Author Topic: Hacking the Rigol MSO5000 series oscilloscopes  (Read 926874 times)
Jaz and 12 Guests are viewing this topic.
Online tv84
  • Country: pt
Re: Hacking the Rigol MSO5000 series oscilloscopes
« Reply #1175 on: August 20, 2019, 08:30:27 am »
I think its pretty certain that the scope phones home everytime it can.
One thing it does in that phone call, i think, is to send a RSA encrypted pack that contains some relevant data from the /data dir. Personal data: keys, licenses,etc
If someone wants to put a wireshark to work we can verify this info.
Mabl, no pissing contest here, but i released the SCPI commands in the general Rigol all SCPI commands thread. I'll try and check with yours.
Online tv84
  • Country: pt
« Reply #1176 on: August 20, 2019, 08:33:22 am »
 Maybe after a successful home call it sets a flag until further changes demand a new phone call or a online update is triggered
Online ebastler
« Reply #1177 on: August 20, 2019, 08:39:17 am »
There is also a non-technical solution to this, which would help to work around the RSA encryption: Since Rigol sell this scope in Europe, they have to adhere to the GDPR data protection/privacy regulations. They can't collect any personal data without informing you about the data they use, the purpose of that exercise, the storage duration etc.. And yes, if they collect a unique identifier like the scope's serial number, and potentially link that back to the buyer via sales records from their distributors, that's personal information.
Could someone who bought the MSO5000 in Europe file an information request with Rigol Europe?
Offline Mr. Scram
  • Display aficionado
« Reply #1178 on: August 20, 2019, 08:44:08 am »
An oscilloscope calling home. Sometimes I hate the era we live in.  :palm:
The following users thanked this post: Fluffhamster
Online tv84
  • Country: pt
« Reply #1179 on: August 20, 2019, 08:49:28 am »
We can also change the key... and the info will be worthless.
Online Fungus
« Reply #1180 on: August 20, 2019, 08:52:09 am »
I dunno about "every time it can" but it looks like it does something at bootup.
Maybe it's just checking for updates. Has anybody seen any sort of "new updates are available" message on one of these?
Tracking how much hacking is going on seems pointless (it's probably in the "90%" region) but that doesn't mean they aren't doing it.
Making the 'scope hang at bootup is a bug though, it needs fixing. A wireshark session would be very informative, if only to figure out what it's doing and how to tweak routers to block it so it boots up as fast as possible.
Online tv84
  • Country: pt
« Reply #1181 on: August 20, 2019, 09:03:11 am »
We can patch out the home calling but i don't appreciate patching very much. Not future proof.  ;)
Offline delfinom
« Reply #1182 on: August 20, 2019, 11:17:37 am »
Thanks delfinom, you rock  :-+
You think perhaps something erroneous got stored in the firmware.xml response file on the affected scopes and that's what caused the hang?  And if so, you think there's a way to copy over a good copy and fix the problem without going through re-patching?  Once the freeze occurs, even the original 04.04 and 04.08 without patch would cause the freeze, that's what leads me to think some erroneous data got stored somewhere.
If not, there's no big deal.  It is easy to re-patch just to remove the phone home "features", especially given how infrequent patches are released.
Again, thanks for all your hard work to look into this matter, it is much appreciated..
A good one won't fix it because it's placed in /tmp which is nuked on reboot. The file itself is most likely not causing it, but rather the http connection going outbound through the great firewall of china.
Well there are two callbacks.
One is definitely an update check, and doesn't send anything other than your scope serial number.
The other is a "upload" function but  it's not set to upload anything that would reveal it's hacked since that is only in appEntry with no file system modifications.
More than likely it's a diagnostic/troubleshooting function. But I can't even find where it's triggered and is most likely not in use.
« Last Edit: August 20, 2019, 11:37:55 am by delfinom »
Offline Mr. Scram
« Reply #1183 on: August 20, 2019, 11:30:59 am »
Having a device in the network independently upload data or being able to do so is definitely a concern.
