0 Members and 17 Guests are viewing this topic.
I installed this and it seems to have worked perfectly, with one exception. I cannot get the probe to compensate correctly on channel 1. On the other 3 channels I can get the probe compensated, but Channel 1 has a hump above the peak of the square wave regardless of the probe I use. Is this something wrong with the scope, or something wrong with the hack? Should I roll back to the non-hacked version? I'm not entirely sure how to resolve this.Thanks,Steven
It should be fixed in the next firmware version: https://www.eevblog.com/forum/blog/new-rigol-scope/msg2366808/#msg2366808
Will they allow users change the resistors and honor the factory warranty?
Any word on how they intend to handle existing units with what appears to be a manufacturing/design fault?
I got one MSO5074.I though I can dump many times with high bandwidth for data aquctation.but it's not possible.
If you send it in, it might come back with some new firmware that is not hackable...
