric power supply. Today you can buy units as a bench power supply for less money (e.g. in Germany for less than 300 Euro). I think to use two 6632B is a better than buying a real symmetric or dual power supply. Because they are expensive or will not deliver the voltage and current with the precision like the 6632B.
Advantage:
  • High precision power supply
  • Voltage range up to +/-20V
  • Current range up to 5A per rail
  • Full protection for over current or over voltage (remote shut down via external link)
  • Programmable and control via RS-232 or GPIB
  • Inexpensively and available
Disadvantage
  • Two devices
  • No synchronized voltage or current setup
  • No Front-panel Binding Posts (optional)
  • Need many connections to DUT (V+, V-, GND, Sense V+, Sense V-, Sense GND1, Sense GND2)
I have built a terminal HUB to reduce the number of connections between the power supply and the DUT.
Offline Neganur
Re: Symmetric Power Supply with HP 6632B
« Reply #1 on: July 03, 2014, 10:51:41 pm »
Haha, zwei Dumme, ein Gedanke. (great minds think alike/ two fools, one thought)
guess I'm being a cheap arse though with my plastic box and I also have to place the jumper manually. The sense wires are connected to the binding posts internally.
« Last Edit: July 03, 2014, 10:53:58 pm by Neganur »
