Author Topic: GW Instek PSP-603 not turning on when cold  (Read 2011 times)
Offline tom66Topic starter
« on: December 07, 2020, 10:53:18 pm »
My trusty GW Instek PSP-603 which I procured from the Farnell tradecounter when it was open in Leeds, has died.
There was no warranty on this product as it was a customer return and I got it for £80 so I cannot complain, it has given me almost 4 years of reliable service so far.  I think the issue is with the onboard power supply which generates the regulated +5V and unregulated positive and negative rails.  Those rails are low when the power supply is cold which leads to a dim display with all segments lit.  I suspect that, despite the 5V rail being correct (all of the digital logic operates on 5V) the malfunction presents itself because a rail comparator is indicating a fault condition or there is some self-test performed which indicates a fault state and the processor watchdogs until this disappears.
This is actually a fairly interesting design.  It's a 60V, 3.5A power supply for lab use, with an SMPS at heart to reduce the weight and probably the cost too.  A pre-switching regulator generates a voltage a few volts above the output and a linear pass transistor produces a stable, regulated output.  The pass transistor seems to remove most of the switching noise although I don't tend to use this PSU for sensitive applications.  (It feeds the scope prototype, but that is mostly buck converters anyway.)
The other particularly curious thing about this design is it contains not one but two 8-bit 8051 microcontrollers (an W78C032C40DL and MG87FE52AE), one with an external flash memory and one with internal flash. Instead of an ADC, a DAC is used as some kind of successive approximation slope converter.  The DAC also generates the Vset and Iset signals for the PSU board by precisely timed output signals from MCU #2,  which are latched into sample and hold circuits which generate the required signals for the PSU board.  The power converter itself is a fairly standard two-transistor half bridge.  Passive PFC is accomplished with a large choke in line with the AC power feed.
I'm not exactly clear on why there are two MCUs, other than it simply being too difficult to fit into one MCU. As far as I can see, the bulk of the work is done by MCU #2 - it drives the keypad, DAC, reads voltage outputs and communicates with MCU #1.  The purpose of MCU #1 appears to be to handle the external RS232 port, drive the display, read the EEPROM and picks up pulses from the rotary encoder.    This looks like a very old design that's probably been only upgraded slightly over the years and must be expensive to make if it is still in production (Farnell website shows it available.)  The date codes on my units suggest a production date of around 2012, but the parts date from the late 90's.  I've confidence that almost everything on this board could be replaced with a single ARM or PIC microcontroller nowadays.
Anyway, I found two bulging capacitors on the PSU.  I tested with a scope, and indeed when the PSU is not working the +/- rails are at considerably different output voltages to what they are when the PSU is working.  Indeed, freezing the caps briefly stops the PSU powering up.
More to follow ... hopefully I can fix this thing.
The following users thanked this post: Wollvieh
Re: GW Instek PSP-603 not turning on when cold
« Reply #1 on: December 07, 2020, 11:03:01 pm »
Video of the fault for those curious
It's also possible to hear an odd whining from the auxillary SMPS on the PSU board.
Offline wraper
  • Country: lv
« Reply #2 on: December 07, 2020, 11:06:11 pm »
Dunno if it's just looks so on the picture but 2 electrolytic caps are probably bulged.
« Reply #3 on: December 07, 2020, 11:07:17 pm »
Yes, those are the ones that when frozen the PSU stops working.  So I suspect they are the fault.   They do appear very slightly bulged although the glue makes it hard to be sure.  Sadly I do not have any of these in my personal stock.
« Reply #4 on: December 15, 2020, 09:06:38 pm »
So, this PSU is fixed.
Replacing those two caps however was not the only problem. After replacing them the PSU cycled rapidly, classic SMPS symptom when the start-up capacitor goes bad so the PSU cannot sustain operation during start up.  Contrary to initial estimations it does not use a self oscillating design for the standby rail,  it uses a TOPswitch TOP222YN.   The original capacitor was 100uF 25V and I replaced it with the only close equivalent I had of 100uF 16V,  which was OK because the TOPswitch internally clamps the Vc node to about 6V.
After that this PSU all works fine now,  and as a bonus the maximum output is restored ... before, the peak output voltage was around 58V but now it is the full 60V.  It seems the design of the SMPS is to track the output voltage plus about 3V, so the power transistor doesn't have to dissipate much heat, although it is still mounted to a modestly large heatsink.
Offline Wollvieh
« Reply #5 on: October 17, 2024, 02:17:42 pm »
I have the same type of power supply  branded Iso-Tech IPS-2010 with 20V 10 A output.
As it stopped working now, I looked through the old threads about it. In https://www.eevblog.com/forum/repair/a-gw-instek-psp-405-lab-bench-power-supply-repaired/ some years ago I contributed some schematics which I found then but didn't need.
One interesting point of your version shown here:
There is a small ceramics cap across the unpopulated "SW1". And the digital ground close to the CPUs crystal is coupled via a (hopefully X2)-cap to earth.
My digital board is already "V 3.0" like yours, but from 04 2008 instead of 2013 like yours. But it's missing both of those bodged caps. So obviously the original manufacturer identified a problem with the reset line (SW1 is a reset button, which I find strange to design into the inside of a power supply) and some other crap happening to the digital part of the PS.
So no help needed here, just a a hint for anyone dropping by because of problems with resetting CPU, flickering display and croaking buzzer that the reason could be some "digital" interference and not only bad caps in the power supply line. The reset button SW1 already has C14 with 10 µ across it, so it's obviously high frequency stuff they want to filter out.
