Author Topic: sigrok with MSO1104Z  (Read 853 times)
Offline Gioreva
« on: April 16, 2017, 04:30:20 pm »
I installed pulseview-NIGHTLY-32bit-static-release-installer.exe for Window.
Already i have UltraSigma, UltraScope ecc.
Sigrok, Connected to Rigol TCP/IP found my device.
It connects, send the commands, changes parameter, start the acquisition, but nothing appair on PC windows.
What can I try ?
Offline Electro Fan
Re: sigrok with MSO1104Z
« Reply #1 on: May 22, 2019, 09:05:30 am »
I know this is a very old/long ago thread but I'm interested in trying what I think the OP was trying....
I understand that Rigol 2000 scopes are supported by Sigrok PulseView but I didn't quite understand how the data is supposed to get from the Rigol scope to PulseView.  After reading this old post is it correct that the scope is connected to a PC via TCP/IP and then PulseView will find and decode the data probed by the Rigol 2000s 2 analog channels?  If this is a yes, any chance Sigrok can take also decode data from a MSO2072A's digital channels too?
