Author Topic: Gratten GA1102CAL Scope Firmware?  (Read 10007 times)
Offline BiOzZTopic starter
« on: April 27, 2014, 06:19:19 pm »
I have a Gratten GA1102CAL and its in desperate need of a firmware update, some functions are glitchy, one does not work and newer ones roll out with that fixed, i know its simply a rebadged atten 1102cal and i did try that firmware and it did not work ... i cant find any download link, cant find a gratten website or anyone to contact
anyone have any luck or know of a link? i know its updatable over the USB host because there are functions in the scope to do that and i dont wanna risk hacking up the firmware for the atten scope to try and force it to work
EDIT: Found this on there EU page http://www.atten.eu/oscilloscopes/ga1102cal-100hmz.html ... even tho it says its 100hmz >_> ... i sent them an email .
EDIT 2: they responded extremely fast asking for my serial number and hardware revision and than quickly responded letting me know that they will contact (or put me in contact the english was not the best) with the engineer tomorrow, i have to say i was not expecting this
« Last Edit: April 27, 2014, 06:50:50 pm by BiOzZ »
My one regret in life is learning to speak English on the internet ...
Offline bithead9
Re: Gratten GA1102CAL Scope Firmware?
« Reply #1 on: September 22, 2014, 12:33:01 am »
Did you get the firmware or still need it ?  I have the ones from ATTEN that I saved when they were originally posted on the China site (they are now gone).  :(  Drop me a PM or reply to this thread if you want a copy.
The following users thanked this post: vwaldon@gmail.com
Offline vwaldon@gmail.com
« Reply #2 on: May 28, 2023, 03:57:06 am »
Bumping this thread in case someone still has one of these scopes and/or the latest firmware.
Just inherited one, firmware is old and buggy, and of course most of the links in threads like this no longer work.  :)
Cheers,
Vince
Offline neilw20
« Reply #3 on: July 16, 2023, 04:54:06 pm »
I have a Gratten that keeps resetting very often. GA1112CAL.
I have original disk. Is there an update available?
What keys do you hold while powering up for a clean reset. It looks like corrupted system.
Thanks
« Last Edit: July 16, 2023, 04:57:52 pm by neilw20 »
Offline tv84
  • Country: pt
« Reply #4 on: July 16, 2023, 06:00:51 pm »
The only CAL FW ever shared is ATTEN_ADS1000CAL_V100R003B01D01P31R16_3.01.01.31R16.
So, it's not from Siglent but from Atten. If it's newer than yours maybe it's worth flashing BUT this is all unchartered waters!
« Reply #5 on: August 24, 2023, 04:25:17 am »
By any chance do you have a current source for that file?  Lots of dead links unfortunately.  Thanks!
Offline tv84
  • Country: pt
« Reply #6 on: August 24, 2023, 01:34:49 pm »
Attached.
The following users thanked this post: coromonadalix
« Reply #7 on: September 01, 2023, 01:03:01 am »
Thanks muchly!!!
Should probably retire this old scope but I like to save stuff from the landfill if at all possible.
Appreciate your response.
Vince
« Reply #8 on: September 11, 2023, 02:20:20 am »
Spoke too soon... scope can't find the file.
Based on a bunch of Googling I've tried:
- shortening the name
- FAT
- FAT16
- FAT32
- 1 G memory stick
- 64 meg memory stick
- with a CFG file and without
Anyone remember, from back in olden times, any particular trick to this?!?!
Offline tv84
  • Country: pt
« Reply #9 on: September 11, 2023, 08:48:53 am »
Change USB disk and repeat.
« Reply #10 on: October 30, 2023, 11:58:22 pm »
Sorry, I'm not sure what you mean by "change USB disk".
I've tried multiple different USB sticks (in multiple formats) if that's what you're referring to?
« Reply #11 on: October 31, 2023, 04:42:40 am »
- FAT
- FAT16
- FAT32
- 1 G memory stick
8Gb max. FAT32 with 4k clusters
« Reply #12 on: November 01, 2023, 07:20:04 pm »
OK, thanks, will give that combo a go!
Offline EduardoLM
  • Country: br
« Reply #13 on: May 16, 2025, 03:12:56 pm »
vwaldon@gmail.com, did you ever succeed on updating the firmware? I'm facing the same exact problem. Thanks!
Eduardo
