Author Topic: Hantek DSO1152S - Wont boot after firmware update  (Read 39089 times)
Offline WanaGoTopic starter
Re: Hantek DSO1152S - Wont boot after firmware update
« Reply #50 on: July 13, 2014, 09:03:04 pm »
Hi Guys
Tinhead - what is the password for the previous update I should try?
111111 doesn't work
Thanks
WanaGo
« Reply #51 on: July 13, 2014, 09:19:53 pm »
regards pictures, thank you very much!. Sure, when you have time you can uplaod higher res somewhere. It would be cool if you would try to check what numbers/name/logo on these ICs in attachement.
Most of the chips have been scrubbed! Thats not cool.
2 places there are smt passives which have been hand reworked and reconfigured with little jumpers etc - mistakes on the PCB I assume. :(
Ill get some photos up shortly, although it doesnt show much
« Reply #52 on: July 13, 2014, 09:22:15 pm »
Actually, all of the chips you pointed to... are scrubbed :S
« Reply #53 on: July 13, 2014, 09:32:46 pm »
Looks like you both will crack it in time.
Fascinating thread, watching with interest.
Think about tidying up later to make it an easy follow for anybody with similar problems.
link to another  :-BROKE Hantek .....a work still in progress.
https://www.eevblog.com/forum/testgear/hantek-dso1200-handheld-dead/msg452374/#msg452374
Avid Rabid Hobbyist
Offline tinhead
« Reply #54 on: July 13, 2014, 09:54:23 pm »
111111 doesn't work
no idea what you doing, but 111111 is for sure proper password.
hmm, so i will try to recognize them from pictures
yeah, that looks bit funny, but as long it works ...
« Reply #55 on: July 13, 2014, 09:58:16 pm »
Booted up the scope this morning via the UART to get into dso.exe
Couldn't extract the up files for the last release as the password didn't work, so I decided to update via the menu system in the dso itself using the up file on the USB Flash, and using the update feature.
That worked fine. Scope is now booting fine.
So yes, definitely something wrong with the last update.
« Reply #56 on: July 13, 2014, 09:59:42 pm »
Hmm deffinitely didnt work for me Tinhead
> gpg -o fw2.tar.tar.gz dso1kb_2.01.1_DSO1152S\(130129.0\).up
gpg: CAST5 encrypted data
gpg: encrypted with 1 passphrase
gpg: block_filter 0x1dbf730: read error (size=12249,a->size=12249)
gpg: [don't know]: invalid packet (ctb=39)
gpg: [don't know]: invalid packet (ctb=07)
gpg: WARNING: message was not integrity protected
gpg: [don't know]: invalid packet (ctb=63)
gpg: block_filter: pending bytes!
Offline tinhead
« Reply #57 on: July 13, 2014, 10:02:46 pm »
dso.exe and English.lan attached, btw. decrypted with 111111. It is the file name, rename these (\ in _ or remove them.
« Last Edit: July 13, 2014, 10:17:01 pm by tinhead »
« Reply #58 on: July 13, 2014, 10:33:52 pm »
Nope, still doesnt like it
> gpg -o fw2.tar.tar.gz dso1kb_2.01.1.up
File `fw2.tar.tar.gz' exists. Overwrite? (y/N) y
gpg: block_filter 0x1da96f0: read error (size=12249,a->size=12249)
Maybe the file is corrupt... ill try again.
« Reply #59 on: July 13, 2014, 10:35:36 pm »
Yup thats what it was. Copied it to my Linux VM again and all ok this time.
Thanks.
Photos coming, uploading.
« Reply #60 on: July 13, 2014, 10:38:28 pm »
Ok here are all the photos I have taken.
Sorry not the best, some are a bit blurry.
Hope you get the gist.
Hantek Scope Pictures zipped LARGE
Cheers
WanaGo
Offline tinhead
« Reply #61 on: July 13, 2014, 11:33:18 pm »
thanks for the pictures, they are great. I do have now raw picture how they made it. Unfortunately you haven't made any picture of what under the channel shielding, in case you get some time to shot one i would be really thankful.
« Reply #62 on: July 13, 2014, 11:54:21 pm »
oh damn... does it just clip off?
I've closed it all up now.
However I might have to get back in there...
Ill def get you a picture though.
« Reply #63 on: July 15, 2014, 05:27:18 am »
I contacted Hantek and they promptly replied with this message to me:
Just uncompress packet file.
And store packet and emerg.do files to a USB drive, and plug the USB drive to DSO, turn on DSO.
