Author Topic: GPIB-to-USB or GPIB-to-ethernet - options for home lab  (Read 6185 times)
Offline TheUnnamedNewbieTopic starter
  • mmwave RFIC/antenna designer
« on: January 19, 2018, 04:07:37 pm »
Hi guys,
If you have a lot of older gear in the home lab it will likely not come with USB or LXI/ethernet, but will have GPIB. I was wanting to do some automated testing of stuff, but I have no GPIB interface to connect to my instruments. Looking online, GPIB-to-USB or GPIB-to-ethernet opetions all see quite expensive (around 200 euros).
Is there any reason these are so expensive? (do they contain some special unobtanium or something?) or is this just market-supply-demand-markup going on? Are there any cheaper options, perhaps using home made controllers with arduinos or rPi or whatever?
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
Offline pelule
  • What is business? It’s other people’s money
Re: GPIB-to-USB or GPIB-to-ethernet - options for home lab
« Reply #1 on: January 19, 2018, 05:52:37 pm »
Option1: build your own GBIB to USB (for example PIC ate Arduino based) - there are some project published (just use the g..le)
Option2: buy a used GPIB-to-USB converter at the bay (got mine for ~70 EUR incl shipping)
Otpion2: buy a cheap chinese GPIB-To-USB converter (~80-100 EUR)
Option3: time to time in the bay some used GPIB PC cards are offered at the bay (I got my PCI one for ~30 EUR inc. shipping)
/PeLuLe
You will learn something new every single day
Offline alm
« Reply #2 on: January 20, 2018, 09:49:19 am »
I think it's mostly that it's a niche market. Keep in mind that the standard requires more substantial drivers than a MCU I/O pin, so the cheap DIY ones might not work reliably with some devices or many devices in a chain.
It depends on the software you want to use. With software from NI or something from a big instrument manufacturer like BenchVue, you will need an adapter that supports the current version of NI-VISA or Keysight VISA.
Something like the HP E2050A can be used as LAB to GPIB gateway, and can sometimes be found for $50 or so on eBay, but is not supported by current Keysight software versions. But it works fine with python-vxi11. The more modern E5810A, that is still supported by their current software, is much more expensive.
Offline Fortran
« Reply #3 on: January 20, 2018, 10:36:10 am »
I'm using this.  :)
http://dalton.ax/gpib/
Works great with all of my gear.
I've got spare boards if you're interested.
Offline Magnum
« Reply #4 on: January 20, 2018, 01:49:35 pm »
Offline BloodyCactus
    • Kråketær
« Reply #5 on: January 20, 2018, 05:05:39 pm »
ICS 8065 show up on ebay cheap time to time. I have one. it works very well. You can I think daisy chain 16 GPIB instruments to it and connect it to lan. works very well.
-- Aussie living in the USA --
« Reply #6 on: January 20, 2018, 06:47:45 pm »
I am using a Agilent 82357B from Ebay. It works great with Keysight VEE and Labview. There are lots of them available from China, some seem to be clones, some seem to be original: https://www.ebay.de/itm/NEW-Agilent-82357B-USB-GPIB-Interface-Adapter-GPIB-USB-Controller/192183286857?_trkparms=aid%3D555017%26algo%3DPL.CASSINI%26ao%3D1%26asc%3D20160630134825%26meid%3D940546cf2e0f47b48fcdd2211750c523%26pid%3D100507%26rk%3D1%26rkt%3D1%26&_trksid=p2045573.c100507.m3226
Going by the fact that the first image shows "Functional Test Ceryificate" answers the question of authenticity I think  ;) However, for 75 Euros it might be worth trying... I'll have a look.
But I'll keep a lookout. I don't want to try a DIY solution, I don't trust my ability with anything digital and don't want to have to question the device every time I run into issues...
Offline Bratster
« Reply #7 on: January 20, 2018, 08:52:03 pm »
Another gpib-ethernet one to look for on eBay is the tektronix ad007. Occasionally they crop up for a good price, $50-90 US dollars.
While older, it talks standard Visa.
Sent from my Nexus 6 using Tapatalk
Offline DC1MC
« Reply #8 on: January 20, 2018, 09:24:43 pm »
I'm using this.  :)
Hi, I'm interested in a pair of boards, please PM me with shipping to Germany included.
 Cheers,
 DC1MC
Offline wakawakawaka
« Reply #9 on: January 21, 2018, 11:14:59 pm »
Hi, do you have an idea of the longevity of these? I have a GPIB-USB that cost something like $300, but I have to power cycle it periodically.
