RichardK, I have listed some issues. I was holding back as some of these may already have been solved in your coming binary. If you have a look at the User Manual I posted here
http://jmp.sh/dKax03Q there are some parts in red that are not mentioned below that are easier explained in that way.
I know its always a pain in the backside to get these when busy with a project, I thus apologize in advance! Hope this helps you sort out some glitches a bit easier!
1. If full screen is selected the GUI does not display the menu, tool bar and button bar, only the full graticule and program name area.
Pressing the ESC button returns correctly to smaller display with toolbars and controls panel in view.
Clicking the small top left hand icon and selecting Restore the display is smaller, but no toolbars or controls are shown, you have to right click on the display and select Windows Mode to get your toolbar and controls back.
This happens exactly the same on both Win7 and Win8 on same PC and on another PC running Win7.
Richard is aware of this, but cannot reproduce on his PC.
If anyone else can please test this and report back on this it will help.
2. Autoset is not taking one to best settings option, on every run it changes the Volt/Div to a different value. On the OEM program the Trigger marker is also set to the middle of the Waveform amplitude. Richard was working on this.
3. Trigger Sweep One shot freezes waveform display, shows "Stop" and red led flashes on device. Unable to resume if setting is changed back to Normal or Automatic, but resumes if Factory default is pressed after changing back to Normal or automatic. Pressing Autoset actually also restarts the program after freezing. Richard was looking at this.
4. Print preview screen underlines the words when typing in Notes. Can the underline be removed? Richard was looking at this.
5. Can colors be changed in Print Preview just for the printout?
6. The zoom function cuts off after 19 steps, but the counter can be clicked up into the hundreds without any further response after 19.
7. The XY mode Lissajous pattern offset is in radians, will be changed to degrees and the second pointer which stays horizontal (incorrectly) now will be moved to vertical top. (In hand with Richard)
8. The Horizontal Time/Div ranges from dropdown menu does not compare to the values in the dropdown in the control panel S (seconds) is also after minute instead of before and 5000 sec is max in control dropdown while 500.0S is max in menu dropdown.
9. The OPEN6022BE does not go back to previous settings used when starting it. This is working in the OEM software (Richard has this on his pending list)
10. Display Ch1, CH2 and reference as the square wave from the output lug and Function generator. With Ch1 & Ch2 as source, enable Maths and use A/B and you will get noise pulses of 1V. Now change one of the Sources A or B to Reference wave and see what happens to the Maths channel. Is this correct? Unable to “lock” the Maths wave now it moves around. Reference trigger position has no effect. Select Reference as trigger and all the waves except reference start moving – unable to lock.
11. When displaying a Reference waveform and then selecting Reference as trigger, the trigger name and voltage shows right hand top. Voltage is off the screen if more than 3 numericals at the right top. E.g if the value is Reference 1.36V the “V” is off the screen, this is also present in the OEM software.
12. The OEM software had the date and time displayed at right hand bottom corner, as well as the ”Running” in the left bottom corner. Not displayed in OPEN6022BE.
13. If you Turn off CH1 or 2 it still shows the CH1 =xxxV and TR1= xxxV in bottom left corner. Neither clear nor reset removes this or changes it to 0V, the measurement showed before turning off remains there. OEM software removes these indications completely from the bottom line when turning channel off.
14. OEM software has an Autohide feature for the control panel. Not provided in OPEN6022be yet.
15. On OEM software only the trigger selected and active shows as a trigger marker, the non-active trigger does not show, but OPEN6022BE shows all the triggers whether active or not.
