Author Topic: Hantek - Tekway - DSO hack - get 200MHz bw for free  (Read 1636939 times)
panoss and 2 Guests are viewing this topic.
Offline ayechon
Re: Hantek - Tekway - DSO hack - get 200MHz bw for free
« Reply #1750 on: May 19, 2013, 01:44:46 pm »
How to read / write the "DISP" file using DSO-USB-Tool. I proceed as follows:
I select the Read / write File (F4) tab and in the Filename field I entered "/ DISP" then I clik on the "Read from DSO" button. This method does not work.
Thank you.
Offline tinhead
« Reply #1751 on: May 19, 2013, 04:03:57 pm »
Thank you.
did you installed the DSO drivers, and if which of them , the original or libusb?
On my computer libusb seems to works better (especially file/read write seems to be affected)
Offline oguz286
  • Make, break, hack, tweak
    • GuzTech
« Reply #1752 on: May 19, 2013, 10:32:38 pm »
I'm looking for a oscilloscope which is going to be my first and the Tekway DSO1062B looks like a really nice device.
If I were to order a new one today, would I still be able to perform the UART hack? Or did Tekway block it off in a new hard/firmware revision?
If it still is possible I'll be ordering a new one from pinsonne elektronik asap :)
Offline electrollers
« Reply #1753 on: May 23, 2013, 01:04:18 pm »
Hi
As the DSO-USB-Tool has a shell option to send comands to busybox. Is it possible to follow the procedure with that tool, without opening the case and soldering the UART?
For me is not a problem soldering, but this seems easyer.
Thanks
The answer seems to be yes, as nobody has said the contrary in the last posts.
« Last Edit: May 23, 2013, 04:37:55 pm by electrollers »
Offline tinhead
« Reply #1754 on: May 23, 2013, 01:16:57 pm »
Hi
sure, move/copy will work, edit (vi) of course not because this is not a real remote shell. So when you need to edit
e.g. the logotype.dis they you can copy to flash drive/edit on PC, or read/write from DSO to PC over read/write function in that
tool or echo new line into file (in case that work).
Offline Yaksaredabomb
« Reply #1755 on: May 24, 2013, 04:06:39 pm »
I'm looking for where I can get a Hantek DSO5102B in the USA.  I posted about it here:
LFS / WTB (USA) Hantek DSO5102B oscilloscope new or like new
Not trying to intrude but thought I might get a few more responses if I post here, too, since there are so many in this thread that know a lot about this series of scopes.  Thanks for humoring me.
Edit:  Modified link to show topic title.
« Last Edit: May 24, 2013, 04:09:16 pm by jneumann »
My display name changed June 6th from "jneumann" to "Yaksaredabomb"
Offline jebcom
« Reply #1757 on: May 26, 2013, 06:21:31 am »
check circuit specialists
http://www.circuitspecialists.com/digital-storage-oscilloscopes
Thanks jebcom!  Nice to have at least one option besides ebay, and their 30-day return option is nice to know about.
For anyone else, I'm still open to other sources or anyone's used model - please comment on my post in the Buy/Sell/Wanted forum if you have any help.
Now I'll stay out of this thread!  Thanks again for letting me intrude.
Offline tinhead
« Reply #1758 on: May 28, 2013, 08:47:38 am »
as few people asked for it, attached BSDL files for:
- Tekway DST1000(A) - SoC S3C2410
- Tekway/Hantek/Voltcraft/Extech B/BM/BMV/S series DSO/MSO/Handhelds, S/N < 15000 - SoC S3C2440
- Tekway/Hantek/Voltcraft/Extech B/BM/BMV/S/P series DSO/MSO/Handhelds, S/N > 15000 - SoC S3C2416
The S3C2416_bsdl file is as well good for Owon SDS users.
Offline oguz286
    • GuzTech
« Reply #1759 on: May 28, 2013, 04:44:19 pm »
Well I just changed my Voltcraft DSO-1062D to a DSO-1202D, and I think it went ok. I can select 4ns/div, so I guess it's ok now :)
Offline tinhead
« Reply #1760 on: May 28, 2013, 05:03:30 pm »
you should have 2ns/DIV
Offline oguz286
    • GuzTech
« Reply #1761 on: May 28, 2013, 06:32:19 pm »
Hmm, I followed this video:
I renamed the dst1062b file to dst1202b, adjusted sys.inf accordingly, and also adjusted tmpdst, logotype and logotype.dis.
Just in case it matters, here is the system information:
Model: DSO1202D
SW version: 2.06.3 (130306.0)
HW version: 10070x555583eb
EDIT: I do get an error that a logo file cannot be found for the 1202 version, but it boots up just fine.
