Hello! Thank you for giving us the opportunity to talk to you about these great products, it's really valuable!
I have a DPOX180H on its way to me.
I have a few questions, please answer them if possible.
1) Here in this video review:
https://youtu.be/9i_4Eu887gU?si=kZSLi12ISzpr8gXf&t=295(it's in Russian, but the subtitles seem to translate well)
They say there's a problem with compensation with an open and closed channel up to 10 MHz. Many people in the comments say that the problem does exist, and they also write that it can be solved by soldering a 100 pF capacitor. Is this a problem you know about?
2) Is it planned to add a scale for measurement to the FFT spectrum function? (a cursor would be an ideal solution)
3) At a low sweep speed, the oscilloscope behaves like an analog one, i.e. the graph is drawn from left to right, then the graph is erased and starts to appear again. This is close to what would be on analog oscilloscopes. But this is not convenient when you need to catch an unpredictable transient process that is not caught by a trigger. It would be cool if you added a mode in which the signal curve is continuously generated on the right side, and its history shifts to the left. Is there a chance that you will add such a mode?
4) I really miss the infinite afterglow as it is on younger models like 2C53P, it was really super convenient for catching single very fast events.
Is there a chance that you will add this? (I understand that you did not work on 2C53P, but I assume that you are aware of its functionality)
