Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 381683 times)
Offline tv84
  • Country: pt
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #800 on: March 01, 2019, 10:00:27 am »
Yes, you should reenable the daemon via the config file.
Yes, it's easily patchable (from here to eternity...). Just recreate the GEL and fire away.
I assume that anyone doing  this kind of task uses IDA.
Offline mabl
« Reply #801 on: March 01, 2019, 10:02:45 am »
I'm not sure how to start it though. The start command is close to other UI stuff, and the string "Enter Project mode" is used close to it. I could imagine there is something like a maintanance menu we don't know about yet.
Notice, that rigol/resource/menu/msg.h defines a rather complete set of command messages. Say for example
#define MSG_HISTO_STATISEN      17670
For example rigol/resource/scpi/HISTogram.xml
<TotalItem>
<head>^(:?HISTogram|:?HIST)(:STATic|:STAT)\?$</head>
<service>histo</service>
<cmd>17670</cmd>
<minSize>-1</minSize>
<indexes>
<i>1</i>
</indexes>
<unit>
</unit>
</TotalItem>
One of these codes is
#define MSG_APP_UTILITY_PROJECT               12073
which is unfortunately not mapped, but might be somewhere in appEntry.
Online Fungus
« Reply #802 on: March 01, 2019, 10:27:58 am »
I believe you are right. I did not notice earlier, but rootfs/etc/init.d/rcS was modified such that sshd is not run.
-/usr/sbin/sshd
+#/usr/sbin/sshd
So we just unpack the GEL, edit that file, repack it, back to business as usual?  :)
« Last Edit: March 01, 2019, 12:04:17 pm by Fungus »
Offline mabl
« Reply #803 on: March 01, 2019, 10:50:28 am »
I would guess so. Still waiting for the scope to be delivered. You can also use oliv3r's packer I think: https://gitlab.com/riglol/rigolee/#gel-packer
But I'm not sure if this is tested at all.
Offline piskers
« Reply #804 on: March 01, 2019, 11:06:39 am »
Welcome! May I ask what tools you use for disassembly?
Thank you! I'm using Binary Ninja right now.
I believe the license checking function is at 0x0041801c. It seems to set r0 to #0x1 if the user owns the requested license.
At least that's what the -fullopt flag did in the previous versions.
Online Fungus
« Reply #805 on: March 01, 2019, 11:16:00 am »
It should be easy to mod that to "ld r0,#1; ret;" (or whatever the local assembly language is) to get all options.
Hacking an MSO5000 would then be as easy as inserting a USB stick and pressing "OK".
Offline tv84
  • Country: pt
« Reply #806 on: March 01, 2019, 11:34:17 am »
If there is any packer that works, it's this one! Older ones will not work because this .GEL is completely different.
Offline mabl
« Reply #807 on: March 01, 2019, 12:24:36 pm »
Thanks for the hint, that is indeed a nice tool! I believe you are right and it makes it is super easy to patch it such that it only ever returns 1.  :-+
Patch for 01.01.04.04 to always return 1
Superseeded by later work.
EDIT: Just got my scope from Batronix. Comes with firmware 00.01.01.02.03. I would have expected them to ship with the new "unhackable" firmware. However, ,aybe they did not want everyone to return them directly.  :-//
EDIT2:  I tried an intermediate update to 00.01.01.02.06, and now ssh is gone?! Strange....
EDIT3: Darn, that firmware also already kills sshd, even though it is from December last year! So I effectively shut myself out for now. BTW, the build script is not far enought to repackage the modified file system.
« Last Edit: March 13, 2019, 07:15:18 pm by mabl »
Offline piskers
« Reply #808 on: March 01, 2019, 02:26:25 pm »
Yes, 00.01.01.02.06 was the first version having the the start of the ssh daemon commited away in /etc/init.d/rcS
You could try an earlier version or be the first person to try oliv3r's packer  :D
Or did someone already test the packaging function?
EDIT: Oh okay, I guess downgrading is not possible?
« Last Edit: March 01, 2019, 02:29:51 pm by piskers »
Offline mabl
« Reply #809 on: March 01, 2019, 02:31:26 pm »
 |O Anyways. I don't know if downgrading is a good idea with calibration data and such. I think i also saw a check against it in fw4linux.sh.
oliv3r's packer will only do the firmware flash encryption (so i could batch out the downgrade stop). It will not generate the image files etc.
