Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 917802 times)
beatman and 10 Guests are viewing this topic.
Offline thm_w
  • Non-expert
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #1100 on: June 10, 2019, 10:22:59 pm »
Dear All,
a little help to a novice: I flashed 01.01.04.04 on my MSO5074 and while I can ping the scope, ssh gives me "connection refused"... anyone has experienced this?
Its mentioned in this thread, SSH is disabled in that FW. You can either patch to enable it, or directly patch the FW for the options and avoid SSH altogether:
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2251401/#msg2251401
Offline w_m0zart@eevblog
« Reply #1101 on: June 13, 2019, 09:34:58 am »
Two weeks ago I ordered at the company batronix an mso5074, which software version 01.01.04.04 on it. After reading through pages 20 to 47 I was confident enough to install the patched firmware. With that the oscilloscope has now all features enabled.
On general remark though about this oscilloscpe, which has nothing to do with the patch, is that the input impedance cannot be switched to 50Ohms. The option is greyed out. Standard is 1MOhm. And we would need to use external feed through terminators to realize this. If someone would need this, the option would be to go for the MSO7000 Series. I have not seen anywhere if someone was able to patch that oscilloscope as well with success.
Offline Sighound36
« Reply #1102 on: June 13, 2019, 09:43:50 am »
You could wait for the DSO 8000 or just use some genuine 50 Ohm terminated BNC adapters that way you would know that the consistency of the measurement you are making will be accurate.
Offline tv84
  • Country: pt
« Reply #1103 on: June 13, 2019, 05:16:20 pm »
Just for the record, mine is HW 01.01.000.
Offline TopLoser
« Reply #1104 on: June 13, 2019, 05:21:13 pm »
Interesting you only have one bandwidth upgrade installed tv84.
How could that have happened?!
Offline tv84
  • Country: pt
« Reply #1105 on: June 13, 2019, 05:27:35 pm »
"One option to rule them all..."  ;)
Offline TopLoser
« Reply #1106 on: June 13, 2019, 05:53:26 pm »
Not a ‘feature’ now then!
Offline Frex
« Reply #1107 on: June 29, 2019, 01:49:52 pm »
Hello all,
First thank to all they have contributed to make the hack possible (then Rigol first of all !  :) ).
I'm a little bit confused in the large amount of pages/posts in the thread and not shure to have found latest right info.
I there a way to have a link on a post with step by step procedure to hack the scope ?
I don't have already order the scope, but plane to do it soon, so i would be ready ! :)
Thanks all.
Frex
(Maybe majors posts about the hack could be linked in the first post of the thread for an easiest acces ? ).
Offline Martin72
  • Testfield Technician
« Reply #1108 on: June 29, 2019, 02:39:28 pm »
Everyone have to search for, there´s nobody who have all the posts in mind by numbers.. ;)
Except me  8)
Procedure
(Joke, have to search for, too)
Offline Frex
« Reply #1109 on: July 01, 2019, 03:51:30 pm »
Thank you ! :)
So i have another question,  is there any MSO5000  owners that had played with histogram analysis ?
It  would be great to look how it perform for measuring phase RMS noise...
I somebody want to try  :D
Frex
Offline texaspyro
« Reply #1110 on: July 07, 2019, 02:41:58 am »
I got in my MSO5000.   Seems to work well.   Mfg date was 20 Feb 2019.  HW 01.00.000  FW 00.01.01.04.04    Screen is nice and bright.  Fan is nice and quiet.
Only complaint is the rubber boots on the probe BNCs.  They like to rotate without turning the BNC shell... makes it a pain to attach / remove the probes.
Offline NoisyBoy
« Reply #1111 on: July 07, 2019, 03:27:29 am »
That's the first thing I replaced, they are very tight and a pain to pull off.
I went with this: https://www.ebay.com/itm/25-BNC-Female-Cap-Plug-Caplugs-Black-Easy-EZ-Pull-New-Protection-Caps-Dust-Cover/121430968091?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
A little loose, but very easy to put on and take off.
