I finally decided to ask because I risk looking stupid. I have been working with Rigol MSO5074 for a long time. But what I really don't like is that the oscilloscope's probe divider setting is constantly reset. So, before I start working with the oscilloscope, I have to go into the settings of each channel and set the probe divider to 1:10
Yes, there is an option to remember the oscilloscope state and return to it the next power on. In this case, the probe divider setting is saved with other settings, like beam offset, channel Y-amp gain, etc. However, I don't like this. I always like to start from scratch. And I constantly have to set the probe divider to 1:10. This irritates me.
Neither the Rigol DS1054Z nor the Lecroy WaveRunner have this problem, i.e. clean startup for them does not reset the probe divider to 1:1. MSO5074 should not reset the probe divider, but it does!
The question is - did I miss something?
Firstly.. that's not a stupid question.
Secondly. Yes you did miss something
- There is the setting that returns the scope to the previous state upon a new restart (but as you're already aware, this doesn't work that great)
- There is a Method by which you can SAVE SETUP and create custom setups and then load them whenever you want.
it goes like this
FIRST WE CREATE A FOLDER TO STORE ALL THESE SETUP FILE
1. Select STORAGE / DISK / Enter the C Drive / NEW FOLDER
and create a new folder and save it
NOW WE CREATE A SETUP FILE
1. Setup your entire scope the way you want it to be
2. Navigate to INSIDE the folder you just created.
3. then do this...
STORAGE / SAVE SETUP
Change the FILENAME from RigolDSO to something more meaningful
Select SAVE
when you do this it takes a snapshot of your settings and saves it in an .stp File (Setup File)
You can create as many of these files as you like to cater to whatever situation you want to start in
RESTORING THE SETUP YOU NEED
STORAGE / LOAD SETUP
Navigate to the file and select LOAD
You will find this will be very easy to do after 2 or 3 tries
Let me know how that works out for you.
I also didn't like the things you described and then i learned about this and i've had no problems since
