Author Topic: Has anyone tried UNI-T's new 17B Pro meter?  (Read 1216 times)
Offline Corner
« on: June 26, 2020, 07:01:04 am »
Saw this meter for sale and wonder if anyone has used it and have opinions on it?
From the product page on their Taobao website, here's a few things that they claim:
- The meter can withstand 8kv transient voltage
- 1 meter drop
- rotation switch is guaranteed to still smoothly operate after 30,000 cycles
Also from the PCB image, it has two big-as Bussmann fuses and various input protection components from other good brand meters. The board looks pretty clean too.
The thing I don't see though, is independent safety certification. I'm curious if all the claims are true.
The following users thanked this post: Marco1971
Re: Has anyone tried UNI-T's new 17B Pro meter?
« Reply #1 on: June 26, 2020, 07:17:42 am »
Ugh... close, but no cigar...
Look where the current shunt is, no way that's good enough clearance for 8kV.
Don't get me wrong I like my UT139C, but if I need to measure anything dangerous, I'll reach for my Fluke 87V every time.
Addiction count: AVO-BlackStar-Fluke-Hameg-HP-Keithley-IsoTech-Mastech-Micronta-Solartron-Tektronix-Thurlby-TTi-UniT
Offline Corner
« Reply #2 on: June 26, 2020, 07:25:33 am »
I used to have a 139C as well, but I gave it to my dad. This thing functionality wise looks like a direct upgrade to the 139C.
The price is $90 AUD, I'm so tempted to get it to play around lol. God help me.
Online MosherIV
« Reply #3 on: June 26, 2020, 07:45:48 am »
I think it is fake.
No mention of 17 series on the Uni-trend web site.
Offline Corner
« Reply #4 on: June 26, 2020, 08:16:19 am »
Offline Fungus
« Reply #5 on: June 26, 2020, 08:52:15 am »
I think the cutouts and spaceings are on the other end of the fuse, where the input is.  :popcorn:
Offline Fungus
« Reply #6 on: June 26, 2020, 08:54:50 am »
If your life depends on it being true then don't trust it. Get something with a genuine certification.  :-//
Offline Fungus
« Reply #7 on: June 26, 2020, 08:56:32 am »
I think it is fake.
Are you sure? https://www.uni-trend.com.cn/index.php?m=content&c=index&a=show&catid=438&id=786
Really? A 15B and a 17B? I wonder which brand they're trying to grab karma from?
« Last Edit: June 26, 2020, 09:03:26 am by Fungus »
« Reply #8 on: June 26, 2020, 09:58:21 am »
So you only get separation if the current is high enough to blow the fuse.
Great design!   :-+
/sarcasm
Online 2N3055
  • Country: hr
« Reply #9 on: June 26, 2020, 10:32:12 am »
Great design!   :-+
/sarcasm
LOL. Step back......
What is the voltage over shunt and fuse when fuse is not blown?
8kV? Or 100-300mV ?
8 kV limit applies to voltage mode only.
Current mode has spec of how much kV it can withstand for 1 min when fuse is blown, and that is usually 1 kV (or max voltage in voltage mode)...
Critical spec for current mode is max breaking current and fact whether it will, in fact, extinguish the plasma and break current as opposed to having a breakdown and having arc discharge accident.
Specifications are quite complicated and there are many caveats when reading what is what..
The following users thanked this post: Wytnucls
Offline Fungus
« Reply #10 on: June 26, 2020, 10:34:22 am »
Great design!   :-+
/sarcasm
Ohms law says that if the voltage is high enough to jump the gap, the current will be high enough to blow the fuse.
Plus: Voltages usually only jump around when there's a high impedance in their way, which a fuse isn't.
« Last Edit: June 26, 2020, 10:45:21 am by Fungus »
Offline Corner
« Reply #11 on: June 26, 2020, 10:40:23 am »
I think it is fake.
