Author Topic: Hantek clamp meters no effect on waveform  (Read 1003 times)
Offline RoverfanTopic starter
« on: March 28, 2021, 11:20:31 pm »
Hi I am newb with oscilloscopes
Delighted to have just taken delivery of a hantek 6074be a few days ago. Got it to display the 1khz waveform no probs...
... When trying to use the hantek amp clamp meters cc65/cc650, the meters have little to no effect on the displayed waveform even when meters are turned off. It has a waveform and the Vrms sometimes shows uV and sometimes mV all by itself
Right now it's showing Ch1:Vrms 6.58mA but moving around, zeroing clamp has no effect (sometimes it does have an effect but only a temporary effect)
Is this user error? Or something else?
Re: Hantek clamp meters no effect on waveform
« Reply #1 on: March 29, 2021, 03:54:12 pm »
Had a measure of the output of the clamp meter cc65 with a multimeter, its definitely not working as it should. It zeros OK but then starts floating immediately . Also it's output is not effected by what it's measuring. The biggest reaction you can get from it is by opening and closing its jaws
Scope is a bit suspect too, if you unplug the clamp meter it continues to show similar readings on the screen
If I'm missing anything please let me know. This is my first time using such equipment
« Last Edit: March 29, 2021, 03:56:48 pm by Roverfan »
« Reply #2 on: March 30, 2021, 08:36:26 pm »
Resolved
In a word User error
Embarrassingly I was not measuring a single conductor wire.
Offline tautech
« Reply #3 on: March 30, 2021, 08:44:32 pm »
 :-DD
You won't do that again !
You can increase the sensitivity of current probes by wrapping the conductor around the head and passing it through the clamp again to double the sensitivity however you need be careful not to overload the current rating of the clamp and damage it.