Online Fungus
« Reply #1184 on: August 20, 2019, 11:50:42 am »
Does it do that during boot, shortly after power-on?
Online NoisyBoy
« Reply #1185 on: August 20, 2019, 02:37:53 pm »
At boot, a few seconds after all the UI are up, after you get the network attached message.  Troubleshooting the bug that froze my scope while it connects to Rigol.com is what made me discover this phone-home behavior.
Offline mabl
« Reply #1186 on: August 20, 2019, 03:34:13 pm »
Oh okay. I did not see or find that thread. It was just a side product of the python wrapper that I'm working on.
EDIT: Found it https://www.eevblog.com/forum/testgear/lists-of-rigol-scpi-commands/
« Last Edit: August 20, 2019, 04:40:43 pm by mabl »
Offline mabl
« Reply #1187 on: August 20, 2019, 04:35:05 pm »
Hmm I still don't get this.
The function at 0x000c4fe4 downloads from  http://www.rigol.com/Support/ProductUpgradeStatue?SN=%1&result=1 to also ask for a firmware.xml.   It downloads the content via HTTP  to /tmp/firmware.xml. For me, currently the downloaded content is
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html>
<head><title>301 Moved Permanently</title></head>
<body bgcolor="white">
<h1>301 Moved Permanently</h1>
<p>The requested resource has been assigned a new permanent URI.</p>
<hr/>Powered by Tengine</body>
</html>
EDIT: Note the typo and the change of URL to what skip reported:
[...]  scope does a regular http (not https) get of "/Support/ProductUpgradeFile?sn=MS5xxxxxxxxxx&hardware=1.0&behaviour=soft&software=00.01.01.02.03 HTTP/1.1".
Function at 0x000c46f4: Triggers on manual update, triggers the dowload of firmware.xml via 0x000c4fe4 via an unclear mechanism. It also generates the hardware/behaviour/software strings for the URI which gets extended to the above URI somewhere. It contains references to http://www.rigol.com/up.aspx?act=%1&filename=%2.dat. with the %1="up". It is unclear when this triggers. It looks like an XML path lookup of "storage/firmware" is involved somehow.
EDIT2: Yep it is XML. It actually loads the URLs from /rigol/resource/dsometa.xml, and these sound far more up-to-date.
<firmware>http://www.rigol.com/Support/ProductUpgradeFile?sn=%1$hardware=%2$behaviour=%3$software=%4</firmware>
<uploadurl>http://www.rigol.com/up.aspx?act=%1$filename=%2</uploadurl>
That upload-url makes me a bit squeezy.
In any case, it fails to parse this firmware.xml, probably due to its wrong content, and fails with "ASSERT: "false" in file cmetanode.cpp, line 121" on stdout. Since appEntry exits, the GUI appears to hang.
I would guess that on some machines, the update check triggers automatically without manual update check, gets a "mal-formed" XML and then appEntry dies. I don't get why my scope doesn't do it however...
