Author Topic: bug found? Hantek DSO5102P: different measures in AC vs DC coupling  (Read 3501 times)
Offline bdunham7
Re: bug found? Hantek DSO5102P: different measures in AC vs DC coupling
« Reply #25 on: April 16, 2021, 10:35:28 pm »
And this is consistent across all channels?
Offline radiolistener
  • Country: ua
« Reply #26 on: April 17, 2021, 04:11:27 pm »
yes, the behavior is exactly the same for both channels. Both have the same frequency response.
Offline DL2XY
« Reply #27 on: April 18, 2021, 10:08:56 am »
Your mains voltage is not a sine wave but a trapezoid.
Simulating the measurement with a clean trapezia clearly shoes the effect:
During the constant voltage phases the coupling capacitator is charging, in the transients this charge is transported to the other half-cycle resulting in overshoot.
« Last Edit: April 18, 2021, 10:15:40 am by DL2XY »
Offline David Hess
  • DavidH
« Reply #28 on: April 18, 2021, 10:12:47 pm »
There are plenty of oscilloscopes which do not suffer from additional distortion when measuring distorted AC line waveforms.  With a single pole response, even the difference between 1x and 10x probe attenuation yielding 10 and 1 Hz cutoffs is not visible.
