Author Topic: Hantek 4032L Logic Analyzer  (Read 33777 times)
Online FraserTopic starter
« on: April 28, 2013, 10:00:41 pm »
I have been looking for a new Logic Analyzer and, after some searching, found that the Hantek HT4032L meets my limited needs for monitoring data and address buses, at a decent sample rate. 32 Channels, 2Gbit internal DDR2 memory, up to 400Ms/s, 150MHz b/w.
It is a USB device so uses a PC, but it contains 2Gbit of DDR2 Ram that is used across the 32 Channels as required  :-+
I am aware that Hantek software can be flakey but hopefully it will be good enough for my requirements. The SDK is listed on the Hantek web site, so DIY software is a possibility.
I shall report my thoughts on the unit when it arrives this week. It is available in the UK from Rigoloscilloscope.co.uk for GBP139 delivered.
http://www.rigoloscilloscope.co.uk/wholesale/PC-USB-Logic-Analyzer-Hantek4032L-320.html
Manual attached
« Last Edit: April 29, 2013, 05:09:11 pm by Aurora »
Offline Lightages
  • Canadian po
Re: Hantek HT4032L Logic Analyser
« Reply #1 on: April 28, 2013, 11:03:10 pm »
I hope to see a review soon! Please?
« Reply #2 on: April 29, 2013, 04:43:11 pm »
The 4032 arrived today. It was taken apart within minutes  :)
Here are the pictures of what lives inside. The PCB is very well anotated, almost as though Hantek are encouraging experimentation with it. Even the JTAG connection is clearly maked, complete with voltage pin !
On the down side, when I received the unit something just didn't look right. In the all the pictures that I had seen, the annotations on the I/O socket were upright when the unit is stood vertically on its feet....not on my unit, they were all upside down. To overcome this I took the unit apart and changed the orientation of the case so that the anotations are upright. The Hantek logo is now correctly orientated but on the opposite side to the pictures on the internet ! The power and USB ports are now nearesr the top of the unit rather than near  the desktop. A small FAIL, but still a FAIL in my book. The label on the bottom also reads "2M Memory Deepth". A minor spelling error but a silly one for a manufacturer to make as all labels should be proof read before release.
The port marked USB-X1 is, I believe, a port used to connect the unit to an oscilloscope and other Hantek test equipment to form a test kit 'stack'
The PCB is marked "2012-12-7 LA4032 V3.0" so it has been through at least two other versions and is a relatively recent PCB release. The PCB and the component placement is very good, so no complaints there. Just how could they have messed up the I/O port orientation so badly !
The PCB design seems a step up from the Hantek 5034 which, IMHO, looks to be a far cheaper unit in terms of quality of layout. The 4032 has nice track length compensation (the wiggly pcb tracks) and a well organised layout. Compare my pictures with those of the 5034 in this thread:
https://www.eevblog.com/forum/chat/anyone-tried-the-hantek-la5034-logic-analyzer/msg18290/#msg18290
I wouldn't have thought that they were both from the same OEM manufacturer but I may be wrong about that.
The logic analyzer package includes the 4032L, A decent looking multi national SMPSU with US, Aus and European adapters (no UK adapter), nice quality short length probe leads, 18 IC pin grabbers of reasonable quality (I will be using the superior HP and TEK ones though), USB cable and a software CD.
All in all I am pleased with the design and build of the unit. I have an HP logic analyzer self paced training board that I will connect this unit in order to do some tests on its performance.
Chip data:
Spartan-6 XC 6SLX16 :
http://www.xilinx.com/products/silicon-devices/fpga/spartan-6/lx.html
Cypress CY7C68013A-100AXC :
http://www.cypress.com/?mpn=CY7C68013A-100AXC
Micron D9LHT:
1Gbx16 400MHz SDRAM DDR2
http://www.micron.com/parts/dram/ddr2-sdram/mt47h64m16hr-25e
« Last Edit: April 29, 2013, 11:12:52 pm by Aurora »
The following users thanked this post: Pitrsek
Offline nctnico
Re: Hantek 4032L Logic Analyzer
« Reply #3 on: April 29, 2013, 09:06:49 pm »
IMHO its pretty sad the designer used so many tantalum capacitors. These should be avoided because they are unreliable and not so good compared to ceramic multilayer capacitors.
