Author Topic: Hantek PPS2116a reverse engineering  (Read 1141 times)
Offline fqahmad66
« on: June 02, 2021, 07:03:08 am »
My Hantek PPS2116a finally died so took it apart to study and do some reverse engineering. Starting with the power board (usually the culprit), noted that it has AC fault sensing which the Korads lack.
Attachments updated
« Last Edit: June 13, 2021, 08:21:32 am by fqahmad66 »
The following users thanked this post: rvalente
Offline fqahmad66
Re: Hantek PPS2116a reverse engineering
« Reply #1 on: June 07, 2021, 03:36:39 am »
Next Trying to understand the Main Board. Does somebody managed to successfully download the hex file? Never mind.. I got it.
« Last Edit: June 09, 2021, 08:42:34 am by fqahmad66 »
Offline fqahmad66
« Reply #2 on: June 10, 2021, 06:11:13 pm »
Main Board Layout and schematic. Can somebody educate how is the OVP implemented? Cannot trace it.
Offline fqahmad66
« Reply #3 on: June 13, 2021, 10:13:51 am »
Latest destination of this power supply.
https://www.circuitspecialists.com/pps2116a-programmable-dc-power-supply.html
There is no programmable OVP...just  a built in AC fault shut down.
« Last Edit: June 13, 2021, 10:15:53 am by fqahmad66 »
Offline fqahmad66
« Reply #4 on: June 17, 2021, 06:24:50 am »
Display, Keyboard and USB schematics..
Offline miatarexx66
« Reply #5 on: November 30, 2021, 08:29:44 pm »
THANK YOU for posting the attached schematics.
I work as a bench technician and my company has 40+ of these specific units so the information is greatly appreciated.  I have repaired quite a few of them but have had some that I couldn't quite figure out without more info or schematics.  Some of the suspected parts also appear to be obsolete or out of stock when I search for those.
What kind of issues did you have with yours?  Problems, symptoms?  If you fixed it, what was it?
I'm currently working on one that just stopped working during some ESD testing some of the other engineers were performing, the control board doesn't appear to be functioning at all.  Can't adjust voltage or current.  Other than showing all 0's, it's basically a boat anchor currently.
Offline fqahmad66
« Reply #6 on: December 01, 2021, 10:03:45 am »
I am glad you find those usefull. I did reverse engg just for fun. The supply is now resting dismantled in a box. I replaced it with a Rigol. You may check the diode across supply on Power board and also TLO82s on Main board. Mine had that diode blown due to connecting a reverse battery. The code protection on MCus is enabled so it that is fried then a replacemet board is the only solution.
Best regards
Farooq
Offline rvalente
  • Country: br
« Reply #7 on: December 01, 2021, 01:14:43 pm »
Well done!
Would you share more about the reversing engineering techniques you've used?
Is this cad capture from altium? Does not seems to be eagle or kicad?
470uF as output cap seems a little high to me, does that PS has big overshoot on short?
Offline fqahmad66
« Reply #8 on: December 01, 2021, 06:42:44 pm »
Took out the boards and visually followed the layout and traces. Did you ever replaced the MC is any of the controller boards? No overshoots. It was a very good supply in my opinion. However it will fry a Zener or LED if touched with live voltage...not through the soft on/off.
« Last Edit: December 01, 2021, 06:46:36 pm by fqahmad66 »