The backtrace to 0x000c4fe4 when executing a manual update (after breakpoint at 0x000c46f4 has triggered)
#0  0x000c4fe4 in ?? ()
#1  0xb62fec28 in QMetaObject::activate(QObject*, int, int, void**) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#2  0x000d42e8 in CHttp::sigFinish(QNetworkReply::NetworkError) ()
#3  0x000cf3f0 in ?? ()
#4  0x000cf1bc in ?? ()
#5  0x000d3e88 in ?? ()
#6  0xb62fec28 in QMetaObject::activate(QObject*, int, int, void**) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#7  0xb6630770 in ?? () from target:/rigol/Qt5.5/lib/libQt5Network.so.5
#8  0xb66907b4 in ?? () from target:/rigol/Qt5.5/lib/libQt5Network.so.5
#9  0xb62fc8c4 in QMetaCallEvent::placeMetaCall(QObject*) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#10 0xb630006c in QObject::event(QEvent*) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#11 0xb6bb76e8 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from target:/rigol/Qt5.5/lib/libQt5Widgets.so.5
#12 0xb6bbcccc in QApplication::notify(QObject*, QEvent*) () from target:/rigol/Qt5.5/lib/libQt5Widgets.so.5
#13 0xb62ce5bc in QCoreApplication::notifyInternal(QObject*, QEvent*) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#14 0xb62d151c in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#15 0xb6325ec0 in QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#16 0xb5914ba0 in QUnixEventDispatcherQPA::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from target:/rigol/Qt5.5/plugins/platforms/libqlinuxfb.so
#17 0xb62cc3f0 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#18 0xb62cc81c in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#19 0xb62d43e0 in QCoreApplication::exec() () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#20 0x0004334c in ?? ()
#21 0xb5da7874 in __libc_start_main () from target:/lib/libc.so.6
#22 0x00042d98 in ?? ()
BTW. The backtrace of the assert is the following
#0  0xb5dbfb48 in raise () from target:/lib/libc.so.6
#1  0xb5dc4ed8 in abort () from target:/lib/libc.so.6
#2  0xb60f1018 in QMessageLogger::fatal(char const*, ...) const () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#3  0xb60ec660 in qt_assert(char const*, char const*, int) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#4  0x0087256c in ?? ()
#5  0x0087065c in ?? ()
#6  0x000c5b28 in ?? ()
#7  0x000c50a0 in ?? ()
#8  0x000d2544 in ?? ()
#9  0xb62fec28 in QMetaObject::activate(QObject*, int, int, void**) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#10 0x000d42e8 in CHttp::sigFinish(QNetworkReply::NetworkError) ()
#11 0x000cf3f0 in ?? ()
#12 0x000cf1bc in ?? ()
#13 0x000d3e88 in ?? ()
#14 0xb62fec28 in QMetaObject::activate(QObject*, int, int, void**) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#15 0xb6630770 in ?? () from target:/rigol/Qt5.5/lib/libQt5Network.so.5
#16 0xb66907b4 in ?? () from target:/rigol/Qt5.5/lib/libQt5Network.so.5
#17 0xb62fc8c4 in QMetaCallEvent::placeMetaCall(QObject*) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#18 0xb630006c in QObject::event(QEvent*) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#19 0xb6bb76e8 in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from target:/rigol/Qt5.5/lib/libQt5Widgets.so.5
#20 0xb6bbcccc in QApplication::notify(QObject*, QEvent*) () from target:/rigol/Qt5.5/lib/libQt5Widgets.so.5
#21 0xb62ce5bc in QCoreApplication::notifyInternal(QObject*, QEvent*) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#22 0xb62d151c in QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#23 0xb6325ec0 in QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#24 0xb5914ba0 in QUnixEventDispatcherQPA::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from target:/rigol/Qt5.5/plugins/platforms/libqlinuxfb.so
#25 0xb62cc3f0 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#26 0xb62cc81c in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#27 0xb62d43e0 in QCoreApplication::exec() () from target:/rigol/Qt5.5/lib/libQt5Core.so.5
#28 0x0004334c in ?? ()
--Type <RET> for more, q to quit, c to continue without paging--
#29 0xb5da7874 in __libc_start_main () from target:/lib/libc.so.6
#30 0x00042d98 in ?? ()
Where 0x000c5b28 is inside the firmware.xml parser at 0x000c5aac, which extracts firmware comments, version and url for download.
« Last Edit: August 20, 2019, 07:50:35 pm by mabl »
The following users thanked this post: thm_w, luma, NoisyBoy, whatisthis
Online tv84
  • Country: pt
« Reply #1188 on: August 20, 2019, 06:25:11 pm »
mabl, i think yours isnt dying because the update check isnt being triggered. Or did you try it manually? Mine also doesnt hang when i trigger it manually.
The following users thanked this post: NoisyBoy
Offline mabl
« Reply #1189 on: August 20, 2019, 06:27:20 pm »
Mine (firmware 00.01.01.04.08) hangs on manual update trigger, with that wrong content in the firmware.xml.  The old path to download firmware.xml still works though.