« Reply #4 on: April 29, 2013, 09:38:32 pm »
Noted but is the Tantalum not maligned because of its failure in old equipment ? It has always been used in MilSpec equipment made by Racal and they served their country reliably until they reached an age well beyond that intended for continued use. I have repaired many Racal equipment's with failed tantalum capacitors on the power rails, but that equipment dated back to the 1980's. I am suspicious of Electrolytic capacitors even in relatively new equipment but I was not of the same opinion about Tantalums....am I wrong to trust them more than the crap cheap electrolytics ? Tants have always been the expensive and preferred alternative to electrolytics.
Offline nctnico
« Reply #5 on: April 29, 2013, 09:43:22 pm »
Because of the low ESR they are better for switchers and power supply decoupling. The whole problem with a tantalum is that it is basically a small bomb (oxidizer and fuel). A large voltage spike may set it off and if the PSU can supply enough power it will burn right through a board like thermite otherwise it will just become a short.
« Reply #6 on: April 29, 2013, 09:54:25 pm »
Ah I see why you are not a fan of them. I have been lucky to date, only shorted tantalums that took out the power rail rather than burning anything. Nest time I restore a piece of old kit I think the Tants (good or bad) will be changed out.
Thanks for enlightening me on these little monsters.
Online notsob
« Reply #7 on: April 29, 2013, 10:00:43 pm »
I think it comes down to using the 'right' component in the right place and beware of it's possible short comings when designing. I've repaired boards where many of the resistors were ' fuse' varieties, ie failed open to prevent possible damage, and at the same time boards with gigantic holes burned thru them when a tant went up in flames.
Offline Lightages
  • Canadian po
« Reply #8 on: April 29, 2013, 10:37:19 pm »
Thanks Aurora. Now we need to see it in action!  ;)
Offline codeboy2k
« Reply #9 on: April 30, 2013, 05:29:03 am »
That Cypress chip is a pretty expensive USB controller; it's around $11.00 for qty 1000+... I think if I was doing it today, I might consider an ATMEL device with USB. They can cost  as little as $5.50 or so in qty 1000. It would really depend on the availability of DMA on the chip and USB software libraries for the device.  But it might be possible at half the cost, unless they would have to license something that the Cypress chip includes already.  If so, well then there's the cost difference right there. .
They are probably using Cypress's well known and well supported EZ USB
« Reply #10 on: April 30, 2013, 08:59:44 am »
I was pleased to see known brands of chips in the unit and I am also pleased to hear that they have used a relatively expensive Cypress chip. It may not be the most cost effective solution but I hope this means that the unit is not a cheapo, built down to a budget product using the very cheapest parts available. I am also pleased to see that no silly chip anonymisation has been done !
Thanks for the comments on the design, most welcome. I only hope the software is worthy of the hardware !
I don't have time to 'play' at the moment, so pictures of the software working will need to wait a little.
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #11 on: May 03, 2013, 12:57:46 am »
It's a pity they didn't provide a Trigger Out - very little extra cost to do it - and it really should be standard with LAs.
Not to jump the gun on your review, but the software looks exactly the same as the software for their old LA (LA5034), which hadn't gotten very good reviews by a previous owner here. Oh well, Hantek software (and you can say the same for pretty much all Chinese test equipment manufacturers) is generally crap - so you just have to resort to writing your own.
Offline tinhead
« Reply #12 on: May 03, 2013, 09:35:55 am »
i bet this USBXI port provide trigger out as it can be used to sync multiple devices (as far i understood).
The problem is, i don't see any pinout nor documentation published  :palm:
Offline marmad
  • Country: aq
    • DaysAlive
« Reply #13 on: May 03, 2013, 10:30:36 am »
Maybe, but even if true, it's certainly not handy on a card-edge connector.
Offline JimmyMz
« Reply #14 on: May 19, 2013, 01:54:12 am »
I guess there isn't much to say about this LA, or am I reading the 2+ weeks of time w/o a review poorly?
If you didn't get this message, let me know, and I'll get you another.
« Reply #15 on: May 19, 2013, 11:12:45 am »
Reviewing equipment is not my day job and so other priorities come first.
Patience will be required by those wanting a review as these are just 'toys' to play with compared to my day job responsibilities. There are never enough hours in a day  ;)
« Last Edit: May 19, 2013, 02:13:38 pm by Aurora »
Offline JimmyMz
« Reply #16 on: May 19, 2013, 07:56:10 pm »
Personally, I don't need a lengthy review. A thumbs up, or thumbs down, along with two sentences; one sentence for pros and one sentence for cons, and I'd be happy.  :D
Please don't misinterpret my comments, I fully understand you might be busy, and I'm completely happy, if you write something once you feel like it.
