Author Topic: Warranty on a used Rigol DS1102E  (Read 1289 times)
Offline RadicalAnsTopic starter
« on: January 29, 2017, 07:33:20 pm »
Picked up a used Rigol DS1102E of ebay for a steal. I want to replace the fan w/ a quieter one and maybe put a heatsink on the voltage regulator under the fan. My question is, should I bother attempting to keep the warranty sticker in place or just go for it. Since I bought it used I don't have the original receipt or anything.
Thoughts?
Edit: Also, if any of you folks have suggestions for heatsink and/or fans to use on this scope, I'm open to suggestions.
« Last Edit: January 29, 2017, 07:37:52 pm by RadicalAns »
Offline Fungus
Re: Warranty on a used Rigol DS1102E
« Reply #1 on: January 29, 2017, 07:43:46 pm »
Wait a couple of weeks until you're sure it's working then just go for it.
Offline jjoonathan
« Reply #2 on: January 29, 2017, 07:50:22 pm »
IIRC Rigol has a warranty period of 3 years and the DS1102E is a pretty old model, so I doubt that the warranty sticker will get you a warranty and I doubt that you'll need one. Don't just cut it though! At least use it as an opportunity to practice the heat gun + wax paper + patience maneuver. Then sell the sticker on ebay  ;D
« Last Edit: January 29, 2017, 07:52:13 pm by jjoonathan »
Offline Fungus
« Reply #3 on: January 29, 2017, 08:10:37 pm »
 :-DD  :-+
