Author Topic: GPIB to USB controller/adapter  (Read 29170 times)
Offline asgardTopic starter
« on: April 06, 2013, 05:33:53 am »
Dave et al,
I have recently acquired an HP (before it morphed into Agilent) 1631D logic analyzer.  My previously misspent youth was taken up with doing very serious O.S. code using a 1630 as my primary debugging and bench tool, so I have particular fondness for the good old 1630.  What's new with the 1631 as opposed to that is that it includes a 2-chennal, 50MHz DSO as part of the package.  Real cute, albeit primitive by current standards.  Nevertheless I wanted to leverage available equipment as part of my design lab, so I wanted to use the 1631 to prepare documents for standards compliance (I am working on projects that will in all likelyhood require documented compliance with EnergyStar, IEC/EC, and so on).  I want to connect the GPIB (HP-IB) interface on the back of the 1631D to my PC so I can do screen capture and saving/restoring of analyzer setups.
What hacks me off about this is that even in this day and age the typical converter for USB to GPIB/IEEE488 is a little dongle that sells for about 400-500 USD.  That is a serious disconnect between cost of materials and sales price.  Even the One Hung Low stuff is about that price.  There is one notable exception, and that is a little honey from Softmark, in Australia (not Austria).  I don't know if you (or any of the other crazy Aussie blokes down there) have any experience with such gadgets, but I would be interested in knowing why the Softmark converter is so cheap compared with all the others, and whether it is truly usable with LabView or any such stuff on my PC.
Thanks muchly,
J.R. Stoner
Klaatu Barada Nikto!
J.R. Stoner Bifrost Development Group asgard@jeffnet.org
Offline amspire
Re: GPIB to USB controller/adapter
« Reply #1 on: April 06, 2013, 06:29:54 am »
The Softmark converter is pretty useless. I would not touch it. It is extremely limited in GPIB capability, and I think it only works via the provided very lame software.  Isn't it run from a parallel printer port? If so, who has a parallel printer port?
The good news is that things are not quite as bad as you think.
If you want something very good, go for the Prologix converters, or about $100, you can probably find Agilent USB/GPIB converter clones that can use the Agilent drivers. These options are fully compatible with most recent IEEE488.2 spec and with Visa drivers.
http://www.ebay.com.au/itm/S82357-GPIB-USB-interface-Agilent-82357-compatible-/171016606020
If that is too much, then there have been a few projects in this forum and elsewhere for DIY converters.
Steve ( scasagrande ) did a great open source board that he was selling, but you could get all the info to make your own.
https://www.eevblog.com/forum/buysellwanted/for-sale-oshw-gpibusb-adapter/
There is also a current thread about a project:
https://www.eevblog.com/forum/testgear/gpib-usb-what-functions-would-you-like-in-one-of-these/
Typically the DIY projects are not VISA compatible which is good and bad.
Bad as you cannot use them with the standard GPIB drivers for compatibility with many high end software tools, but good as you do not have to install 500MBytes of junk to just be able to send a 10 byte request to an instrument, and get a reply back which is maybe 15 bytes.
Richard
« Last Edit: April 06, 2013, 06:43:07 am by amspire »
« Reply #2 on: April 07, 2013, 03:19:23 am »
I did go and have myself a good hard look at Steve Casagrande's project.  I had a hard time with the schematic, so I wanted to rerender it with my usual tool, which is Eagle.  Here is what my refigure of the schematic looks like.
I have also laid out the pcb to fit one of the Sick Of Beige boxes.  Only thing left is to build the thing and hang it off my scope.
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #3 on: April 07, 2013, 07:24:10 am »
I have the faster variant of this adapter (F82357) and can really recommend it, there's probably nothing better for this money available right now than these Beiming adapters. I had a look at the alternatives but none of them supported VISA/IVI which made them pretty useless for me.
I'm using my Beiming adapter in NI.488 mode (National Instruments compatible) as most programs which support GPIB expect NI kit, and so far it works just fine and absolutely stable. Tested under Windowsxp, Vista x64 and Windows 7 (32bit and x64), and also under Windows 8 x64.
« Last Edit: April 07, 2013, 07:26:36 am by Wuerstchenhund »
Online bingo600
« Reply #4 on: April 07, 2013, 01:22:52 pm »
I got a Beiming off 'bay
I emailed Beiming twice within the last month to get confirmation that one can use Agilents firmware to update it.
No answer on both accounts  :--
Beiming claims their adapter is 100% compatible with the Agilent-82357A, and rumours are ... Even firmware compatible.
According to the Linux-Gpib Project : I need to update Agilent-82357A adapter to the included firmware.
http://linux-gpib.sourceforge.net/firmware/gpib_firmware-2008-08-10.tar.gz
Support or any firmwareupdates from Beiming are apparently non-existant :-- :--
They have releasenotes & upgradeguides , i can't find any firmware files .....
Wonder if it's a Rigol daugthercompany.
