(After that we'd want an app to configure the user interface options without editing those pesky JSON files. )
Can the scrollable button panel at top right be edited? It would be cool to be able to just replace it with one or two items that don't have a physical button on the front (eg. "decode").
:BUS1:MODE SPI /*Sets the decoding type to SPI.*/
There is the bug with the display brightness as well - it always starts 100%.
Fixed Rigol's bugs with trigger mode icons and added horizontal scale and trigger mode to the full-screen info panel
Like this very much. Thanks.Can some ogf the acquire settings (mode, mem depth) also be added to this bar?
Quote from: RAPo on February 16, 2025, 02:51:07 pmLike this very much. Thanks.Can some ogf the acquire settings (mode, mem depth) also be added to this bar?...or on the title bar at the top, next to the graphics that shows you how much you can zoom.(there's enough numbers at the bottom now to have to scan through to pick one out)
Release of a new version of the modification (a007) - https://github.com/Andy-Big/Rigol-DHO800-900-Sparrow_mod/releases/tag/a007_00.01.04.00.02
Question, after installing your version do we need to re-do the FFT flat-top calibration?
Yep, I know, it was handled here in past afaik, but for me - as the user - it is a bug.. When I set it 60% it gets 100% after the restart.. The same: the time zone (enabling time/date), the flattop window coeffs, etc. So perhaps the experts here may create an "automatic process/script" which will handle all those "bugs".
What if you set a move complex trigger mode, eg. Serial triggers. Does it all fit?
Hello God, I would like to ask a question, that is, how to display the time on the screenshot, in addition, how to set the time, in the case of not networking, the switch will not reset the time, my model is DHO804
Whats going on with this zero? It looks, as it is a bit more than zero.
There is no RTC module inside this machine?