If the DSO can reboot automatically when your upgraded the firmware last time, DSO can recall the factory setup.
Pls try.
With this file: http://www.taktik.co.nz/EEVBlog/packet.zip
« Reply #64 on: July 15, 2014, 05:39:30 am »
It looks like this contains fixes for the bad script before, but when I connected the USB drive with the packet folder and emerg.do files in the root of the USB drive, and started the scope up, it didnt seem to do anything differently.
Running the update program in the scope doesnt work either as it cannot find any updates on the drive.
So not 100% sure what to make of this.
Offline tinhead
« Reply #65 on: July 15, 2014, 08:08:10 am »
emerg.do (and all the even newer recovery tricks) are implemented into dsod file. You remember, you renamed it to stop the boot loop. That file need to be there and loaded, and when the firmware is crashing (or not loaded or missing) the dsod will look for "magic" on flash drive. You can see the output/status mesages on uart.
Btw., on my dev board when i follow the instruction the dsod is looking for system*.up and not doing what it should do :P
So who knows what your handheld is doing (that depends on version of dsod)
« Reply #66 on: July 15, 2014, 08:31:31 am »
OK interesting stuff.
They replied again when I said it didnt work.
Here is what they said
Since you could use UART connection, please use attached "uart_update" to solve the problem.
Steps as follows:
1. Just uncompress packet file.
And store packet and do_update files to a USB drive, and plug the USB drive to DSO, turn on DSO.
2. Connect DSO to PC by UART.
3. And input following commands in the UART tool on PC.
1?cd /mnt/udisk/
2) chmod +x /mnt/udisk/do_update
3) /mnt/udisk/do_update
and sent me the file I put here: http://www.taktik.co.nz/EEVBlog/uart_update.rar
Have an excuse to open it back up now and take that photo for you under the shield covers.
Will do that now
Regards
WanaGo
« Reply #67 on: July 15, 2014, 08:47:09 am »
Photos from under the cover are here. Also all scrubbed apart from the one near the opening.
Sorry if they are not very clear
http://www.taktik.co.nz/EEVBlog/DSO1152S-UnderCover.zip
Regards
WanaGo
« Reply #68 on: July 15, 2014, 08:59:20 am »
Followed their instructions...
Even worse now...
Display is now completely snow after the main start pages.
Here is the log
[root@Hantek /]# cd /mnt/udisk
[root@Hantek udisk]# chmod +x /mnt/udisk/do_update
[root@Hantek udisk]# /mnt/udisk/do_update
kernel is 2.6.30.4
ln: /lib/libgif.so.6: File exists
rm: can't remove '/OurLanguages': Directory not empty
mkdir: can't create directory '/OurLanguages': File exists
save exit: isCheckpointed 0
umount: /dev/sda1 busy - remounted read-only
umount: tmpfs busy - remounted read-only
[root@Hantek udisk]# umount: can't remount /dev/root read-only
umount: can't remount rootfs read-only
The system is going down NOW!
Sent SIGTERM to all processes
s3c2410-wdt s3c2410-wdt: Unexpected close, not stopping watchdog
Sent SIGKILL to all processes
Requesting system reboot
s3c2440-sdi s3c2440-sdi: powered down.
Restarting system.ÿ*** Warning - bad CRC or NAND, using default environment
##### EmbedSky BIOS for SKY2440/TQ2440 #####
Press Space key to Download Mode !
Booting Linux ...
Copy linux kernel from 0x00200000 to 0x30008000, size = 0x00200000 ... Copy Kernel to SDRAM done,NOW, Booting Linux......
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.30.4 (root@zgt) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-176) ) #125 Sat Jun 30 17:13:48 CST 2012
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: TQ2440
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0
NR_IRQS:85
irq: clearing pending ext status 00000300
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61260KB available (3160K code, 346K data, 100K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 296 bytes
NET: Registered protocol family 16
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
yaffs Jun 30 2012 14:45:29 Installing.
msgmni has been set to 119
alg: No test for stdrng (krng)
io scheduler noop registered (default)
backlight initialized
s3c2440-uart.0: tq2440_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: tq2440_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: tq2440_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
Driver 'sd' needs updating - please use bus_type methods
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=2, 20ns Twrph0=3 30ns, Twrph1=2 20ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 4 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "EmbedSky_Board_uboot"
0x000000200000-0x000000400000 : "EmbedSky_Board_kernel"
0x000000400000-0x000003ff8000 : "EmbedSky_Board_yaffs2"
0x000000100000-0x000000200000 : "EmbedSky_Board_logo"
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
Linux video capture interface: v2.00
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: starting watchdog timer
s3c2410-wdt s3c2410-wdt: watchdog active, reset abled, irq enabled
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: initialisation done.