Thank You,
JimmyMz
« Last Edit: June 06, 2013, 05:32:12 pm by JimmyMz »
« Reply #17 on: May 19, 2013, 10:12:11 pm »
OK, I will sort something out this week for you. It will not be a lengthy review but will detail my findings when used on a digital test piece that I have. I also have the Hantek 1025G Function/Data pattern generator that will present the LA with some different data patterns. I really want to get stuck into testing these but alas life has been on the hectic side of busy since purchase.
For info I also have a Sysclk-DX en-route to me. That has a lesser sampling frequency capability, but does offer data decoding and two low frequency oscilloscope channels in the one box. A true MSO it isn't but it may be an interesting 16 channel unit all the same.
Sysclk-DX Specifications:
Two input channels with a maximum analogue sampling rate of 24Msps
   Analogue Bandwidth 3 MHz
   Analogue Channels: 2
   Input voltage measured: -10V to 10V
   Input impedance: 1MOhm/30pF
   Logic I/O Channels :16
   Protocols:
              Channels: 16
   Maximum sampling rate: from 1 to 24Msps with 4 trigger levels
   SPI, I2C, Async, USB, PS/2, SM Bus, Sync Serial, CAN, 1-Wire, Parallel busses as well as Custom Decoder capabilities
Utilities:
   Bus Data Extractors
   Oscilloscope/Logic Analyzer
   Bus Decoders
   PacketPresenter
   Digital Signal Generator
   Data Logger
   Voltmeter
   Frequency Counter
   I2C Bus Controller
   Frequency Generator
   PWM Controller
   Pulse Counter
   Toolbuilder Source Code API
   Remote Controller
http://www.aliexpress.com/item/Free-Shipping-Sysclk-DX-Mixed-Signal-Oscilloscope-and-logic-analyzer-USB-2-probe-P6100-20LA-probes/583945355.html
I also own a Link Instruments 200Ms/s MSO-19 that is an 8 Channel MSO with one analogue input.
http://www.linkinstruments.com/mso19.htm
Its a very clever product but it has only 8 channels in the LA and cost a lot more than the other two LA's.
Watch this space.
Offline abyrvalg
« Reply #18 on: May 19, 2013, 10:25:35 pm »
I'm another fresh happy [hard to say] owner of this device, so here are my 5 eurocents:
Hardware:
  • + big buffer
  • + build quality is much higher than expected
  • + a good FGPA+DDR+USB plaform (more on this later)
  • - clips quality is poor
  • - plastic bumpers of the housing produce strong "chinese equipment" smell (thrown away immediately)
Software:
  • + trigger options beyond simple single edge/single pattern
  • + protocol decoders seems to work
  • - stucks in "Capturing..." state often (Stop button does nothing, or there is some very big delay?)
  • - no data save/load function, export only
  • - waveform render is extremely slow! zoom/scroll operations takes seconds
  • - using cursors is a bit complicated - right click, select from menu
  • - no external clocking option (although mentioned in manual, ACLK/BCLK pins present on a connector, but Hantek support had confirmed that it's not possible)
I don't expect breakthrought sw updates from manufacturer, but hw part looks pretty powerful, so I'll try some DIY based on it (first - try adapting some 3rd party sw like open source sigrok).
I did a quick research already, here are some results:
  • Both FX2 and FPGA boots to their final states from serial EEPROMs, not from PC (not so handy for experiments, but this can be fixed - disconnect both EEPROMs, switch Spartan to Slave Serial mode)
  • FX2's fw is pretty dumb, data passes directly to/from FPGA with no sw intervention (slave FIFO mode)
  • Spartan's JTAG pinout found (so I got access to spartan's pins via boundary scan)
  • All FX2-Spartan interconnect found
  • All Spartan-test port interconnect found
  • Both DRAMs are connected to Spartan's dedicated MCBs
  • The undocumented USBXI is FX2's USB, 2 Spartan's IOs (triggers?), power/gnd
  • Test port has two reference voltages (defines treshold voltages) generated by obscured U11,U12,U13. U13 is connected to Spartan
If somebody wants to play with this device, I can post more details.
