Author Topic: Hantek - Tekway - DSO hack - get 200MHz bw for free  (Read 1635861 times)
Offline Hydrawerk
Re: Hantek - Tekway - DSO hack - get 200MHz bw for free
« Reply #1800 on: June 16, 2013, 05:19:56 pm »
I am still looking forward to Dave's review of this Tekway scope... https://pbs.twimg.com/media/BMI6-1sCMAEse4e.jpg
« Last Edit: June 16, 2013, 05:23:25 pm by Hydrawerk »
Offline tinhead
« Reply #1801 on: June 16, 2013, 07:52:32 pm »
so far i know he did it, but probably not edited/uploaded yet or simply decided to publish it "later" as 3 DSOs within
3 weeks might be too much at once for some users.
I don't know if he covered all the "hidden" things, like e.g. Recorder or Marker (marmad spoke about in his review)
or triggered XY mode or lot of the other things you might not see directly or might not recognize as "special" without
deep look on it. Example the Recorder; it is at first look simply recorder, but you have to check deeper to see what
you can do with it and what others can't :
https://www.eevblog.com/forum/testgear/is-rigol-ds1052e-still-the-best-option-in-its-class/msg246917/#msg246917
I'm sure he will have a rant about the 1M/2M memory slowing the front panel/UI response to "worm speed"
(no, not worm hole speed, not light speed ^^).
But that's will be ok for "first impression" video, it would be not fair to do deep review and try to find "possitive"
things on Tekway/Hantek when he not did that for Owon or especially Instek (which is in higher price/quality class).
Offline Hydrawerk
« Reply #1802 on: June 16, 2013, 08:52:24 pm »
Marmad's Tekway scope was full of bugs in 2011, but it changed, I hope...
Offline Hydrawerk
« Reply #1803 on: June 17, 2013, 05:33:24 pm »
This thread is too long to search...
Was there ever any serious issue with this scope like the well-known Owon noise problem?
Not a single wrong unit, but many of them? AFAIK not, but?
Offline tinhead
« Reply #1804 on: June 17, 2013, 11:38:54 pm »
AFAIK not, but?
but what? Are you looking for somethign special? Something that is bad or not that good?
oh yes, there was between Feb 2011 and Jun 2011 hardware revision hw1005.
That was first revision made by Hantek, and it was not working as expected.
There was a difference between production and test unit, the FPGA design was
just a bit over the limit, so while sampling with 1GS/s there was a lot of distortion
making these DSO useless at 1GS/s.
I can't tell you how many units was affected exact, but it was something like 90%
The remaining 10% got special FPGA deisgn, making them bit more noisy but stable.
As a long term solution Hantek re-designed the PCB and fixed these issues with
hw1007 (which is since then still the latest hw revision for 1M/2M DSOs and MSOs)
« Last Edit: June 18, 2013, 01:17:41 am by tinhead »
Offline Hydrawerk
« Reply #1805 on: June 18, 2013, 12:29:55 am »
Thanks. So it was solved two years ago, it's OK.
Offline jyo
« Reply #1806 on: June 20, 2013, 02:29:37 pm »
I (unfortunately) got a hw1005 on april 2011 (I was happy to have a new - better - hardware at that time  :palm:)
Is there a way to know if I'm 10% happy or 90%...?
I'm interested by everything.
Are everythings interested by me?
Offline rf-loop
  • Starting with DLL21
« Reply #1807 on: June 20, 2013, 04:15:30 pm »
It was "interesting" time.
One sample from many kind of document images. (and there is lot of, and many different tests, not only just this)
And note: This is from APRIL 2011
This is history. This must not connect with today Hantek equipments.
But today it can show becouse all this terrible hassle have been over long time ago. Just "fun" history.
This happend when designer did not have enough experience and knowledge about what he was doing.
(I have always made "pre-ageing" and tests for every single scope I have sell.
What ever model or brand it is. Also other new equipments. All go to burn in tests before accepted for sell. failed units stop to my barrier and did not go to end users. This is one reason why I do not so much admire these re-shipper sellers who only receive parcels, get orders and send parcels to end users. But cheapest price win - of course, or is it so...
In this time average was around 50% failed after arrive from factory.
Here one fun sample image.
Signal is around 16MHz quite clean sinewave from medium grade generator HP8657B.
« Last Edit: June 20, 2013, 04:29:56 pm by rf-loop »
If practice and theory is not equal it tells that used application of theory  is wrong or the theory itself is wrong.
It is much easier to think an apple fall to the ground than to think that the earth and the apple will begin to move toward each other and collide.
Offline tinhead
« Reply #1808 on: June 20, 2013, 11:27:51 pm »
yeah, you was not the only person who was "happy" to got newest hardware.
10/90% check is simple, when your DSO is working and you don't have such massive distorted/modulated signal like on the pictures which rf-loop posted just above my respone then your DSO is in 10% group.
Offline Strada916
« Reply #1809 on: June 24, 2013, 01:07:09 pm »
Looking at buy this one
http://www.ebay.com.au/itm/Hantek-DSO5102P-Digital-Oscilloscope-100MHz-1Gs-2CH-7-TFT-Compared-TEK-TDS2012-/121080518250?pt=BI_Oscilloscopes&hash=item1c30f6166a
I have read through most of the 121 pages here and I am confused whether this scope can be hacked to 200MHz or not. As the 60MHz model is about $100 more expensive.