Offline delfinom
« Reply #1190 on: August 20, 2019, 06:41:20 pm »
Yea, I triggered it manually and didn't have it die, same exact file contents you have and that same typoed url.
I also wonder if the freeze at bootup has to do with the fact the online update button press is also persisted, if you press the button it greys out, and if you were to reboot the scope, it stays greyed out for some time still.
But I did try and it had no effect on it freezing.
I see you are much further along by running gdb on the scope :P
I am probably just going to leave it at just patching out the http requests and calling it a day. They serve no useful function once you start using the changes.
« Last Edit: August 20, 2019, 06:43:43 pm by delfinom »
Offline mabl
« Reply #1191 on: August 20, 2019, 06:58:17 pm »
Strange.
Oh that was surprisingly simple. I just compiled gdbserver in gdb-7.12 with the xilinx toolchain (attached to this post). On the scope I just run
$ ./gdbserver localhost:30000 /rigol/appEntry -run
And on the client, using a cross-toolchain (gdb version is 8.2, so its is backward compatible) I use
$ arm-linux-gnueabihf-gdb
target remote ip:30000
b *0xaddress
layout asm
c
The following users thanked this post: bveina
Online tv84
  • Country: pt
« Reply #1192 on: August 20, 2019, 07:09:25 pm »
 Can i use IDA Pro as client, mabl?
Offline mabl
« Reply #1193 on: August 20, 2019, 07:13:05 pm »
I do not know, but it looks like it, see https://www.hex-rays.com/products/ida/support/idadoc/1343.shtml.
Unfortunately, Ghidra  does not yet have support. I just used the command line manually.
Online tv84
  • Country: pt
« Reply #1194 on: August 20, 2019, 07:19:07 pm »
That's a PITA. Can you single step, step into, step over? All my previous mso5000 investigations were done with jtag but i dont want to open mine for now...
Of course the specs say IDA work but i wanted full testimony in this particular case.
Thankx for the gdbserver.
Offline mabl
« Reply #1195 on: August 20, 2019, 07:22:25 pm »
I only tried step (command stepi) on gdb and that works. Backtrace (bt) also works. I did not yet try step-over(nexti). I'm no gdb wizard :-D
Offline mabl
« Reply #1196 on: August 20, 2019, 07:41:13 pm »
Interesting. The Power-On state set to "Last" now restores the scope state. I thought that did not work in the last firmware version?  :-+
It looks like the scope writes the current state (a 1K field of memory) approximately every minute to /rigol/data/stat.dat  (independently of the power on state setting).  That mount point has the realtime option:
/dev/ubi1_0 on /rigol/data type ubifs (rw,sync,relatime)
I wonder how long this small ubi partition will survive? And there are the calibration files and licenses on it....
« Last Edit: August 20, 2019, 07:59:49 pm by mabl »
Online tv84
  • Country: pt
« Reply #1197 on: August 20, 2019, 08:03:06 pm »
It's been a long time since I saw that but I have the impression that all those constant writings are in the FRAM copy and not in the NAND.
Online NoisyBoy
« Reply #1198 on: August 20, 2019, 08:04:16 pm »
It is self-healing!
To try out some of the latest finding you have discovered, I removed the firewall rule on my router, plug the scope into the network, and tried to recreate the problem.  Guess what, now the scope boots fine with the LAN attached, and rigol.com no longer blocked.
Not sure if some flags were reset in my scope or something happened on rigol.com end.
One thing I did earlier was booting the scope with the firewall rule in place, when the Online Upgrade button light up, I push it for an online upgrade.  I backed out at the first screen when it asked me to accept the terms and condition.  Not sure if that might have somehow reset the flag, but for now, everything is back to normal.
BTW, the Online Upgrade button lights up whenever the scope is connected to the LAN, it does not matter if it can actually reach the rigol.com site.
On the safe side, I am keeping it off the Internet.  If I need remote control, it will only go on the physically isolated network at my hobby lab.
Offline mabl
« Reply #1199 on: August 20, 2019, 08:05:51 pm »
I hope so... But just by looking at the file modification date suggests it changes repeatedly....
