Author Topic: Hacking Keysight 1000X  (Read 7411 times)
Online Fungus
Re: Hacking Keysight 1000X
« Reply #25 on: October 06, 2019, 01:54:04 pm »
This should probably be in the hacking thread.
Are we not there? ?
Oh, yes, so we are!  :-DD
(I mean the original hacking thread, this is a new one...)
« Last Edit: October 06, 2019, 01:57:24 pm by Fungus »
Online Fungus
« Reply #26 on: October 06, 2019, 02:15:34 pm »
Is it possible to boot the 'scope using firmware v1.0 and the trick detailed here:
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg264356/#msg264356
If so, can you upgrade to the hacked v1.1 firmware?
Even if that doesn't work, it's still a simple way to run the hacked v1.1 firmware directly from USB with zero risk - just pull the stick out and revert to factory firmware.
(at the cost of a 'little bit longer' boot time ... how much longer?)
Offline TK
« Reply #27 on: October 06, 2019, 10:52:54 pm »
Most of the tricks for the 2000X or 3000X series do not work on the 1000X, i.e. the infiniivision.lnk method never worked on the 1000X.
The following users thanked this post: Fungus
Offline tv84
  • Country: pt
« Reply #28 on: October 06, 2019, 11:31:50 pm »
Sure, but what FEECSA did on the 1000X could, very well, be used in 2000X and 3000X. Same patch.
Offline TK
« Reply #29 on: October 07, 2019, 12:07:15 am »
Sorry for the confusion, I was replying to Fungus's post about running the firmware from USB, etc... If FERCSA hack could work on the 2000X 3000X, then it is an interesting finding worth sharing on the 2000X/3000X hacking thread