To be fair i have heard the adapter does well as an Agilent Clone , but expect no support  >:(
/Bingo
Online bingo600
« Reply #5 on: April 09, 2013, 02:26:54 pm »
To be fair , i just got an answer from Beiming today.
I had been "caught in the spam filter" they said.
I was informed that you can not use Agilent firmware , and that they dorsn't support linux-gpib for now.
But they expect that feature to be added soon.
I'll get a new firmware for my adapter this week.
/Bingo
Online bingo600
« Reply #6 on: May 30, 2013, 03:17:44 pm »
Good news  :)
I'm currently in dialog with Beiming , and i am testing linux-gpib support on the S82357.
I have only done some light tests, with the ibtest program.
But it seems to work on my "quirky HP 5384A" that refuses to set EOI , and behaves the same as my Agilent USB adapter
This will be nice , as i paid 2x the Beiming price for an Agilent , to get Linux support.
Beiming offers 2 solutions , 1 where you load the code on usb-insert (fxload) , just as an Agilent.
And (untested by me) , one where you program the new firmware permanently into the iic eeprom , and doesn't need to load firmware on usb insert.
I don't know when they release the frmware(s) for public use , but would not expect a long time.
Nice work Beiming  :-+
/Bingo
Ohh: I get to test the F' firmware also when they're ready.
Offline manticore00
« Reply #7 on: July 31, 2013, 10:52:08 pm »
Erik,
I bought that one to work with my 34401a and it works great with the Agilent software.
Aut viam inveniam aut faciam
Offline JoeyP
« Reply #8 on: August 01, 2013, 02:24:02 am »
I use one of the Prologix adapters. I've found it to be, uh, OK. It does get the job done, but have found it to be susceptible to crashing in a way that requires at least R&R of USB cable, if not reboot of PC. Seems to really not like having devices connected which are not powered up - but that might be the fault of the GPIB device rather than the adapter.
Offline c4757p
  • adieu
« Reply #9 on: August 01, 2013, 02:28:39 am »
This is a GPIB connector.
Do you want to have to unplug a bunch of these when devices are shut down? It's the adapter's fault. ::)
Offline JoeyP
« Reply #10 on: August 01, 2013, 02:53:45 am »
I don't disconnect them. I just make sure the troublesome device is powered up. I realize that this shouldn't be necessary. The GPIB spec says that devices are not supposed to load the bus when power is off. But, I've found that not all devices - particularly older ones, honor that part of the spec. I do suspect the adapter, but it could also be the fault of a non-compliant device in my stack, so don't want to bad-mouth the product without knowing for sure. It only happens with a certain device. Others can be powered off without issue.
alm
  • Guest
« Reply #11 on: August 01, 2013, 06:57:55 am »
It might also be weak drivers in the Prologix device. Do they use a real GPIB chip or some random logic gate to drive the cable? GPIB is designed to work with long cable and many devices, so the outputs are supposed to be quite beefy.
Offline TerraHertz
    • It's not really a Blog
« Reply #12 on: August 01, 2013, 12:47:26 pm »
Dave et al,
Hey, I too have a HP 1630G. Used it for many years, though it's currently packed away for lack of workspace.
I'll be interested to hear how you go, getting it to talk with a PC. I'd like to do that too. I have the dual floppy disk unit, but it's a pain since the floppies are non-standard format, and can't be read in PCs. I have several disassemblers for the 1630G on those disks. Would be nice to get them into a more permanently archived form.
It was always tempting to buy the analog scope card, and see if it could be added to my 1630G. The space is there, along with the holes for BNCs. The extra EPROMs are available. But I think when I looked into it there was a problem with number of EPROM sockets free. Can't recall the details.
Online bingo600
« Reply #13 on: August 01, 2013, 03:16:33 pm »
Good news  :)
/Bingo
Beiming is working on their linux support again  :-+
They apparently upgraded their linux distro , and got some linux-gpib kernel/module troubles , that i helped out with.
I'm currently testing with linux-gpib and gpib-utils , and it looks promising.
So far i have seen no differences to my Agilent adapter.
Thy are now trying to get a "scope" that has support in gpib-utils , in order to test a binary xfer (screendump)
Afaik their windows support is already ok , and it supports all the "VISA's".
I haven't tried any of the adapters on windows , as i am 95% linux based.
And would like to stay that way.
But if they get the linuxsupport error free , i'd say its a nice buy for the price.
I payed 2x the amount for the Agilent adapter on *Bay.
They support loading of firmware via fxload like the Agilent , or you could install the i2c image on the adapter once and skip the loading.
I prefer the fxload way , as i'm used to with the Agilent
/Bingo
Offline JoeyP
« Reply #14 on: August 01, 2013, 04:35:22 pm »
They drive the bus directly from their microcontroller, an Atmel ATMEGA644PA which seems like a cheesy way to do it. Didn't look at the output specs for that controller, but did test the adapter with about a dozen devices and much cabling when I first got it. Worked OK in that config, but just doesn't like one particular device when it's powered down. When that device is not powered up, the driver/adapter hangs in the most obnoxious way, and teaches you quickly not to forget to turn it on. If it would at least recover more gracefully from that condition I could overlook/forgive the behaviour.
