Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 925990 times)
Wong and 10 Guests are viewing this topic.
Offline TopLoser
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #575 on: January 08, 2019, 12:21:49 pm »
Somebody asked me to post a photo of my 'system information' screen.
Were you a beta tester???   :-DD
I built it from kit form, after it had been totally dismantled and various IC's removed for 'QC' inspection  ;)
« Last Edit: January 08, 2019, 12:29:07 pm by TopLoser »
Offline oliv3r
    • Rigol related stuff!
« Reply #576 on: January 08, 2019, 08:56:47 pm »
Back on page 10 was it? Vtech made an excellent post finding out a lot of the cool chips with Dave's video.
I figured, we need a pic and some more text to go with that. But not any ol'e pic. I took the front and back pictures from Dave's teardown, and overlayed them. Then made the bottom 50% transparant allowing us to see a little bit more what's going on :)
For more information (what the colors mean etc) see https://gitlab.com/riglol/rigolee/wikis/MSO5000-teardown
Edit: Also did the keyboard
For more information see https://gitlab.com/riglol/rigolee/wikis/MSO5000-teardown
« Last Edit: January 08, 2019, 10:07:04 pm by oliv3r »
The following users thanked this post: Vtech, klaus11, tcottle, sparkv
Offline helmy
  • Country: eg
« Reply #577 on: January 09, 2019, 09:55:05 am »
Did anyone try to make their own (PLA2216) logic probe for cheap, considering it is priced at $400!
Offline TopLoser
« Reply #578 on: January 09, 2019, 09:58:19 am »
https://www.eevblog.com/forum/testgear/rpl1116-active-logic-probe-pod-for-1000z-series-teardown/
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #579 on: January 09, 2019, 09:58:25 am »
Should be easy enough as it's just a bunch of ECL comparators.  Probably just a matter of time before they show up on Aliexpress
Day Job: Mostly LEDs
Offline tv84
  • Country: pt
« Reply #580 on: January 09, 2019, 12:35:04 pm »
What does this image show?
(It's a MSO5000 capture, with a 50-ohm termination.)
« Last Edit: January 09, 2019, 02:56:37 pm by tv84 »
Offline thomil
  • Country: at
« Reply #581 on: January 09, 2019, 12:45:04 pm »
350ps fal time? 1GHz bandwidth?
Offline Fungus
« Reply #582 on: January 09, 2019, 12:51:54 pm »
It's displaying a pulse that's approx. 1ns.
Offline johnmx
  • Country: pt
« Reply #583 on: January 09, 2019, 01:23:24 pm »
What is your signal source?
It would be interesting to see the same response using a 50 Ohm terminator at the scope input.
E.g. something like this may prevent oscillations at higher frequencies:
https://www.picotech.com/accessories/bnc-terminators-leads/50r-terminator-bnc
Best regards,
johnmx
Offline Fungus
« Reply #584 on: January 09, 2019, 03:42:14 pm »
It's a transistor catching fire?
Offline tv84
  • Country: pt
« Reply #585 on: January 09, 2019, 04:19:12 pm »
We are almost OT but I would like to see if you guys confirm that this can be used as proof of the claims that were made a few weeks ago...
BTW, Fungus, can you recreate this with your (any) scope?
Offline iMo
  • Country: pm
  • It's important to try new things..
« Reply #586 on: January 09, 2019, 04:21:41 pm »
The rise time is important with that test, afaik.
BW=350/0.44=795MHz
Offline Fungus
« Reply #587 on: January 09, 2019, 05:44:57 pm »
I haven't got a 90V DC supply. Mine only goes up to 30V.
(I assume that applying 90V to that transistor is bad, hence my comment)
Offline Noy
« Reply #588 on: January 09, 2019, 06:27:38 pm »
Fungus searching for "Avalanche Pulser" then you will know what it is.
And that 90V ist OK for an Avalanche Transistor...