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18a.
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
S3C24XX_UDA134X SoC Audio driver
UDA134X SoC Audio Codec
asoc: UDA134X <-> s3c24xx-i2s mapping ok
ALSA device list:
  #0: S3C24XX_UDA134X (UDA134X)
TCP cubic registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
lib80211: common routines for IEEE802.11 drivers
s3c2410-rtc s3c2410-rtc: setting system clock to 2009-01-01 00:01:39 UTC (1230768099)
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
usb 1-1: new full speed USB device using s3c2410-ohci and address 2
usb 1-1: configuration #1 chosen from 1 choice
scsi0 : SCSI emulation for USB Mass Storage devices
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem) on device 31:2.
Freeing init memory: 100K
insmod: can't insert '/lib/cfbcopyarea.ko': No such file or directory
insmod: can't insert '/lib/cfbfillrect.ko': No such file or directory
insmod: can't insert '/lib/cfbimgblt.ko': No such file or directory
insmod: can't insert '/lib/s3c2410fb.ko': No such file or directory
bwscon:0x2201d110
fpga bank 221422
dso-fpga: install ok
dso-spi initialized
Init spi success!
New Log Write OK Length:21
s3c2440_clkcon=00FE7FF0
fpga download file_name :dn.rbf
copy-from-user ok
dn_file_name:dn.rbf
fpga_down_load file name : dn.rbf.
data DOWN finish.
dso-spi:FPGA_DOWNLOAD ok.
release
<0>open LCD error: No such file or directory
dm9000 Ethernet Driver, V1.31
Now use the default MAC address: 10:23:45:67:89:ab
eth0 (dm9000): not using net_device_ops yet
eth0: dm9000e at c487a300,c487e304 IRQ 53 MAC: 10:23:45:67:89:ab (EmbedSky)
Try to bring eth0 interface up ...
Hantek GPIO(buzzer/speaker),(c)20110309
Hantek-gpio initialized
speaker on
Beep
dso-buzzer initialized
insmod: can't insert '/dso/driver/usb-storage.ko': No such file or directory
ifconfig eth0 hw ether 10:23:45:67:89:ab
eth0: link down
ifconfig eth0 192.168.1.55 netmask 255.255.255.0 up
/sbin/net_set: line 5: route: not found
add default gw 192.168.1.2
Done
scsi 0:0:0:0: Direct-Access     Lexar    JumpDrive        1100 PQ: 0 ANSI: 0 CCS
sd 0:0:0:0: [sda] 15679488 512-byte hardware sectors: (8.02 GB/7.47 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Assuming drive cache: write through
 sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
pdata->frequency=6000
s3c2440-i2c s3c2440-i2c: bus frequency set to 9 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
s3c2410_udc: debugfs dir creation failed -19
s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes
g_serial gadget: Gadget Serial v2.4
g_serial gadget: g_serial ready
lcd_init
dso-lcd1 initialized
insmod: can't insert '/dso/driver/dso-adc.ko': No such file or directory
tq2440_ts: module license 'unspecified' taints kernel.
Disabling lock debugging due to kernel taint
TQ2440 TouchScreen successfully loaded
input: TQ2440 TouchScreen as /devices/virtual/input/input0
Power-Ctrl initialized
Please press Enter to activate this console. cannot open lcd
s3c2440_clkcon=00FFFFF0
MachineFunctionLimitByBrandType
release
Booting Linux ...
Machine: TQ2440
NR_IRQS:85
TCP reno registered
loop: module loaded
ALSA device list:
s3c2410-rtc s3c2410-rtc: setting system clock to 2009-01-01 00:02:00 UTC (1230768120)
bwscon:0x2201d110
fpga bank 221422
dso-spi initialized
Init spi success!
copy-from-user ok
dn_file_name:dn.rbf
data DOWN finish.
release
speaker on
Beep
eth0: link down
Done
 sda: sda1
lcd_init
release
rm: can't remove '/param/sav/run*': No such file or directory
« Reply #69 on: July 15, 2014, 09:15:09 am »
Oh dear.
« Reply #70 on: July 15, 2014, 10:01:07 am »
Im stuck.
Cant get it working no matter what I try.
