Looks like there is some menu to enter codes. And the funny part: when you enter a code, the firmware doesn't decode it, but tries to generate valid codes for all possible feature+period combinations (18 features * 4 periods), outputting each code via printf("license=%s\n", code) (to that console UART? or some other debug UART?). So it should be possible to enter some random code and get all those valid combinations from the output.
Wow! This is a lot of information that you got from this
actually I never tried to look at the UART port while entering a random key for option keys. However, there are two debug ports in
the unit, one that is clearly accessible from the battery door and it has even identified TX/RX/GND pins on the silk screen and has a pin header
and I got the boot console from it. There is another UART port a couple of blocks away on the CPU port hidden under the metal shield
and has no pin header but it has identifier TX/RX on the silk screen. I tried that one too but there was no activity on that port during boot and normal operation. However, I didn't think of looking at it (them) while entering a license key.
But why the unit should generate all license code combinations and output them on a UART port? so eventually how does it identify and accept the code? I could see that there is a routine that seems to be generating the correct code within the software but I never understood why.
by the way, the instrument determines what option(s) must be enabled with a given license code. I mean you just enter a license key and it will decode what option(s) will be cleared. You DO NOT choose the option name and then enter a code for it
