Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 330031 times)
Offline shapirus
  • Country: ua
Re: Hacking the Rigol DHO800/900 Scope
« Reply #2575 on: April 08, 2024, 10:12:34 am »
A little preview
(Attachment Link)
Wow that looks exciting. Not just the FFT averaging app, but all the changes to have a launcher etc.
Care to give a bit more details as to what it's all about?
« Last Edit: April 08, 2024, 11:21:14 am by shapirus »
Offline Fungus
« Reply #2576 on: April 08, 2024, 10:41:45 am »
A little preview
(Attachment Link)
Care to give a bit more details as to what's it's all about?
Adding launchers is old news.  :)
I'm more interested in how to get to the home screen without a keyboard.
It looks like he's swiping down from the top of the screen...
Offline mrisco
  • Country: pe
« Reply #2577 on: April 08, 2024, 12:35:17 pm »
A little preview
(Attachment Link)
I didn't add a launcher. I kept the original Rigol to avoid screen flickering on startup. I use an accessibility app.
The following users thanked this post: egonotto, RAPo
Offline Evi
  • Country: ru
« Reply #2578 on: April 08, 2024, 12:47:12 pm »
Quote from: mrisco on Today at 06:35:17
>Quote from: Fungus on Today at 04:41:45
>Quote from: mrisco on Today at 03:23:05
A little preview
> (Attachment Link)
Maybe you stop talking hints and provide reasonable description?
Offline enson72
  • Country: ua
« Reply #2579 on: April 08, 2024, 05:19:29 pm »
Im instal Button Master and assigned the location of the floating button. Getting out without a keyboard is not a problem https://4pda.to/forum/index.php?showtopic=1075359&ysclid=lur7plmx2b728125086
Offline Fungus
« Reply #2580 on: April 08, 2024, 09:20:42 pm »
I can do it with ADB, too, but can you do it without?
Offline mrisco
  • Country: pe
« Reply #2581 on: April 08, 2024, 09:23:11 pm »
There are many options, also "Back button" and "Zone Edge Launcher". I recomend Zone Edge that is what I'm using, this application avoids to change the Rigol launcher.
The following users thanked this post: shapirus
Offline enson72
  • Country: ua
« Reply #2582 on: April 09, 2024, 05:54:51 am »
What does ADB have to do with it? Install the Button Master application, it has a floating button option. Turn it on so that it is displayed on all applications. On the Rigol app as well. And set it up so that by clicking it it sends you to the desktop of the launcher or wherever you need.
Offline mrisco
  • Country: pe
« Reply #2583 on: April 09, 2024, 06:20:51 pm »
I feel that with the app it is easier to see the peaks, what do you think?
« Last Edit: April 09, 2024, 06:26:04 pm by mrisco »
The following users thanked this post: egonotto, AndyBig, NikNik
Offline shapirus
  • Country: ua
« Reply #2584 on: April 09, 2024, 06:44:19 pm »
Yeah that's how it should have been implemented from the start, at least as far as indicating the values right on the peaks goes.
Averaging is nice to have, too.
Offline mrisco
  • Country: pe
« Reply #2585 on: April 09, 2024, 06:54:02 pm »
I uploaded the preview apk temporary here: https://github.com/mriscoc/RIGOL_DHO800_DHO900_GUI/releases/tag/FFTAVG0.3.2
Until I can find a better place.
« Last Edit: April 10, 2024, 01:22:24 am by mrisco »
The following users thanked this post: NikNik
Offline VicthorHW
  • Country: br
« Reply #2586 on: April 10, 2024, 06:11:06 pm »
Hello all, this is my first post on the forum.
I am about to buy my firts digital ociloscope  ;D.
i was about to pull the triger on the DHO814, but i have seen that is possible to hack the DHO804 to basically be a DHO814 (100Mhz BW) and more Memory Depth.
My question is:
Still possible to hack brand news (up to date firmware and software) DHO804 ?
if still possible i will get a DHO804 new, from rigol store on aliexpress.
Another question is:
Is worth to buy the DHO814, does it have any thing else (excluding the bigger bandwith) that the DHO804 dont have ?
Actualy the cost diference betwews the two aren't much, but if they are the same i dont wanna to burn money.
DHO804 -  BRL 2.488,92 - 490 USD
DHO814 -  BRL 2.754,04 - 542 USD
Aliexpress listing say that the 2 models have the same memory depth (25Mpts).
So i probably would do the hack on the DHO814 (if i buy) to get the extra memory depth.
Offline mrisco
  • Country: pe
« Reply #2587 on: April 10, 2024, 06:14:51 pm »
Actualy the cost difference betwews the two aren't much, but if they are the same i dont wanna to burn money.
Check in Alibaba, I bought from them and they sent me the DHO804 for a very good price with DHL shipping included.
The following users thanked this post: VicthorHW
Offline AndyBig
  • Country: ru
« Reply #2588 on: April 10, 2024, 06:43:17 pm »
Yes, you can easily convert your 804 into an 814 and then further increase the memory bandwidth and depth with options.