Sorry if it has been asked already.
Nick
The Bone, the Off-White, the Ivory or the Beige?
Offline tinhead
« Reply #1811 on: June 24, 2013, 01:17:36 pm »
Nick,
what a waste of time, you have to read only my very first posting on the very first page of this thread.
Just search on that first page for "P" model
But i can make it even easier for you, let summirize what i wrote there:
 - P model schematic - not done as i don't have P model to play with it
 - pictures/other information about P model - no, i need help from P model owners
 - backup tool - no, i need as well help from P model owners
 - hack - afaik yes (60->100 tested, no evidence in firmware that 200 would not work)
Offline sorin
  • Country: al
« Reply #1812 on: June 24, 2013, 01:20:26 pm »
Nick
https://www.eevblog.com/forum/testgear/hantek-tekway-dso-hack-get-200mhz-bw-for-free/msg239898/#msg239898
Offline Strada916
« Reply #1813 on: June 24, 2013, 02:44:48 pm »
thanks will keep reading. And researching
Offline carloscuev
  • Country: mx
    • Spanish Freescale Developers Forum
« Reply #1814 on: June 25, 2013, 02:22:14 am »
Just watched dave's review and as an owner of this scope I'd like to know if anyone has any clue about why is the analog frontend makes the captured signal "jump all over the place", could it be his hardware revision? How can I test without that fancy evaluation board he got?
Offline RobB
« Reply #1815 on: June 25, 2013, 10:33:14 am »
check out Alan's channel. He has a very simple squarewave generator with fast rise time. It should be able to stress the scope enough.
BTW I tested the holdoff-crash thing Dave showed on my scope. no sign of a crash. Indeed the scope has never crashed on me.
« Last Edit: June 25, 2013, 08:17:12 pm by RobB »
Offline Winston
    • IC Die Photography
« Reply #1816 on: June 25, 2013, 02:53:19 pm »
My tiny little brain has an overtemp migraine from reading this thread, so I'll be asking some questions that are probably already answered within this thread:
1. What is the out of box defective rate for Hantek DSO5102 scopes in 2013?  rf-loop's image of the response to the same 16MHz sine wave of four different copies of the same Hantek model  looks pretty scary.  It also makes me seriously wonder if the horrible pulse response Dave got in his review of the Tekway DST1102B may have been due to a defective scope front end and maybe just in one channel (assuming that the Tekway and Hantek use the same main board).
2. What is the difference, if any, between a Hantek DSO5102B and a DSO5102P?  No US suppliers I see on eBay carry the P model, those are only available directly from China, but I'd prefer buying from a supplier in the US in case there are issues with the scope right out of the box.
3. Does the Hantek DSO5102 use the same on-screen menu structure and font as the Tekway DST1102 shown in Dave's review?  The same hardware?
Online andersm
« Reply #1817 on: June 25, 2013, 04:01:52 pm »
B has 1M memory, P has only 24K. Other than that, the specs look identical.
Offline tinhead
« Reply #1818 on: June 25, 2013, 04:13:03 pm »
and "P" model have brand new mainboard (which contains different SoC and DDR memory), newer Linux (3.x).
Offline Winston
« Reply #1819 on: June 25, 2013, 06:29:04 pm »
Thanks for that info.  Found the web page for the "P" version and it looks like it's just an attempt to lower the cost of the scope which makes sense with the lower memory count.
« Last Edit: June 25, 2013, 06:42:12 pm by Winston »
Offline Winston
« Reply #1820 on: June 25, 2013, 06:33:59 pm »
Thanks, couldn't find any specs on the Hantek site, they just listed their "DSO5000C Series" with no real info on it in English.
Whoops, just found some info on a Hantek site, might have been on a satellite site of some kind before.
« Last Edit: June 25, 2013, 06:42:29 pm by Winston »
Offline tinhead
« Reply #1821 on: June 25, 2013, 06:42:28 pm »
Other than the smaller amount of memory, is that new mainboard better than the old mainboard or did they simply redesign it to lower production costs?
they redesigned the PCB because the main SoC is EOL. Now they using Samsung S3C2416 instead of S3C2440.
Was the Hantek DSO5102B with the older mainboard just the Tekway DST1102B hardware and firmware sold under a different brand name?
afaik Hantek nd Tekway belongs to same shareholders, they did a merger to optimize production costs. On the other side they selling still under own names (even if firmware is actually owned by Tekway and mainbaord produced by Hantek) and Tekway costs more (on the other side i know they running burn-out tests). What else behind, no idea, this is all they told me.
Offline Winston
« Reply #1822 on: June 25, 2013, 06:48:42 pm »
OK, thank you for that very helpful info.  It really clarifies things.
Offline Erwin Ried
  • Country: no
« Reply #1823 on: June 29, 2013, 06:53:48 am »
Hello!
Is this model compatible with the hack?
Hantek DSO5072P Digital Oscilloscope 70MHz 1Gs 2CH 7" TFT WVGA(800x480)
http://www.ebay.com/itm/121089632989
My website: http://ried.cl
Offline tinhead
« Reply #1824 on: June 29, 2013, 08:38:11 am »
Hello!
everything you need ti know is posted here
https://www.eevblog.com/forum/testgear/hantek-tekway-dso-hack-get-200mhz-bw-for-free/msg21170/#msg21170
