Author Topic: GM328 transistor tester MCU firmware update  (Read 6911 times)
Offline sdancer75Topic starter
  • Country: gr
« on: March 17, 2019, 08:23:59 am »
I bought a GM328 transistor tester that can't be calibrated. It stucks at the "short probes" stage. Anyway, I decided to update the MCU firmware.
I connected the ATMega328pu to my breadboard and I double checked the connections with my DMM. The AVRdude always return the following error :
D:\temp\GM328\EN>avrdude -pm328p -cUSBasp -B4 -Pusb
avrdude: set SCK frequency to 187500 Hz
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
I even tried to connect an external crystal but without luck. What seems to be wrong here? My OS is Win10/64Bit and AVRdude is v5.10
Regards,
  • Country: gr
Re: GM328 transistor tester MCU firmware update
« Reply #1 on: March 17, 2019, 10:51:14 am »
An 8MHZ crystal solved the problem !!! :phew:
Best Regards,
  • Country: gr
« Reply #2 on: April 15, 2019, 05:12:00 pm »
Also to note, the GM328 could not be calibrated because it had wrong resistors. I replaced them, and it worked like a charm.
« Last Edit: April 15, 2019, 05:14:35 pm by sdancer75 »
Offline akcoord
  • Country: eg
« Reply #3 on: November 29, 2022, 02:05:20 pm »
could you plz
mention the steps to do that and explain how to update and pass the fuse thing i have mine and i want to update using the usbasp but do not know which software to use  and how to
best regards
i hope you still follow
Offline Fuzzy Star
« Reply #4 on: November 30, 2022, 03:30:35 pm »
could you plz
The info that you are looking for is probably in this thread:
https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
You can do search there.
The following users thanked this post: akcoord
Offline akcoord
  • Country: eg
« Reply #5 on: December 01, 2022, 11:14:38 am »
thanks man
i hoped for a full steps buy video guide anyway thanks mine is mg328 and i face the same problem with soft 1.11k which is very old also selftest message always appear even if i calibrate it so many time
and the resistors value you mention is the right one but they need a very precise one
i hoped for tools for compiling the download version of v m1.45 and tools to use to extract makefile and hex and eep one also how to change fuses to suite my hardwre version which is not present at the hole 3700 post
best regards
Online pope
« Reply #6 on: December 01, 2022, 12:38:32 pm »
Same here,
That thread is so overwhelming... Every time I try to read something, I give up after 5 minutes.
  • Country: gr
« Reply #7 on: December 01, 2022, 12:57:05 pm »
I really don't remember anything of this. It was quite long now.
Anyway, I am not a professional electronic technician but instead, a software developer so it's not my everyday work. This is a hobby for me, working with electronics and microcontrollers.
As far as I can see from the photos I attached, I followed the connection diagram, and using avrdude I uploaded the new firmware.
Where exactly do you have a problem with this? Are you able to use AVRDude? What is your experience on the topic?
Regards,