Seems that first update has cleared out some essential files or something, it no longer knows how to use the LCD.
Offline tinhead
« Reply #71 on: July 15, 2014, 12:51:26 pm »
when you look exactly the "last" update copied some missing libs and the new dsod, everything else (meaning the "broken" dso.exe, which seems to be not broken btw.) is the same. A new rcS and /model (what are they doing with that? i see it is on latest benchtop model as well, hmm, will have to take look on that). Anyway, so far evrthing should be ok.
I'm wondering about two things:
1- the new rcS is loading run.sh, which starts then the dsod, but not dso.exe (so i assume the newest dsod is calling the dso.exe or dso_bin itself, haven't check that but i trust them here, a day old "B" model firmware is doing this exact the same way). I'm wondering only that they implemented this on such old "S" models as yours, but yeah, they should know what they doing.
2- what is with the lib and lcd drivers on your handheld? Look your bootlog:
i did loaded "BV" model image, from 2011, so even older than your "S" model, then installed the first "S" model firmware - all working, and now used that manual update procedure - and everything works here. So it looks like the new dso.exe HAVE TO BE started by dsod (or manually, but not anymore from rcS, so that's why you got new one). Anyway, everything seems to be working (as far i can see on my dev board).
I your older bootlog there is no such problem with lib directory, so i assume you wiped that directory at some time (this is why i did checked myself if one of hantek's updates was responsibe for this, but it wasn't). I would say, send them that bootlog, they can easily compile for you zip file with all the missing files (i would do this for you, but i don't have any dump of "S" model and even if my dev board works, i can not guarante that my lib dir is complette, so better when Hantek compile for you this).
« Reply #72 on: July 15, 2014, 09:22:45 pm »
Hmm
I haven't wiped anything manually.
I sent them the logs I posted here, will wait I suppose.
« Reply #73 on: July 16, 2014, 03:40:50 am »
Fixed, they send another update.
Attached.
kernel is 2.6.30.4
umount: /dev/sdb1 busy - remounted read-only
Booting Linux ...
Copy linux kernel from 0x00200000 to 0x30008000, size = 0x00200000 ... Copy Kern        el to SDRAM done,NOW, Booting Linux......
Uncompressing Linux.............................................................        ................................................. done, booting the kernel.
Linux version 2.6.30.4 (root@zgt) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-1        76) ) #125 Sat Jun 30 17:13:48 CST 2012
Machine: TQ2440
NR_IRQS:85
TCP reno registered
loop: module loaded
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit        )
ALSA device list:
s3c2410-rtc s3c2410-rtc: setting system clock to 2009-01-01 00:02:58 UTC (123076        8178)
setting vert: up=11, low=11, sync=1
setting horz: lft=17, rt=135, sync=11
Console: switching to mono frame buffer device 80x30
fb0: s3c2410fb frame buffer device
bwscon:0x2201d110
fpga bank 221422
scsi 0:0:0:0: Direct-Access     USB 2.0  Flash Disk       2.10 PQ: 0 ANSI: 2
sd 0:0:0:0: [sda] 2046456 512-byte hardware sectors: (1.04 GB/999 MiB)
 sda:dso-fpga: install ok
 sda1
dso-spi initialized
Init spi success!
copy-from-user ok
dn_file_name:dn.rbf
data DOWN finish.
release
var.xres=640
var.yres=480
var.bits_per_pixel=16
var.xres_virtual=640
var.yres_virtual=480
fix.id=s3c2410fb
fix.smem_start=866123776
fix.smem_len=614400
fix.type=0
fix.type_aux=0
fix.xpanstep=0
fix.ypanstep=0
fix.ywrapstep=0
fix.line_length=1280
argv[1]=16
var.xres=640    var.yres=480    var.bits_per_pixel=16
show logo,video_buf_size = 614400
eth0: dm9000e at c488c300,c4890304 IRQ 53 MAC: 10:23:45:67:89:ab (EmbedSky)
speaker on
Beep
eth0: link down
Done
lcd_init
Please press Enter to activate this console. s3c2440_clkcon=00FFFFF0
InitLcdShowBasic:0x40b92000
***************************Stat_ShowBattery:0, 0
INIT SYS OK!
***************************Stat_ShowBattery:1, 0
******************no data cnt=-1************************
« Reply #74 on: July 16, 2014, 05:04:53 am »
Very glad to hear this good news.
Our engineer have found the problem and will make up a firmware without this bug.
Many thanks for your below helpful datas.
