Author Topic: Hacking the Rigol DHO800/900 Scope  (Read 1940735 times)
Offline AndyBig
  • Country: ru
Re: Hacking the Rigol DHO800/900 Scope
« Reply #3450 on: February 04, 2025, 09:24:52 pm »
I think 1.4 GSa/s or 1.6 GSa/s is more real limit of overclocking FPGA and DDR3 memory.
I think that raising the clock of the FPGA even by 10-15% will be problematic.
That is, maybe some oscilloscopes will work, but it is unlikely that it will be stable.
Online Fungus
« Reply #3451 on: February 04, 2025, 10:00:36 pm »
The DHO8/9 and DHO1000 hardware looks the same, but the DHO1000 is 2GSa/s and the DHO8/9 is only 1.25GSa/s, so it would be nice to switch to 2GSa/s sampling as well
It's not just the ADCs, it's the FPGA, the RAM, many dozens of places in the firmware that do math based on the sample rate, etc.
The following users thanked this post: AndyBig
Offline AndyBig
  • Country: ru
« Reply #3452 on: February 04, 2025, 11:04:33 pm »
It is enough that the 1000 and 800/900 have completely different FPGAs. This immediately puts an end to any analogies between these oscilloscope lines.
The following users thanked this post: Fungus
Offline LEER333
  • Country: hk
    • www.qq.com
« Reply #3453 on: February 05, 2025, 02:38:32 am »
The main reason is that the FPGA configuration has been reduced. thank you
Offline mrisco
  • Country: pe
    • Github repo
« Reply #3454 on: February 07, 2025, 06:19:12 am »
Next version will have a docked result panel (can be undocked to the former view) and a surprise I can overcome all obstacles
DHO800-900 Extended UI: https://youtu.be/mT4ivaMY7zg
The following users thanked this post: AndyBig, zelectronicauy
Offline shapirus
  • Country: ua
« Reply #3455 on: February 07, 2025, 10:58:45 am »
I wonder if it's feasible to make it display the math traces in the main window.
Offline mrisco
  • Country: pe
    • Github repo
« Reply #3456 on: February 07, 2025, 02:15:17 pm »
I try to do it, but there is a lot of changes to do in the apk and maybe the precompiled binary library draws inside of a window with a predefined id. In other models that is possible, but fight with a binary library may not be worth it.
Offline RAPo
« Reply #3457 on: February 07, 2025, 02:48:15 pm »
@mrisco and @AndyBig,
Both of you are making this scope so much better, thanks for that.
My question is: are you two joining forces, because I sure would like to see all your great adaptions in one package!
The following users thanked this post: AndyBig, mrisco
Online Fungus
« Reply #3458 on: February 07, 2025, 04:42:01 pm »
I think that would be very difficult. You might even need to have the math window open anyway to be able to put the trace in a different window.
Offline mrisco
  • Country: pe
    • Github repo
« Reply #3459 on: February 07, 2025, 04:54:51 pm »
I could open the window and hide it, but the problem is the trace drawing itself.
Offline iMo
  • Country: li
« Reply #3460 on: February 08, 2025, 08:50:51 am »
FYI - 804 modded to 824, no selfcal after mod.
50ohm terminator on CH4.
Waveform view.
BW OFF       49.4uV Avg. AC.RMS  (+12uV against 804)
BW 20MHz   24.1uV Avg. AC.RMS  (the same as the 804)
« Last Edit: February 08, 2025, 08:53:21 am by iMo »
Offline AndyBig
  • Country: ru
« Reply #3461 on: February 08, 2025, 08:57:47 am »
Of course, because the bandwidth has expanded almost 3 times :)
Offline iMo
  • Country: li
« Reply #3462 on: February 08, 2025, 09:02:24 am »
Yep, the noise looks ok.
The model is 824 and time base 2ns.
BUT - I still see only 25M mem depth and the options - see below.
What went wrong?
vendor.bin generated by -o -M DHO824
Offline AndyBig
  • Country: ru
« Reply #3463 on: February 08, 2025, 09:07:34 am »
What went wrong?