Offline TurboTom
« Reply #589 on: January 09, 2019, 06:59:39 pm »
Btw, that resistance in series with the power supply is MegOhm, not milliOhm as the schematic may suggest...  ;)
Offline johnmx
  • Country: pt
« Reply #590 on: January 09, 2019, 07:08:22 pm »
I wonder if the oscillations are from the circuit itself instead of the impedance mismatch of the scope input stage
Best regards,
johnmx
Offline tcottle
« Reply #591 on: January 09, 2019, 07:15:16 pm »
http://www.eevblog.com/2012/07/06/eevblog-306-jim-williams-pulse-generator/
Offline rgwan
« Reply #592 on: January 10, 2019, 05:54:11 am »
The frontend of this scope has very poor S11 performance, measured by KC901 VNA. Although we added a 50-ohm terminator to its input, S11 curve above 350MHz still looks terrible. We have swept this scope by HP 8657 generator, usable bandwidth is around 380MHz. Maybe the internal match network on AFE's output line limited the bandwidth and the input circuit isn't capable of high-frequency usage (because of such high S11).
« Last Edit: January 10, 2019, 05:57:38 am by rgwan »
Offline TheSteve
  • Living the Dream
« Reply #593 on: January 10, 2019, 06:02:18 am »
Did you calibrate the KC901V to remove the cable effects?
Have you checked the return loss of the terminator itself?
Can you run it with a lower max frequency as anything above 500 MHz/ 1 GHz is likely meaningless.
Lastly many scopes 50 ohm inputs are only rated to have an SWR of 1.5:1 or better - that is only 14 dB of return loss.
VE7FM
Offline rgwan
« Reply #594 on: January 10, 2019, 06:20:07 am »
1、Yes.
2、Of course.
3、I have done it, it doesn't look good... Almost the same result as this. Below 350MHz it is fine though, but in 350MHz-1GHz, if you don't do some hardware modification, it is not as good as the calculated bandwidth that the pulse response result shown by tv84. I have returned home for winter vacation, about 1 month or so I can't do any measurement for this scope (because I haven't equipment to measure at home) ...
« Last Edit: January 10, 2019, 07:46:22 am by rgwan »
Offline TheSteve
  • Living the Dream
« Reply #595 on: January 10, 2019, 06:41:40 am »
I don't think you're seeing any problem with the scope, it is just the nature of trying to use a 50 ohm feed through connected to the 1 meg-ohm input of a scope. A scope with a 50 ohm internal path is optimized for such things. Using a feed-through will only match a proper 50 ohm input at very low frequencies.
Here is an example of what my Keysight scope looks like with its native 50 ohm input, and then using a 50 ohm feed-through with the scope input back at 1 meg-ohm. It looks absolutely horrible using the feed-through. The third shot is the 50 ohm feed-through on its own just for reference.
VE7FM
Offline rgwan
« Reply #596 on: January 10, 2019, 07:24:27 am »
I mean this scope is not designed for testing above 350MHz signal. It just not perform well and maybe it needs some hardware modification to make use of the high sample rate.
Offline 2N3055
  • Country: hr
« Reply #597 on: January 10, 2019, 08:03:25 am »
You cannot just hack it.. For higher frequencies you need to use 50 OHm path, and that has to exist in the scope from input connector to A/D converter. It has to be controlled impedance layout.
Basically, it has to exist as separate part of PCB made for just that purpose that is just not there on MSO5000 board.
Chipset and front end chip in MSO7000 and MSO5000 is identical and capable of same bandwidth (frontend chipset is capable of few GHz actually). It's just that your signal from input BNC cannot get to it without being destroyed.
For a scope of this class it is more important that it has good 300 MHz with good signal integrity(which is a miracle itself), that hacking it to 1GHz with distorted signal. You get worse scope actually, and much more noise...
Offline rgwan
« Reply #598 on: January 10, 2019, 08:11:59 am »
Yes, that is actually what I mean. To make use of the high sample rate isn't easy.
« Last Edit: January 10, 2019, 08:13:43 am by rgwan »
Offline PA0PBZ
« Reply #599 on: January 10, 2019, 08:31:19 am »
Can you explain why above 800MHz the feedthrough + scope seems better than the feedthrough alone? Is the feedthrough not made for frequencies above 500MHz or something like that?