Offline tv84
  • Country: pt
« Reply #810 on: March 01, 2019, 03:00:18 pm »
Why downgrade??? Don't you want to upgrade with a hacked version?
Worry about repacking the new GEL and your problems will be over.
Since none of these versions change the bootloader, you can do all the harm that you want and there will always be a safe exit.
Offline mabl
« Reply #811 on: March 01, 2019, 03:08:08 pm »
I wanted to first backup the calibration data. I have patched 01.01.02.04 such that it will downgrade now. I'm back in  :scared:
@Oliv3r, I had to add --owner=rigolee --group=rigolee to the tar commands.
Offline piskers
« Reply #812 on: March 01, 2019, 03:16:13 pm »
congratulation  :D
So next step is to pack the rootfs/rigol folder as an UBIFS image
Offline mabl
« Reply #813 on: March 01, 2019, 03:22:59 pm »
congratulation  :D
In fact I just did the quivalent patch to the old appEntry as mentioned before  - and behold, all features are there without -fullopt  :popcorn: :-DD  Many thanks go to piskers for finding the function and pointing me to the right direction.
EDIT2:
Now it looks alright too  :-DD See attached image.
« Last Edit: March 01, 2019, 03:31:36 pm by mabl »
Offline piskers
« Reply #814 on: March 01, 2019, 03:41:47 pm »
Very nice job!!  :-DD :-DD :popcorn:
Did you change anything else for the licenses to also appear in the options list?
Btw, the appEntry also seems to have support for (jitter) eye diagrams..
Offline mabl
« Reply #815 on: March 01, 2019, 03:48:43 pm »
I just changed the option list view  to always show forever ;D. Easy to find when looking for "Forever". So its just a visual thingy. I also noticed eye diagrams, but I thought it is just that different color scheme.
A patch for the current version, which makes it look and feel like full options. Obviously untested until we can pack the GEL files:
superseded by later work
EDIT: Note, that there is also a BW07T5 option in the file, while the highest option shown is BW07T3....
« Last Edit: March 13, 2019, 07:15:49 pm by mabl »
Online Fungus
« Reply #816 on: March 01, 2019, 04:16:32 pm »
Ummm... isn't that what self-cal is for - to generate some new data?  :popcorn:
Online Fungus
« Reply #817 on: March 01, 2019, 04:20:06 pm »
This means hacking is now as easy as inserting a USB key and pressing "Go!" (or whatever it says on screen).
No need to mess around with SSH or Vi.
And an easy way to de-hack it if it ever has to go back under warranty.  :)
« Last Edit: March 01, 2019, 04:22:01 pm by Fungus »
Offline mabl
« Reply #818 on: March 01, 2019, 05:39:51 pm »
Once we can create the update files. I'm not the best in shell scripts, so somebody else might be faster. Oliv3r?
That actually true? I was not aware we can run the u-boot flash script without soldering, can we? Also, it flashes the current version numbers into u-boot configuration, which we can obviously disable for our package.
Offline piskers
« Reply #819 on: March 01, 2019, 06:03:47 pm »
Could someone run
mtdinfo /dev/mtd0 on the device so that we know the parameters for packing of the UBI image?
EDIT: Actually /dev/mtd6 and /dev/mtd10 just to be sure
« Last Edit: March 01, 2019, 06:08:08 pm by piskers »
Offline mabl
« Reply #820 on: March 01, 2019, 06:39:46 pm »
Could someone run
Sure, if it existed... Need to find some binary first....
EDIT:
Used an arml library from debian.
