Products => Test Equipment => Topic started by: Nhan95 on May 11, 2015, 01:22:10 am
When I use analog oscilloscope in the experiment, sometimes I work with sine wave or square wave, my teacher asked me to choose DC mode for channel 0 and channel 1 or I will face with wrong result. Uhm, I feel confused :( . Could you help me when we use DC or AC mode?
If the sine wave or square wave has a DC bias either pos. or Neg, then you need to be DC coupled or you won't be able to see the offset. AC coupling will remove any DC biasing of a waveform.
Another way understanding it is to see what the switch actually does. When I was younger, I could only afford old tube based 5MHz bandwidth oscilloscopes, which were pretty horrible but how they worked was obvious just by looking. The AC coupling switch simply put a 0.1uF capacitor in series with your probe lead. That way all DC was blocked to the vertical amplifier.
Before asking for any help with basic use of an oscilloscope, everyone should watch the video in this thread.
https://www.eevblog.com/forum/beginners/oscilloscope-training-class-(long)/ (https://www.eevblog.com/forum/beginners/oscilloscope-training-class-(long)/)
Or you could download this document from Tektronix :)
http://info.tek.com/www-xyzs-of-oscilloscopes-primer.html (http://info.tek.com/www-xyzs-of-oscilloscopes-primer.html)
...my teacher asked me to choose DC mode for channel 0 and channel 1 or I will face with wrong result.
I'm thinking - is the teacher teaching you these things? Did you ask the teacher? Just thinking out loud on this end. ???