Offline Fungus
« Reply #2589 on: April 11, 2024, 01:17:29 am »
My question is:
Yes,
No.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2590 on: April 11, 2024, 03:44:47 am »
the price for "DHO814 100MHz" sticker and man hour to upgrade 804 to 814 is worth $52, if you dont want DIY like some people, yes its worth it to get DHO814 ;D
The following users thanked this post: RAPo, VicthorHW
Offline Cees
« Reply #2591 on: April 11, 2024, 02:27:10 pm »
Great job! Is it easy / possible to add a frequency log scale?
Offline mrisco
  • Country: pe
« Reply #2592 on: April 11, 2024, 02:38:53 pm »
I think that it is possible but maybe not easy. Currently the app takes the FFT results from the MATH channel, if I convert to a logarithm scale maybe the plot will lose frequency resolution. Other possible solution is to take the data directly from the acquisition channel (CHn) and do the LFFT calculus inside of the plugin app. If the loss of resolution is acceptable (just visual change of data representation) then it might be easy.
Another possible solution is if the plugin can control the FFT parameters and sweep the frequency range and then stitch the data together, but I haven't explored controlling the oscilloscope from the plugin yet.
« Last Edit: April 11, 2024, 02:54:55 pm by mrisco »
The following users thanked this post: Cees
Offline Cees
« Reply #2593 on: April 11, 2024, 02:59:29 pm »
In most cases ( so far I know) it is just a visual change. A logical consequence will be that the data points in the low range will be further apart.
Offline mrisco
  • Country: pe
« Reply #2594 on: April 11, 2024, 03:05:45 pm »
If you want, I opened a discussion site in the Github to not polute this thread with a specific topic: https://github.com/mriscoc/RIGOL_DHO800_DHO900_GUI/discussions
The following users thanked this post: RAPo, Cees
Offline VicthorHW
  • Country: br
« Reply #2595 on: April 11, 2024, 03:52:09 pm »
First I want to say thanks to: mrisco, AndyBig, Fungus and Mechatrommer for replying my question  :).
I ordered the DHO804 from AliExpress.
The main reason is because "RIGOL Store" on AliExpress actually has some stock already in my country, so I won't need to pay any import fees.
The import fees here are insane; if I have to pay the imports fees, the total cost would be 2x oscilloscopes or more  :-//, and on the local market
(ignoring the AliExpress "RIGOL Store"), the DHO804 cost something around  6500 BRL / 1280 USD
Now I am waiting anxiously to get my new toy  :D
Offline RAPo
« Reply #2596 on: April 13, 2024, 02:03:53 pm »
I really like the app.
Had some time to look into a TCXO 10MHz 0.1ppm module.
Worked out great:
2118395-0
« Last Edit: April 13, 2024, 03:21:59 pm by RAPo »
The following users thanked this post: mrisco, NikNik
Offline Fungus
« Reply #2597 on: April 14, 2024, 06:07:23 am »
Does anybody know if it's possible to make the HDMI output a second screen (not a mirror)?
Offline Slavius
  • Country: ru
« Reply #2598 on: April 17, 2024, 05:13:38 am »
Hello everybody!
I recently purchased a Rigol DHO804 oscilloscope. Everything works fine, I haven’t noticed any bugs yet, but..
This question is: Why do the phases of the signals between channels 1 and 2 diverge? The higher the signal frequency, the greater the discrepancy.
My generator produces a maximum sine wave of 70 MHz, so at 70 MHz the phase difference is 20%, and it doesn’t matter between which channels, between 1 and 2, between 1 and 3, between 1 and 4!
But a nuance was noticed that between 2 and 3, 3 and 4, 2 and 4 channels there is no such phase discrepancy, only relative to 1 channel and any other.
Can someone check on their oscillation whether this is the same nonsense or not?
p.s. Activated 50 MB of memory and 100 MHz frequency.
Offline ebastler
« Reply #2599 on: April 17, 2024, 06:12:39 am »
I assume what you are observing is "channel skew". There may be variations in the time a signal takes to travel through the scope's front end, due to parts tolerances. It is an approximately constant time offset per channel. In your scope, channel 1 seems to be different from the others by about 3 ns (20% of a signal period at 70 MHz).
You can adjust these skews in the scope software. See section 5.11 of the manual. The adjustment range is -100 to + 100 ns, so your 3 ns skew is easily within the range.
Before you do that, let the scope warm up for at least 30 minutes, and then run a self-calibration (section 21.6 of the manual). Then check the skew again and adjust in the software dialog as needed.
Edit: This thread is specifically about hacking (modifying) the scope hardware & firmware. For general discussions and questions, I think the following thread is the better choice: https://www.eevblog.com/forum/testgear/rigols-new-dho800-oscilloscope-unbox-teardown/
« Last Edit: April 17, 2024, 06:32:33 am by ebastler »
The following users thanked this post: ebourg, NikNik
