Author Topic: Leader LDC-822 freq counter reads accurately then goes erratic.  (Read 1819 times)
Offline cleanrfTopic starter
I have a Leader LDC-822 frequency counter that I bought on ebay. It works sometimes then suddenly reads 3 MHz or so higher than my the signal from my HP-8640B sig gen. When it does this it is also kind of erratic and bouncing around. Anyone have any suggestions?
Thanks in advance.
« Last Edit: February 28, 2021, 05:24:03 pm by cleanrf »
"Trying not to choke on that 10 ohm smoke!"
Offline bob91343
Re: Leader LDC-822 freq counter reads accurately then goes erratic.
« Reply #1 on: February 26, 2021, 03:32:47 am »
You may have an oscillation.  Does it read anything with no signal input?
« Reply #2 on: February 26, 2021, 06:23:53 am »
No, zero only zeros.
Offline bob91343
« Reply #3 on: February 26, 2021, 08:31:34 pm »
You probably should open it and do some signal tracing.  First check the power supply.
« Reply #4 on: February 26, 2021, 11:03:44 pm »
I wouldn’t know where to start. I can easily test the power supply though. Not sure how that would cause what’s happening.
Offline wizard69
« Reply #5 on: February 26, 2021, 11:11:36 pm »
Power supplies can cause all sort of strange behavior in digital electronics.  If I'm doing my job right, checking the power supplies is generally at the top of the list of any debug process.   Sometime it pays to check multiple times and at different points in the system.   I'd have to say that power supplies and often the caps in them, are the primary failure point in many systems.
« Reply #6 on: February 27, 2021, 03:45:23 am »
Makes sense. I assumed caps could be bad. I will test the power supply circuit.
« Reply #7 on: February 28, 2021, 02:35:33 am »
Power supply seems to check out. I was hoping this was a common problem.
Offline tautech
« Reply #8 on: February 28, 2021, 03:23:38 am »
3 milli hertz seem accurate enough.  :-//
Offline bob91343
« Reply #9 on: February 28, 2021, 06:15:56 am »
Yes the persistent casual and improper capitalization, among other abuses.
An engineer I respected once told me that any unit named after someone should be capitalized.  That would include Ohms, Hertz, Volts, etc.  I find it interesting that most people capitalize the H in Hertz even when there is a prefix, such as MHz.  But they seldom do it for Volts as in mV or Ohms as in MOhms.  It really can get you into trouble with Siemens; mS rather than ms (milliseconds).
« Reply #10 on: February 28, 2021, 06:15:50 pm »
I fixed the typo of mhz with MHz.
Offline bob91343
« Reply #11 on: March 01, 2021, 09:32:08 pm »
Okay cleanrf but don't take it personally.  Just venting over mistakes that are all too common.
« Reply #12 on: March 02, 2021, 06:13:48 pm »
No offense taken here, I am thick skinned and get it.
I just hope someone comes along that has had a fixed the issue I am having the frequency counter or maybe someone has a schematic. This little thing has a beautiful display and I hate to chunk it.
Online BrokenYugo
« Reply #13 on: March 02, 2021, 06:37:03 pm »
Leader will (or at least used to) email you schematics if you ask.
Online 4thDoctorWhoFan
« Reply #14 on: March 03, 2021, 01:47:40 pm »
I have the Leader 823 & initially had a similar issue.  It uses a not so common sort of BNC connector on the input where it did not have the typical circular center conductor.  The center conductor was sort of a wedge shape.  Anyway, I replaced that connector because it was very dirty & oxidized and plus I wanted to put on a typical BNC connector.  Mine has been working fine since the connector change.
« Reply #15 on: March 04, 2021, 04:48:39 pm »
I noticed the connector was odd. It also seems like it was more reliable the signal going into the freq counter was from a stronger signal source that my sig gen can produce.
Offline edavid
« Reply #16 on: March 04, 2021, 05:56:12 pm »
Here's the manual...
The following users thanked this post: cleanrf
