It's spelt DER EE DE-5000.
As mentioned previously on the forums (somewhere) the DER EE testing voltage is higher but under application this is loaded down to a semi conductor friendly level. Now if this occurs under all situations, that would have to be tested.
The DER EE will not discharge capacitors, the Peak only has limited voltage discharging (it's rated at 50V and under). The DER EE will be almost certainly damaged earlier than the Peak.
The DER EE has a slew of features the Peak doesn't including kelvin connectors for lowish ohm measurements. PC interface. Dissipation factor, Quality factor or Phase angle for L/C measurement mode. Data Hold. Tolerance and sorting. Dual display with bar graph. Relative function. DC resistance, AC resistance.
The Peak tests at 100kHz. The DER EE has the option of 1kHz, 10kHz, 100kHz, 100Hz & 120Hz. The test frequency can make a big difference in the results.
