I came across a defect HP3468A. It won't power up, powersupplies are OK (15,-15,5), display shows some random activity for 1/4 second (probably just the display powering up)
No characters however, no relays clicking nothing, dead silence.
Found out that the micro gets reset every 1,3 seconds.
Looking further and making sure the uC was not bothered by the reset circuit, I found that U507 is not getting clocked by the uC.
So I suspect the U502 ROM (Mostek MK 36752) being defect.
Can not find anything on the internet except another person with the same problem 2 years ago. Does anyone here know how I could get the ROM contents of U502 , and also a good (pin compatible) replacement part? Unfortunately U520 is positioned right under the plastick power stick,so a socket with rewiring is probably out of the question.
It looks like a 8092 byte eprom with 24 pins is also unusual (2764 has 28 pins).