To codeboy2k: Cypress FX2 gives both simplicity and high throughput (20+ MBytes/s can be reached with a few lines of code, most of the hard work is done by hw). AFAIK comparable Atmel chips (ones with USB 2.0 HS ports) are ARM9s suitable for Linux, with much more complex programming.
Offline Rasz
    • My random blog.
« Reply #19 on: May 19, 2013, 11:07:43 pm »
Have you heard about http://sigrok.org ?
They are currently in a process of standardizing/modularizing logic sniffer firmware codebase so it can be reused on  all of the supported devices.
http://sourceforge.net/mailarchive/forum.php?thread_name=51923CBA.4000308%40ciellt.se&forum_name=sigrok-devel
« Reply #20 on: May 20, 2013, 12:07:06 am »
abyrvalg,
Thanks for your excellent insight into the 4032L. I will see if mine behaves the same with the lock-up issue and slow responses. I am running Win7(64) on an i5 so there should be enough grunt on the PC side for this little unit.
Out of interest did you notice that 'as supplied' the front panel legends are upside down. That is to say when the unit is stood up on its side with the word HANTEK facing you, all the I/O connector details are inverted ! An amazing cock-up ! I know what you mean about the rubber bumpers, but mine don't smell too bad at all.
I will be testing my unit against an HP MSO training board that provides all sorts of test signals to play with (GBP30 new on e*ay). I will also use the Hantek 1025G but I will need to be careful as I could end up with the scenario where poor output from the 1025 causes apparent issues with the 4032  :scared:
For anyone interested in a simple MSO training board and manual look here:
http://www.ebay.co.uk/itm/Self-Paced-Training-Kit-for-Hewlett-Packard-546000B-Oscilloscope-/290841237442?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item43b77d17c2
and another sellers offering:
Silex-Major - he normally has a few new ones in stock
http://www.ebay.co.uk/itm/Hewlett-Packard-54654A-Self-Paced-Training-Kit-/370792531262?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item5654f5053e&nma=true&si=HmEgAcW1wJEWok98evDCIhXKKFY%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
and here for the USA:
http://www.ebay.co.uk/itm/HP-AGILENT-54654A-TRAINING-KIT-/290750149799?pt=LH_DefaultDomain_0&hash=item43b20f34a7
Its pretty good for the money being asked and is a good quick start test piece for newbies.
« Last Edit: May 20, 2013, 12:27:29 am by Aurora »
Offline abyrvalg
« Reply #21 on: May 20, 2013, 07:16:29 pm »
Rasz, that long link is very interesting, thanks! I've seen their top level pages, but never went deeper
Aurora,
Yes, my unit had the same mistake with panels, bumpers legs were facing opposite sides also :D I have a feeling that housing/clips/sw were designed by some different team than PCB.
Btw, I had some progress today, patched the board to boot from PC (boot FX2 with fpga loader fw, load fpga, boot FX2 with function fw), original fx2/spartan binaries boots just fine. The result is that LA behaves like a generic bootable fx2/spartan/ddr evaluation board with possibility to boot original LA function in 5 seconds.
Offline Rasz
    • My random blog.
« Reply #22 on: May 20, 2013, 10:21:11 pm »
Sigrok guys would probably appreciate it if you shared all the info about hantek with them. They might even help you with firmware if you want to extend existing feature set.
« Reply #23 on: May 20, 2013, 11:01:50 pm »
With regard to the provided test clips..... I have found most cheap one to be a liability so have bought up plenty of the HP/Agilent and Tektronix micro grabbers. A far superior product, but they can cost a small fortune unless, like me, you find a reasonable seller. I have paid around GBP20 for a new pack of 20. They are commonly available in the USA but sadly the postage to the UK can be a real killer.
The additional cost of the quality grabbers is fully justified if you consider the potential damage that can occur if IC pins are shorted together by a cheap grabber claw. I elected to save a few dollars on the SysClk DX unit, by not having the grabbers included. No loss at all to me as they are pretty rubbish.
Offline nctnico
« Reply #24 on: May 21, 2013, 12:59:38 am »
Grabbers always have been a nuisance. The rate in which they detach per minute is e^(number of grabbers)
I usually solder thin (like hair) wires to the pins I want to observe. Those thin wires go to a header which I can plug into the probes of my logic analyser. An advantage of the thin wires is that they also work on 0.5mm (or less) pitched QFP and QFN packages.