<root@rigol>/user/mtdinfo  --all --ubi-info
Count of MTD devices:           13
Present MTD devices:            mtd0, mtd1, mtd2, mtd3, mtd4, mtd5, mtd6, mtd7, mtd8, mtd9, mtd10, mtd11, mtd12
Sysfs interface supported:      yes
mtd0
Type:                           nand
Eraseblock size:                131072 bytes, 128.0 KiB
Amount of eraseblocks:          2 (262144 bytes, 256.0 KiB)
Minimum input/output unit size: 2048 bytes
Sub-page size:                  2048 bytes
OOB size:                       64 bytes
Character device major/minor:   90:0
Bad blocks are allowed:         true
Device is writable:             true
Default UBI VID header offset:  2048
Default UBI data offset:        4096
Default UBI LEB size:           126976 bytes, 124.0 KiB
Maximum UBI volumes count:      128
mtd1
Type:                           nand
Amount of eraseblocks:          512 (67108864 bytes, 64.0 MiB)
OOB size:                       64 bytes
Character device major/minor:   90:2
mtd2
Type:                           nand
Amount of eraseblocks:          32 (4194304 bytes, 4.0 MiB)
OOB size:                       64 bytes
Character device major/minor:   90:4
mtd3
Type:                           nand
OOB size:                       64 bytes
Character device major/minor:   90:6
mtd4
Type:                           nand
Amount of eraseblocks:          64 (8388608 bytes, 8.0 MiB)
OOB size:                       64 bytes
Character device major/minor:   90:8
mtd5
Type:                           nand
Amount of eraseblocks:          256 (33554432 bytes, 32.0 MiB)
OOB size:                       64 bytes
Character device major/minor:   90:10
mtd6
Type:                           nand
Amount of eraseblocks:          800 (104857600 bytes, 100.0 MiB)
OOB size:                       64 bytes
Character device major/minor:   90:12
mtd7
Type:                           nand
OOB size:                       64 bytes
Character device major/minor:   90:14
mtd8
Type:                           nand
OOB size:                       64 bytes
Character device major/minor:   90:16
mtd9
Type:                           nand
OOB size:                       64 bytes
Character device major/minor:   90:18
mtd10
Type:                           nand
OOB size:                       64 bytes
Character device major/minor:   90:20
mtd11
Type:                           nand
Amount of eraseblocks:          536 (70254592 bytes, 67.0 MiB)
OOB size:                       64 bytes
Character device major/minor:   90:22
mtd12
Type:                           nand
Amount of eraseblocks:          4800 (629145600 bytes, 600.0 MiB)
OOB size:                       64 bytes
Character device major/minor:   90:24
EDIT2: Rerun with --ubi-info
« Last Edit: March 01, 2019, 06:49:58 pm by mabl »
Offline piskers
« Reply #821 on: March 01, 2019, 07:20:51 pm »
Thank you!
So packaging should be possible with:
mkfs.ubifs -m 2048 -e 128KiB -c 800 -r /rootfs/rigol app.imgNot sure about the compression type (-x param)..
Then gzip it and run oliv3r's script. Can't try it till tomorrow though..
Offline mabl
« Reply #822 on: March 01, 2019, 07:33:35 pm »
Thanks! There is also https://github.com/jrspruitt/ubi_reader which claims to be able to provide the proper information based on the image.
This results in:
ubireader_utils_info app.img
Volume app
        alignment       -a 1
        default_compr   -x lzo
        fanout          -f 8
        image_seq       -Q 329026723
        key_hash        -k r5
        leb_size        -e 126976
        log_lebs        -l 5
        max_bud_bytes   -j 8388608
        max_leb_cnt     -c 825
        min_io_size     -m 2048
        name            -N app
        orph_lebs       -p 1
        peb_size        -p 131072
        sub_page_size   -s 2048
        version         -x 1
        vid_hdr_offset  -O 2048
        vol_id          -n 0
        #ubinize.ini#
        [app]
        vol_name=app
        vol_size=98660352
        vol_flags=autoresize
        vol_type=dynamic
        vol_alignment=1
        vol_id=0
Which they claim maps to
/usr/sbin/mkfs.ubifs -m 2048 -e 126976 -c 825 -x lzo -f 8 -k r5 -p 1 -l 5 -r $1 img-329026723_0.ubifs
/usr/sbin/ubinize -p 131072 -m 2048 -O 2048 -s 2048 -x 1 -Q 329026723 -o img-329026723.ubi img-329026723.ini
Offline mabl
« Reply #823 on: March 01, 2019, 08:31:24 pm »
The attached fill looks like an update but just executes sshd  :scared:
So it will enable SSH on all scopes, but will never break anything.
Forum does not allow GEL, so remove the .txt file ending.
EDIT: Note, it will look like the upgrade failed, but no worries you will have ssh. The change is not permanent and ssh will be gone after reboot.
« Last Edit: March 04, 2019, 05:56:07 am by mabl »
The following users thanked this post: dren.dk, KeBeNe, testmode, luma, Shodge, NoisyBoy, db6178
Offline mabl
« Reply #824 on: March 01, 2019, 08:45:25 pm »
My previous patch works for the latest firmware  :-DD :scared:
So we could even build a small upgrade script, which checks for the currently installed version, and applies a binary patch to appEntry.  8)
The following users thanked this post: dren.dk, KeBeNe, thm_w