This is because you have two channels active - channel 2 serves the trigger and channel 4 shows the signal.
Offline iMo
  • Country: li
« Reply #3464 on: February 08, 2025, 09:12:00 am »
The same with trigger at the same channel.. 25MB max..
OK, the counter and measurement on a diff channel have to be OFF, and I get 50MB..  ::)
What about the options? Is that ok?
PS: why the counter enabled on a different channel limits the max mem depth ?  :o
« Last Edit: February 08, 2025, 09:20:11 am by iMo »
Offline AndyBig
  • Country: ru
« Reply #3465 on: February 08, 2025, 09:22:08 am »
Yes :)
PS: why the counter on a different channel limits the max mem depth ?  :o
Any access to the channel puts it into full operation, so it takes both the sampling frequency and memory.
Offline AndyBig
  • Country: ru
« Reply #3466 on: February 08, 2025, 09:25:01 am »
mrisco and I have incompatible economic models :))
The following users thanked this post: RAPo, norbert.kiszka
Offline iMo
  • Country: li
« Reply #3467 on: February 08, 2025, 09:28:12 am »
Hmm, a weird design.. - their counter looks like a 6digit counter gated by 1sec (perhaps 10 lines in verilog). Has nothing to do with sampling into the mem. Looks like a bug to me..
Offline AndyBig
  • Country: ru
« Reply #3468 on: February 08, 2025, 09:34:21 am »
It seems to me that all operations on the channel - trigger, counter, measurements, etc. - are carried out programmatically based on the ADC readings accumulated in memory.
I agree that this is not the best solution, but apparently they did it this way to reduce the cost of the oscilloscope.
Offline RAPo
« Reply #3469 on: February 08, 2025, 09:51:32 am »
I was afraid of that answer.
So now I have a decision to make ....
Offline mrisco
  • Country: pe
    • Github repo
« Reply #3470 on: February 08, 2025, 03:17:21 pm »
Waveform view.
When I see the original interface of the DHO, I wonder what happened in the UI design engineering team to release that result bar layout!
It is not to continue the layout of the other models because, for the DHO1000/4000 series it is different (due to the bigger screen) so it is only laziness to adapt the UI properly to a lower resolution.
Let's see, this is with the stock application:
And this is with the extended layout:
In the promotional pictures of the DHO800 series, the result bar had a better layout and was docked to the right:
« Last Edit: February 08, 2025, 03:36:00 pm by mrisco »
Offline mawyatt
« Reply #3471 on: February 08, 2025, 05:54:41 pm »
We are attempting to use the DHO814 for Transistor Curve Tracer utilizing the XY Mode. Really like the display that includes the X and Y numeric labels, but can't get the display to show enough brightness in XY mode (we have brightness set to max), it's fine in regular Time Domain mode tho.
The results are very faint as shown.
The setup is an AWG used to sweep (0-8V) the X Axis thru a Resistor (Collector 100Ω) and the DSO CH1 connects to Resistor, the AWG other channel is stair-stepped (8 Steps 0-10V) thru a Resistor (Base 50KΩ). Another Resistor (Emitter 10Ω) and DSO CH2 is connected across this resistor to display Current on the Y Axis.
You can see the Siglent DSO displays the result with good brightness while the DHO814 we can't get to display with sufficient brightness.
BTW wish the Siglent would include the XY display numerics like the Rigol, they are nice :-+
Any help is from the Rigol gurus is appreciated.
Best
~Wyatt Labs by Mike~
Online Fungus
« Reply #3472 on: February 08, 2025, 06:51:46 pm »
Turn up the persistence?
Offline mawyatt
« Reply #3473 on: February 08, 2025, 07:04:17 pm »
First thing we tried, makes no difference in XY Mode, but does work in normal TD Mode?
Best
Offline AndyBig
  • Country: ru
« Reply #3474 on: February 08, 2025, 07:33:34 pm »
Honestly, I like the measurement panel on top of the signal window better. When it doesn't make the signal window shrink :)