Reading about them on some Chinese forums, looks like they made these to directly go against Fluke 15B and 17B. Hahah! These two meters have just been released in China. It's probably going to take a little while for them to come overseas.
« Reply #12 on: June 26, 2020, 10:53:50 am »
Great design!   :-+
/sarcasm
That would imply that a piezo ignitor could supply enough current to blow a 10A fuse.
I suspect that would not be the case.
Online 2N3055
  • Country: hr
« Reply #13 on: June 26, 2020, 10:59:23 am »
Great design!   :-+
/sarcasm
No, that would imply that piezo igniter connected to current input will achieve 300mV peak voltage....Because it doesn't have energy to create enough current...
« Reply #14 on: June 26, 2020, 11:18:40 am »
So as long as the leads are inserted in the correct sockets, you're fine.
What am I missing here?
Offline EEVblog
« Reply #15 on: June 26, 2020, 11:28:42 am »
Some Uni-T meters have proper UL certification, but a lot (most?) don't. Seems pot luck.
But if they are competing against the Fluke then UL certification would be an absolute requirement, otherwise they are dead out of the blocks.
Offline EEVblog
Offline Fungus
« Reply #17 on: June 26, 2020, 12:40:11 pm »
They're not the only ones, Zoyi also does a 15B+ and 17B+
eg. https://www.aliexpress.com/item/33007708093.html
Some sellers put "17B+" in all their items just to trap people, eg. https://www.aliexpress.com/item/32844347527.html
« Last Edit: June 26, 2020, 12:46:22 pm by Fungus »
Offline Fungus
« Last Edit: June 26, 2020, 12:50:33 pm by Fungus »
Offline Corner
« Reply #19 on: June 26, 2020, 01:28:03 pm »
These meters are aiming at tricking people though, they are crappy cheapies that wanna use these labels to trick people. Those new Uni-T meters seem to be of a lot higher quality.
Offline Fungus
« Reply #20 on: June 26, 2020, 02:09:22 pm »
You'd hope so for $95.
"rotation switch is guaranteed to still smoothly operate after 30,000 cycles"
LOL! Somebody's been reading EEVBLOG.
(A real Fluke will laugh at that though)
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #21 on: June 26, 2020, 02:44:19 pm »
The meter seems quite decently built and the air gap around the shunt looks alright - at a typical 3kV/mm for dry air, it doesn't really looks there is a problem. Obviously I don't have one and can't be absolutely certain.
The lack of independent verification (which UT139 has) is surely a turnoff, but it doesn't tell the whole story. Reputable brands such as Yokogawa, Sanwa and Hioki do in-house certification but they have a good reputation and track record of pushing out decent gear (a bit less on Yokogawa, but still). Uni-T has goofed up so many times in the past that they have a very long road ahead to boast any quality claims for in-house testing. There's also that pesky loophole the cert agency will only test whatever you ask them to, and that could easily be circumvented (among other potential loopholes)
That or joeqsmith's videos.  :-+
Offline Corner
« Reply #22 on: June 27, 2020, 12:07:25 am »
Well at least it's similarly priced as the 15B and 17B. I've actually ordered it just to check it out. If I end up wasting 90 bucks, so be it :)
Online rsjsouza
  • Eternally curious
« Reply #23 on: June 27, 2020, 12:19:42 am »
I don't know about the 15B or 17B, but the quality of the 101 for me was very flaky. The first (2017 date code) had issues with the display. The second (2016 date code) did not, but both had oxidized pads on the PCB vias and pads, including the ones leading to the LCD.
This may be due to improper storage, but it was coming from two different sellers from very different locations.
Offline Corner
« Reply #24 on: June 27, 2020, 12:23:58 am »
My 101 was acquired a couple of years ago. It's been sitting in my potable toolbox and gotten pushed around in a sea of pliers, screwdrivers and other crap. Other than scratched screen, it's given me no trouble. I haven't opened up the little thing though.