Offline texaspyro
« Reply #1112 on: July 07, 2019, 03:35:33 am »
No, I'm talking about the black rubber boots/insulators on the end of the scope probe cables...  not the dust covers on the scope BNC connectors.
Offline TK
« Reply #1113 on: July 07, 2019, 01:11:29 pm »
I think you are not handling them correctly... if you push the probe BNC in (it has a spring mechanism), then rotates very easily.
Offline texaspyro
« Reply #1114 on: July 07, 2019, 05:20:24 pm »
Possibly,  I've only been using scope probes for around 50 years...  :-DD
Removing the probes seems to be the most problematic.
Offline Martin72
« Reply #1115 on: July 07, 2019, 05:48:32 pm »
This thread here is for questions about hacking the 5000, common questions would fit here.
Thankyou !  :)
Offline adras
« Reply #1116 on: July 10, 2019, 12:10:21 am »
Just to make sure I understand correctly. I can upgrade the MSO 5072 to a MSO 5354 with the procedure mentioned in this thread?
Do I also unlock the function generator?
Offline maginnovision
« Reply #1117 on: July 10, 2019, 02:22:07 am »
Yes, you'll just be lacking some probes.
Offline N2tl
« Reply #1118 on: July 13, 2019, 12:21:39 am »
mabl's summary of best practices, with helpful links, worked a treat on a 5074 scope just received from TEquipment. No test signal overshoot noticed, before or after. Hardware shown as 1.0. After patch applied, all options shown as "forever." :-+
Online ebastler
« Reply #1119 on: July 13, 2019, 07:33:03 am »
You are referring to this post, right?
Offline adras
« Reply #1120 on: July 13, 2019, 10:48:55 am »
Thanks for that reply. Got a fully unlocked scope as well now. Gotta make some tests now.
Offline adras
« Reply #1121 on: July 13, 2019, 10:50:18 am »
Looking at the questions from myself and others. How about we add some information into the starting post of this thread? Then we have a central place. Of course it takes some time to keep it up to date, but on the other hands, people wouldn't need to search through the whole thread.
Offline oliv3r
    • Rigol related stuff!
« Reply #1122 on: July 23, 2019, 07:22:26 pm »
Ahh I'm so envious. I so wonder what the differences are between the two hardware revisions. DAAaavveeee tear another one down and compare it for us :D
Offline oliv3r
« Reply #1123 on: July 23, 2019, 07:24:43 pm »
Wish it where so easy, the original author is long gone and awol, and I yet have to receive a pull request on https://gitlab.com/riglol/rigolee or an update on the wiki https://gitlab.com/riglol/rigolee/wikis/home
While I admit I have been tardy (not, just super busy :p) I'll pick up on the subject again once I have more time.
I'm still waiting for someone to share the exact value of the resistor of the uart TX line, so I can solder that :) and I've almost started playing with my FPGA board again, trying to write some code helping to identify the pin used by the uart's RX.
Offline adras
« Reply #1124 on: July 29, 2019, 12:56:47 pm »
I was hoping a moderator could add the stuff with a notification like "Added by moderator" or something.
Besides that, I just ran into a problem.
Starting from today, as soon as I connect the LAN cable and boot up the oscilloscope it stops reacting to any input after around 7 seconds.
  • I tried it a couple of times, without LAN(with internet) connected, the oscilloscope works fine.
  • But WITH LAN connected, it stops reacting to the touch screen, buttons and knobs after around 5-7 seconds.
  • It seems like the oscilloscope is deactivating itself because it checks with a server and figures out it got hacked.
  • It worked fine yesterday.
  • I also disconnected all probes except one which is connected to the test signal. But even without a probe connected I've got the same issue.
I'm using the DS5000Update_01.01.04.04.GEL firmware
Did anybody else notice that?
