Author Topic: Handheld meter robustness testing  (Read 1758444 times)
0 Members and 106 Guests are viewing this topic.
Offline joeqsmithTopic starter
Re: Handheld meter electrical robustness testing.
« Reply #850 on: April 13, 2016, 09:54:34 pm »
What happens when your meter is used to measure the output of a microwave oven transformer?
https://www.youtube.com/watch?v=eY5Rh2gokgg&feature=youtu.be
And you thought my tests were harsh!   :-DD
Offline RobertoLG
  • Country: br
« Reply #851 on: April 13, 2016, 10:56:57 pm »
ahh, it doesn't show the test, just the damaged meter...
« Reply #852 on: April 13, 2016, 11:22:56 pm »
Yea, I know!  We were shorted!  I was reading the description.    If it were me, I would have left the cover off, pointed the camera at it, then connect the thing back up.    :-DD :-DD
I need a microwave transformer...
This happened to my multimetr after I have tried to measure voltage on secondary winding of a samsung microwave owen after replacement of a burned glas fuse. I do not know what I was fhought about that moment, but as I red later the voltage level on it is about 3 kV. Thanks god I still have both of my hands. As autopsy shown, it is only 1 ptc and couple of resistors inside, and this is all input overvoltage protection of this multimeter. I wrote an email to manufacturer but they use "ostrich policy" in their job. So, I writing about this for those people, who is going to buy this fake rated device. Do not do it, even for low voltage works, because some day, somehow, you may forget about CAT ratings, and stick it to mains, or worse house incoming power supply 380 V, but nobody will tell you that will happen after that!
Offline RobertoLG
  • Country: br
« Reply #853 on: April 13, 2016, 11:28:51 pm »
heh, I have one here lol, from an old 1600 watts microwave, the capacitor is rated for 2400 VAC , the magnetron too and no I won't kill my meter with it   :-DD
« Last Edit: April 13, 2016, 11:56:47 pm by RobertoLG »
« Reply #854 on: April 14, 2016, 12:47:30 am »
Looks like a good sized transformer.   I wonder if any handheld meter would survive a 1 minute hookup.
Offline RobertoLG
  • Country: br
« Reply #855 on: April 14, 2016, 02:19:09 am »
ya, it's about 6 kilos, the microwave was almost as big as an old CRT TV, with no spinning plate.  the only way to find out is to do the test lol, and that guy from the video learned a lesson he'll never forget at least.
« Reply #856 on: April 15, 2016, 06:32:20 pm »
I have a microwave sitting around........ Should i connect a cheapie meter I do not like to it on DC volts and see where the smoke comes out?
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #857 on: April 15, 2016, 08:23:46 pm »
Or take its guts, create a cheapie microwave gun and aim at the unloved DMM.
Something similar as to what these bozos did a while ago...
http://gizmodo.com/this-kid-took-apart-a-microwave-to-create-an-insane-an-1612804394
« Last Edit: April 17, 2016, 11:39:19 am by rsjsouza »
« Reply #858 on: April 16, 2016, 03:33:33 am »
Looks like TME is selling the UT71D for $170 US.  Not the cheapest handheld to kill this way.
Offline gameru
« Reply #859 on: April 16, 2016, 04:03:01 pm »
Only a couple things are cheap on TME.It's a good shop,but with high prices
« Reply #860 on: May 01, 2016, 05:28:36 am »
A viewer had asked about making lower current measurements in the 4 to 20mA range using the Fluke 17B+.
https://www.youtube.com/watch?v=89HDlSq8WEg&feature=youtu.be
Offline Fungus
« Reply #861 on: May 01, 2016, 05:51:17 am »
Nice use of the current shunt on the Fluke 101.  :popcorn:
« Reply #862 on: May 01, 2016, 03:33:50 pm »
With the 4-20, I would think the risk would be fairly low but you never know.
Offline Fungus
« Reply #863 on: May 01, 2016, 06:34:44 pm »
What's the risk? A burnt out resistor?
Offline Fungus
« Reply #864 on: May 01, 2016, 07:39:07 pm »
I'm sure you can find a suitable high power shunt if you know the current range:
eg. http://www.ebay.com/itm/320757994835
« Reply #865 on: May 01, 2016, 08:58:14 pm »
Working in an industrial environment and hooking up to anything with an unprotected device would have a risk.   Assuming your working in the range of 24V or less would seem like a risk.  With what I show, there is no blast shield, no fuse, the wires hang right out there for you to touch and the banana connectors are not what should be used.  A clamp would be much safer choice and because you are not going in-line would make things go quicker.
Again, I think the risk would be fairly low but buying a meter that has all the protection built-in seems like a small price to pay if this is your job.
Offline blacksheeplogic
« Reply #866 on: May 02, 2016, 01:48:20 am »
If you are measuring inline (not using a clamp) a DMM with a ma range is probably a good option if you have any concerns first. A number of process meters won't appreciate any excessive voltages on the terminals. Both of mine are rated for 30V/24ma MAX on the terminals with the meter being essentially a very expensive fuse in the case of an overload.
« Reply #867 on: May 05, 2016, 01:23:54 am »
I'm sure a few of you are wanting to see some meter carnage!    After all, watching a UNI-T survive 15KV gets pretty boring.
I finally broke out the pocket meters and did a quick check on them.  Suddenly the Harbor Freight free meter does not seem so bad.   These are all CAT II 300V rated but my plan is to not change anything in the test setup.   They are small and while I have not had them apart yet, I have to believe these things are going to make a mess.
Maybe over the weekend I can get something together.   So stay tuned...
« Reply #868 on: May 06, 2016, 11:42:47 am »
Having a look at the new pocket meters.
« Reply #869 on: May 07, 2016, 04:58:16 pm »
Much to my surprise, one of the pocket meters has actually been holding up rather well.   Imagine if you made some "high end" meter and it could not handle what a sub $20 CAT II pocket meter could handle.  Should have everything wrapped up today.
« Reply #870 on: May 07, 2016, 07:48:39 pm »
The last meter just won't die. I have the Dremel, X-acto and dope out.   Time for a break while things dry....
« Reply #871 on: May 07, 2016, 08:38:37 pm »
Sub $20 meter....... :wtf:  :o
Looking forward to this vid....... :popcorn:
« Reply #872 on: May 08, 2016, 01:45:43 pm »
It finally died.  However there's not working dead, then there is 600 Joules of dead.    :-DD     Looks like one more day of testing.
« Reply #873 on: May 08, 2016, 06:53:43 pm »
It's in the computers hands now.  I just packed it into one 40 minute video that I will upload later today along with a new spreadsheet.
On the plus side, I doubled down and used both the modified UT181A and the Brymen as a side-by-side reference.  Having used the 181A for a few weeks now, I hope that UNI-T releases a B model that addresses some of my concerns because I rather like the meter in some sick, demented way...
Looking down the road, there are only a few meters that I would like to add to the list.  One would be a Gossen, the other Dave's fat boy custom meter.
« Reply #874 on: May 08, 2016, 07:34:39 pm »
You think Dave's meter has a chance of surviving at least half way through? Should at least meet the CAT ratings though.
