Well, it looks like I will soon have a 754A. I borrowed to get this scope, I hope it serves me well! I inquired about the electrolytic caps being changed and he said the acquisition caps on the newer scopes like 754 are changed to tantalum and ceramic, and the only electrolytics are on the cpu board. Here was his direct response:
"Neither the TDS754A nor the TDS540C have electrolytic caps on the acquistion board, they are all ceramic and tantalum. There are a few electrolytics on the CPU board, but I do not bother changing them because I have never seen them cause a problem on these newer scopes. And the risk of causing other damage to traces, etc. is greater than any benefit of changing them. The problem electrolytics were predominatly found on the TDS544A, TDS644A, and the old TDS540 (no suffix) scopes. Tek fixed the cap problem on the newer models of scopes like the 754A and 540C."
Is this not correct?
