Hello,
I bought this oscilloscope (GDS-2204e 1050€ on tme.eu) to try to solve some rs232 issues, I like it but I don't know if rs232 decoder is working properly (firmware version 1.32).
I connect the GDS-2204e and a DS1054Z to the same signals and I get different decoder results.
I am triggering the oscilloscopes at yellow signal's rising edge and capturing an uart communication (
57600 8N1).
When I look at the same communication packets on the oscilloscopes I see different decoder results:
Rigol
GW
If I look at the first byte, I think rigol is decoding the signal right, at 57600 this is 02 (if I am not wrong
Am I doing anything wrong with the GD-2204e or is it a bug?
If the GW doesn't decode the RS232 properly I will return it. Any good and cheap.. oscilloscope recommendation to work with serial buses (I2C, SPI, RS232 and
full memory decoding)?.
Thank you and excuse my english.
