I've updated my tool to be able to generate options for the new RKey.data file:
https://github.com/zelea2/rigol_vendor_binThe only difference between the Key.data and RKey.data is that the later is XORed with a vector of incremented bytes then xxtea decrypted as before.
The AES keys are changed but we don't need to understand how. I haven't even tested it yet because I'm at work and my scope at home connected on my localnet.
I was able to print my new AES key because in the end I found a very nice environment to test functions in the libscope-auklet.so library.
Initially I wanted to run all my tests on a linux PC but that turned out almost impossible because all of the other library dependencies and symbol versioning.
In the end I've used the scope itself with 'adb root/push/pull/shell' commands.
First I've installed on my linux machine the latest Android NDK (not SDK) then I've made a working directory where I could compile my programs:
<NDK>/build/tools/make_standalone_toolchain.py --arch arm64 --install-dir working_dir
In my test program I first call dlopen to load "libscope-auklet.so" (I also do export LD_LIBRARY_PATH= so the program can find it) and then you can
call any exported function from that library and don't worry about signatures.
I call the CApiLicense constructor and finally the getLicenseKey and print them to stdout. I've also dumped the CApiLicense structure which is 440 bytes long
but I haven't bothered with what all fields represent.
The function which deletes and replaces the old Key.data with RKey.data is CApiLicense::init and I've checked by running it twice that is generates the same new file
so the new AES key (as the old one) must be somehow linked to your particular scope.
I haven't even tested this and my scope is still on v1.1 - probably someone else will beat me until I get home
