Author Topic: Help needed on Rohde Schwarz UPL with HDD issue  (Read 6533 times)
Offline acbernTopic starter
« on: August 19, 2014, 08:28:10 am »
I recently got a non-working UPL audio spectrum analyzer. It is starting up, but would not detect the HDD. I did check the correct boot sequence and auto detect setting as indicated by R&S in a service note, it is correct. So I booted the unit through the Floppy (using a  DOS boot disk) and did a HDD disk scan. It passes without errors, but the disk is totally empty, must have been erased.
Does anybody have a file to load onto the HDD, or a set of disks, or know where to buy it. Have asked R&S, they were doubtfull due to old gear, still open. Any help is appreciated.
Offline barnacle2k
Re: Help needed on Rohde Schwarz UPL with HDD issue
« Reply #1 on: August 19, 2014, 08:09:31 pm »
You have to find someone with an UPL and get him to clone the HDD content for you.
But maybe only the partition table / filesystem were destroyed.
Try removing the HDD and connect it to a "normal" computer.
Then you could apply Testdisk to try and recover it.
« Last Edit: August 19, 2014, 08:58:56 pm by barnacle2k »
« Reply #2 on: August 19, 2014, 08:27:11 pm »
thanks for the hint re. testdisk, i will check that.
Unfortunatelly I do know anybody who has that unit to clone a hdd. Maybe someone ho reads this here in germany has a unit and still has its old hdd and is getting nervous, I would, besides paying a fee, also clone this to a solid state disk.
« Reply #3 on: August 23, 2014, 04:39:04 pm »
I did check the hdd with the tool, thanks again for the hint. it scans ok, I can load data onto the disk once I have booted into win98 from floppy. so hdd seems ok overall.
The user manual states that as part of the deliverables a set of floppy disks comes with the unit, one with the OS, the other with the program files (both zipped).
So if anyone has that and could make a copy of both disks that would be a simple solution.
Offline German_EE
« Reply #4 on: August 23, 2014, 06:31:53 pm »
Please post the model number, I will see what I can find.
Warren Buffett
« Reply #5 on: August 24, 2014, 01:53:36 am »
The number of the UPl indicated on the rear is 1708.2008.06.
Thanks
Offline German_EE
« Reply #6 on: August 24, 2014, 08:14:22 am »
This is most odd. I have been to three R&S websites and under UPL Firmware the only file is 'R&SĀ®UPP UPx Sequencing Software Operating Manual V 1.0   26.06.2013' The same file appears under the UPP section.
Investigations continue.
Warren Buffett
« Reply #7 on: August 24, 2014, 09:09:14 am »
there is no firmware available on the RS website, unfortunatelly, I have already checked.
Offline German_EE
« Reply #8 on: August 24, 2014, 12:34:21 pm »
On your behalf I have emailed a friend of mine who used to be a field service engineer for R&S, let us see if he can come up with the software.
Warren Buffett
« Reply #9 on: August 24, 2014, 01:05:03 pm »
Great, much appreciated!!
Offline German_EE
« Reply #10 on: August 25, 2014, 06:16:35 am »
Please send me a PM with your email address, I have your software  :-+
Warren Buffett
Offline analizator
  • Country: hr
« Reply #11 on: September 14, 2016, 08:48:35 pm »
I have UPL anylzer by myself too.....since i cannot find software anywhere, if someone still has it would like to have it too......
thanks!
Offline Ivan_Vetrov
  • Country: ru
« Reply #12 on: December 16, 2016, 09:19:50 am »
Please help with the software for this device. My mail motor242@list.ru
Offline German_EE
« Reply #13 on: December 20, 2016, 07:07:27 pm »
To all thread members
My source is no longer able to supply software or service information for R&S equipment as he has been forced to return all material back to the company.
German_EE
Warren Buffett
