... even this cheap Harbor Freight meter is unlikely to be the primary cause of any serious injuries even if used in service panels or outdoor wiring because single-phase 240VAC just doesn't pose the same hazards that three-phase high-energy installations do. If it blows up because you left it in ohms mode while testing your circuit breakers or left the leads in the amp jacks, you'll just get minor burns and flying shrapnel at the worst--maybe bit of molten metal in the eye. I would be more concerned about the atrocious leads and semi-sheathed connections than anything else.
Exactly!
And with a ZT-225, not even that happens.
The sturdy structure alone with the fat, slightly elastic holster simply does not allow it to “blow to smithereens” (attachment).
It is immune to incorrect setting of the selector.
The only place where something could happen is the 20A input with ceramic fuse.
But the circuit breakers are at 16A in our house. What comes first?
Nevertheless, “cheap” DMMs are always eagerly discouraged here because they said to be “unsafe” and potentially deadly.
Deadly for whom? For Fluke? I don't think so.
And before you get into anything that requires electrician training, you should get electrician training.
Then you'll know what tools and safety measures you need. That might not include a Zotek meter, but protective goggles, protective gloves, a second person...
But for anything on this side of CAT II, I wonder what the point of these exaggerated warnings is?
After all, this is an "electronics engineering" forum and not a lineman forum.
