All,
Along with working on the Tektronix oscilloscopes, I have also been dabbling in time references. In particular a surplus 10mhz rubidium reference, and a china made GPS disciplined clock with 10Mhz sine wave output. Having a fair amount of measuring equipment, but nothing that approaches the theoretical accuracy of eith the rubidium reference or the GPS disciplined clock. So today, I hooked both up , let them warm up for a few hours, and input the output of both references to my 2445B, and took a look at the display. Both had a nice sine wave display, but the displays were shifting position in reference to each other. It takes right at 5 minutes ( as best I can measure) for the displays to shift one cycle. That works out to .00333 hz difference. The question I am asking myself, is which one is actually the most accurate? The stand alone surplus rubidium reference or the GPS disciplined reference. Normally I would believe the GPS one is the most accurate, but it is one of the relatively inexpensive ones from China that they are selling on -bay. One of the interesting things about the GPS reference, is that when I opened it up to see what was inside, the OCXO was made in the USA. I have searched the net and can find no reviews on these GPS based references. Do any of you guys (and gals) have one of these units (GPS disciplined Clock, BG7TL 2014-12-09), and just how accurate do you think it is, and how did you test it?
Mitch
