Author Topic: Help Required - Who Is The OEM Of This Multimeter ?  (Read 5669 times)
Offline Amarbir[Lynx-India]
  • Country: in
  • Indian Dealer
    • Lynx-India - Visit Us For Not So Boring Electronic Instruments
« on: July 22, 2013, 08:34:28 pm »
Hello All,
        I Have 4 Models In Metravi Multimeters ,The 901-I , 901-II , 901-III And 901-IV .I Am Adding All The 4 Photos For You .Can Someone Help Me Identify The OEM .I Opened The 901-I Multimeter And It Had DT-9911B Written On PCB .But i Got No Info Of Internet  |O
The 901-I Photo
The 901-II Photo
The 901-III Photo
The 901-IV Photo
PS : I Can Upload Larger Photos Of The Same Also If You Like
Some Images :
« Last Edit: July 22, 2013, 08:36:25 pm by Amarbir[Lynx-India] »
Regards
Amarbir Singh Dhillon [ Lynx-India ] , Chandigarh [ India ] - > www.lynxdealerstore.com , www.lynx-india.com
Indian Distributor For  [ Autoelectric , Sofitech , IDEOfy ,Peak Electronic Design [UK ] , Anatek And Creatronica ]
My Electronics Blog - > www.lynxchandigarh.com
Offline Stonent
Re: Help Required - Who Is The OEM Of This Multimeter ?
« Reply #1 on: July 22, 2013, 09:04:15 pm »
Some Mastech meters use DT in their model.
Also a lot of the really cheap $1 meters are DT-830b
Offline Wytnucls
« Reply #2 on: July 22, 2013, 09:10:13 pm »
  • Country: in
  • Indian Dealer
« Reply #3 on: July 22, 2013, 09:26:37 pm »
The OEM is CEM in China.
http://www.cem-instruments.com/en/pro/sort7-1.html
 Well,
     Just Before I Posted I Checked thier Website .I Could Not Find DT-9911B There For Sure .Either Its a Obsolete EOL Model Delisted From There Or The OEM Is Different .
Regards
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #4 on: July 23, 2013, 03:39:18 am »
 Well,
Or it could be a true OEM. Uni-T makes some variants for companies which have no equivalent in the Uni-T lineup. It's possible the DT-9911B is an internal CEM part number for this device
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline Uwe Hermann
    • Personal website/blog
« Reply #5 on: July 23, 2013, 09:47:10 am »
Can you post a few photos of the PCB?
Oh, almost forgot: Digitek models also start with "DT" usually, though in this case it's more likely to be a CEM indeed.
http://www.digitek.com.hk
« Last Edit: July 23, 2013, 09:51:58 am by Uwe Hermann »
sigrok developer (open-source, portable software for logic analyzers, oscilloscopes, DMMs, and other test & measurement gear)
Offline amyk
« Reply #6 on: July 23, 2013, 11:27:40 am »
DT is just their abbreviation of "digital tester".
  • Country: in
  • Indian Dealer
« Reply #7 on: July 23, 2013, 02:18:56 pm »
Sir ,
     I Have Taken The Photos ,I Will Post Them All For The 901-I Metravi .
Regards
Offline Wytnucls
« Reply #8 on: July 23, 2013, 05:57:48 pm »
The 901 II appears to be the same as the Velleman DVM9912, also made by CEM.
« Last Edit: July 23, 2013, 06:05:01 pm by Wytnucls »
Offline PedroDaGr8
« Reply #9 on: July 23, 2013, 10:45:00 pm »
That one looks a lot like a Uni-T too.
Offline Uwe Hermann
« Reply #10 on: July 24, 2013, 09:06:03 am »
That's quite surely not a UNI-T (not all red DMMs are made by UNI-T), the PCB clearly says DT-9912A-3 which matches the CEM DT-9912. It's sold under a ton of different names by different rebranders, but various photos also exist where it's clearly labelled as "CEM DT-9912" on the housing, e.g.
http://www.industrial-needs.com/technical-gallery/displayimage.php?album=171&pid=2024#top_display_media
http://www.warensortiment.de/bedienung/bedienungsanleitung-digital-multimeter-dt-9912.pdf
http://edura-instruments.de/product_info.php?language=en&info=p172_Digitalmultimeter-DT-9912.html
Uwe.
Offline metalphreak
  • http://d.av.id.au
    • D.av.id.AU
« Reply #11 on: July 24, 2013, 03:12:14 pm »
CEM have a particular style that's used on all of their meters - that rotary switch and the font etc. They are the OEM for heaps of different brands (including some Extech models). Quality is pretty decent most of the time. Not fluke quality but not cheap garbage either.
  • Country: in
  • Indian Dealer
« Reply #12 on: July 24, 2013, 03:57:27 pm »
Well,
       I Recon That Boss .Sorry i Have Not Uploaded Images But i Would Be Doing Those Today.If We Classify Multimeters Into Three Categories " Junk , Mid Quality And High Quality " .I Would Say It Mid Quality  .
Regards
