Lightages, Statement from an ebay seller: Re.: TekPower TP4000ZC Compatible with Xp and downward, it may not work on Vista and Win7.Not trms(Not a big deal, right?) or Win 7 compatible(A big deal 'cause that's what I have), right? OK, thanks!
Quote from: teslafan on February 08, 2015, 04:02:47 amLightages, Statement from an ebay seller: Re.: TekPower TP4000ZC Compatible with Xp and downward, it may not work on Vista and Win7.Not trms(Not a big deal, right?) or Win 7 compatible(A big deal 'cause that's what I have), right? OK, thanks!It's true that the software that comes with that meter (at least when I bought one 3 years ago) is quite rudimentary and antiquated. What will work with that meter is the exellent qtdmm.I know it works under Linux and OSX - I'm not sure about the Windows version but it's worth a try.BTW, even though the TekPower TP4000ZC is not listed as supported. By TekPower? - I got it to work no problem. It worked with what? With this: qtdmm? Is it Linux or OS-X or works on both? Thanks
OK - I just looked up the newest version of Ultra DMM which I know is Win 7 comptable - since i've used it on my Win 7 laptop. The newest version supports the Tekpower TP4000ZC!Ultra DMM can be downloaded HERE
I've never used it yet but this software supports all these DMMshttp://sigrok.org/wiki/Supported_hardware#Multimeters
Quote from: miguelvp on February 08, 2015, 06:34:15 amI've never used it yet but this software supports all these DMMshttp://sigrok.org/wiki/Supported_hardware#MultimetersThanks, I will keep that in mind. Have any opinions on the next grade up in a trms dmm for same general purpose electronics use with Data Logging?
If you will keep the probes out of the wall socket, meaning no high energy circuits at all, then perhaps this one:http://www.ebay.com/itm/Digitek-DT-4000ZC-TekPower-TP4000ZC-Data-Logging-Multimeter-with-Temperature-/200912705694or the UT61E I guess.Remember, these are only for bench top use! Any specific variants that are better? Appreciate your efforts on my behalf.