« Last Edit: May 28, 2013, 06:33:52 pm by oguz286 »
Offline tinhead
« Reply #1762 on: May 28, 2013, 06:59:00 pm »
actually it is only necessary to rename the /dst1062b to /dst1202b
and (if you need boot logo) edit the /logotype.dis file
Everything else will be automatically changed after two reboots after you remaned the /dstxxxx file
Model: DSO1202D
is your serial number higher than 15000? (the last numbers)
Btw, there is no such model DSO1202D, so copy paste error or you really typed wrong name?
For the logotype.dis file, it is better to use something generic, like "hantek_DSO5202B", which
will give you then DSO5202B as model.
sure, but here somewhere in thread (haha) are all the logos you need (i think),
for the functionality it does not have any influence.
Offline oguz286
    • GuzTech
« Reply #1763 on: May 28, 2013, 07:18:55 pm »
Hmm, ok, that's good to know.
Model: DSO1202D
My serial number is lower than 15000.
Well, my model number is DSO-1062D, so I just changed that to DSO-1202D :P I'll change the logotype.dis file to hantek_DSO5202B, so I have a nice startup screen :)
188 pages...  :-DD I'll see if I can find them :)
EDIT: Removed serial number
« Last Edit: May 28, 2013, 07:47:02 pm by oguz286 »
Offline tinhead
« Reply #1764 on: May 28, 2013, 07:28:20 pm »
you should maybe not post the serial here :)
Ok, havin the latest firmware (whcih is the case for you) you should have 2ns/DIV available if the
hack was successful, so there is something you did wrong.
« Reply #1765 on: May 28, 2013, 07:30:57 pm »
sure, but here somewhere in thread (haha) are all the logos you need (i think), for the functionality it does not have any influence.
I might have seen the post you'd be looking for just earlier today or yesterday.  Wasn't able to find it quickly, but maybe this one will help:
https://www.eevblog.com/forum/chat/hantek-tekway-dso-hack-get-200mhz-bw-for-free/msg92830/#msg92830
Offline tinhead
« Reply #1766 on: May 28, 2013, 07:53:22 pm »
or here (i've added as well link on first thread page)
http://www.mikrocontroller.net/attachment/136103/all_logos.zip
« Last Edit: May 28, 2013, 07:58:00 pm by tinhead »
Armageddon
  • Guest
« Reply #1767 on: May 28, 2013, 08:24:17 pm »
Hi tinhead!
For Owon SDS?
Offline tinhead
« Reply #1768 on: May 28, 2013, 08:55:40 pm »
yes, Owon SDS series is using as well the same Samsung S3C2416 SoC as Hantek in their latest hardware revision
(all "P" models, all others with S/N > 15000)
Hi tinhead!
For Owon SDS?
Armageddon
  • Guest
« Reply #1769 on: May 28, 2013, 09:09:00 pm »
Sorry, but:
 What is the purpose? What I can modify with this BSDL file?
« Last Edit: May 28, 2013, 09:11:00 pm by Armageddon »
Offline tinhead
« Reply #1770 on: May 28, 2013, 09:26:45 pm »
Sorry, but:
not modify, but e.g. use to reverse connections from. You need that BSDL file for boundary scan:
http://en.wikipedia.org/wiki/Boundary_scan
with tools like
http://ricreations.com/JTAG-Software-Downloads.htm
http://www.topjtag.com/probe/
Offline sorin
  • Country: al
« Reply #1771 on: May 31, 2013, 08:46:44 am »
Hi!
Do you have any updated information about DSO5072P
You say: "there is complettly different SoC/new PCB"
Can this model be updated (hacked) with RAM memory?
Offline tinhead
« Reply #1772 on: May 31, 2013, 09:41:40 am »
bandwidth can be hacked for sure, what else no idea. All i have are some pictures from top PCB side,
but unfortunately no pictures from bottom side (i know 2ppl haveing P models, but for some reason they
not shot (yet? ever?) pictures from bottom side).
Here what i know so far:
If someone have one of these "P" models, please do a teardwon and shot some more pictures,
especially the bottom side of the PCB is complettly unknown yet
updated, check
https://www.eevblog.com/forum/testgear/hantek-tekway-dso-hack-get-200mhz-bw-for-free/msg264085/#msg264085
« Last Edit: July 19, 2013, 01:56:31 pm by tinhead »
Offline oguz286
    • GuzTech
« Reply #1773 on: June 02, 2013, 10:12:31 am »
Thank you for the help guys! Now I have a 200MHz schizophrenic oscillosope (Hantek logo :-DD).
Forgive my ignorance, but I just wondered... I can now select 2ns/div and 2ns is 500MHz. Does it have something to do with the sampling rate?
Offline tinhead
« Reply #1774 on: June 02, 2013, 07:41:05 pm »
absolute nothing together
