Does anybody own Fluke 28?
Test leads does not go all the way in??
Also when in ohm range it reads resistance of diodes.. this is confusing for in-circuit troubleshooting... If I remember right Fluke 12 and 77 did not do that?
And third thing I noticed when measuring higher capacitors for example 3300uF results are around 10% higher compared to Agilent U1272A, BK Precision 875B and Hioki 3801-50.
Other than that and diode range (only up to 2V) I love it.