Online MarkL
« Reply #15 on: August 05, 2013, 06:13:12 pm »
Dave et al,
You likely can't move from a 1630G to a 1631A/D.  Here's the detail on the (obsolete) upgrade kit:
http://www.home.agilent.com/agilent/redirector.jspx?action=ref&cname=PRODUCT&ckey=10330A%3Aepsg%3Apro&lc=eng&cc=US
As far as the GPIB connection via a PC, it does work for storing configs, doing screen captures, and getting data out of the unit.  But you may have some trouble loading the disassembler into a 163x from a PC since, according to the manual, the unit wants to talk to the disk drive directly.
For the OP, screen captures are returned in HPGL format, so you will need to convert them into something more useful for inclusion in a document.
I have a 1631D that hasn't been used in years.  It was great for its time (late 80's), but in today's terms its really quite slow and limited.
Online bingo600
« Reply #16 on: October 09, 2013, 12:44:15 pm »
Good news  :)
/Bingo
/Bingo
 I just got word from Beiming that they have released the linux (linix-gpib) support firmware for their two USB GPIB adapters - S82357 and F82357 (DMA).
They got the "OK" from the linux-gpib maintainer , where he writes :
I tested your GPIB interface with my Signal Generator and it worked perfectly first time, no problems. For the next release of linux_gpib 3.2.19 I will include your product in the supported devices part of the documentation.
According to Beiming , the firmware should support "Visa" with HP drivers under windows , and now also linux-gpib.
Nice to know there is a $79 / $99 unit with both Win 6 Linux support
/Bingo
Offline madshaman
  • ego trans insani
« Reply #17 on: October 09, 2013, 01:40:51 pm »
To be responsible, but never to let fear stop the imagination.
Offline RobbieC
« Reply #18 on: October 11, 2013, 02:45:57 pm »
I picked up the Ethernet version of the Prologix to talk to the six or seven GPIB devices I have (including a HP 1650B LA). So far I've only done a few simple comms tests, but I'll be putting some .net programs together that will talk to multiple instruments so that should shake out how well the Prologix works.
Th nice thing about the Ethernet version is the lack of drivers and the ability to access it remotely (say, from upstairs since all of my gear is in the colder basement =).
Offline samofab
  • Country: si
« Reply #19 on: October 11, 2013, 10:39:02 pm »
Anyone tried this one?
 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=261254570258
I heard that this one has problems with Tek binary transfers.. aparently it works otherwise.
Offline tinhead
« Reply #20 on: November 17, 2013, 11:20:02 pm »
that thing is clone of Beiming GPIB-USB S82357 adapter, it does use one of the early firmwares. I do not recommend to use it, if spend money then at least on a product where one know that the manufacturer is updating firmware/fixing bugs, like the S82357 or F82357 from Beiming.
Offline mrflibble
« Reply #21 on: December 17, 2013, 05:02:46 am »
I noticed mention of this in other threads as well. Is this a particular measurement device? If so, which one? Or is this the GPIB-USB adapter? I noticed in the SN75160/1B datasheets they make a big point that they do not load the bus when VCC = 0, which would be the case when the gpib adapter is powered off. But in your case the adapter is on, but one of the devices is off right? If so, have you even had the chance of testing it with a "proper" gpib adapter that could sink enough current?
Offline alex.forencich
    • Alex Forencich
« Reply #22 on: December 17, 2013, 05:32:12 am »
Ethernet is definitely the way to go.  The old HP E2050A units pop up on ebay from time to time for less than $100.  The Ethernet side only supports 10 Mb ethernet, but that's already faster than the GPIB side so it's not really an issue.  They speak VXI-11, so they work with all of the VISA libraries.  I have a pair of them myself, and I wrote a nice cross platform Python library that works perfectly with them.
The only thing I really don't like about all of the Prologix stuff is that it doesn't support the standard protocols for communicating with the adapter.  If their Ethernet cable spoke VXI-11, it would be decent deal.
Python-based instrument control: Python IVI, Python VXI-11, Python USBTMC
Offline free_electron
    • SiliconValleyGarage
« Reply #23 on: December 17, 2013, 07:06:51 am »
you need to read up on your standards ...
1)  10 megaBIT ethernet has an effectiveusable rate ( if on a dedicated link ) of about 9megabit ( there is overhead bytes in mac and IP address. The usable payload is smaller)
2) GPIB in its base 488 standard is a 10 megaBYTE transfer rate and can go 25 Megabyte/S in 488.2 (Turbo mode). you need at least a 100base-T link to keep up with a GPIB bus going flat out.
    • Alex Forencich
« Reply #24 on: December 17, 2013, 07:28:04 am »
I stand corrected.  I was under the impression that GPIB only ran at around 1 MBps or so.  In that case it seems like you would need gigabit ethernet to keep up with turbo mode as 100 Mbit only provides 12.5 MBps.
« Last Edit: December 17, 2013, 07:30:39 am by alex.forencich »
