Currently Toploser seems to need more money and he does that the only way he knows how: by selling equipment for excellent prices. This landed a GW Instek PSP-603 on my desk. It seems like a good addition to my lab as a compact general purpose power supply.
The operation is a bit more complicated but it can do some interesting things. Vlimit sets the maximum output voltage. Unlike many other PSUs the output voltage cannot be set (using Vset) above Vlimit. There is also a current limit and a power limit. The power limit adjusts the current limit. In the end something has got to give. The 'Normal' button saves the current settings for the next time it is powered on. I measured the AC output leakage voltage referenced to ground to see if it has half the mains voltage at the outputs but that isn't the case. I measured about 2V (high impedance).
The power stage:
The front panel:
A MSP430 microcontroller runs the entire thing:
Optocouplers for the serial interface (which isn't a real RSR232 interface; a special cable is required):
'RS232' connector:
The fan is temperature/load controlled. At first it made more sound than I liked but some rubber fan mounts solve that nicely:
So far the only logo I found on the board:
Unfortunately it seems these power supplies have some issues with the capacitors:
https://www.eevblog.com/forum/repair/a-gw-instek-psp-405-lab-bench-power-supply-repaired/However the internals look radically different. The version shown in this thread has a seperate processorboard with a through-hole 8051 microcontroller which explains why my one has so much unused space:
