@Retired2:
Did you have used my additional instructions according to Reply #3226 or the original instructions according to Reply #2981 by user "BTO"?
Because it seams you don't use the extention "“--model <your_desired_model>”.
If you have followed my additional instructions in Reply #3226,
please read
ALL the instructions I wrote in Reply #3226!
I wrote:
"For
Step 5 the python script "
Rigol_MSO_LicensingUtility_2.10b.py" was used."
and
Step 5 with “rigol_mso_util_2.13b.py” with and without the extension “--model <your_desired_model>”
does not work."
Reboot the device two times.
Set it to default"
Check the IP address. After restarting, the device may be assigned a new IP address."
#5 -> reactivate licenses
python
Rigol_MSO_LicensingUtility_2.10b.py --regen <rigol_ip_address>
All options are activated.
The oscilloscope with options seems to be functioning properly.
Hint:
Be carefull.
I couldn't find any instructions on how to reinstall the backup files on the Oszi (means NAND, dump, ...)
(and no command instructions in the Python script either)."
(That was my process!)
For Step 5 you have used "rigol_mso_util_2.13b.py"!
I also received error messages with the version “rigol_mso_util_2.13b.py”.
However, my oscilloscope was already at 500 MHz from step 4 onwards, but without any options.
I therefore suspect that the error lies further up.
I don't know why your oscilloscope is still set to 350MHz.
I have issues: NO Model shown in Web Control screen , Cannot login to Web Control with default Login / password but can use VNC viewer.
I mean, this topic is described in this chat.
I also mean that there is no solution for it.
