Author Topic: Help: Rigol DS1054Z PNG Screenshot corruption  (Read 705 times)
Offline cheeseburgerTopic starter
« on: July 07, 2023, 09:04:30 am »
Hello
I have a Rigol DS1104Z. Since the update to the latest firmware (v00.04.05.02.00) the screenshot to USB feature doesn't work properly anymore.
The last screenshot on the USB disk is always corrupted. But just the last one. This also happens when taking the snapshot and shutting the device after a few minutes. It looks like it doesn't write the file to a full finish.
Is this a firmware bug?
Offline RoGeorge
Re: Help: Rigol DS1054Z PNG Screenshot corruption
« Reply #1 on: July 07, 2023, 10:22:31 am »
Upgrade to a newer firmware, IIRC v00.04.05.02.00 not the latest firmware.  From here, there are at least 2-3 newer ones.  https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg4865735/#msg4865735
If not, you can downgrade to the last known working firmware you had before (for how to downgrade Rigol firmware, see the last paragraph written as code, the Rigol signed disk is attached there: https://www.eevblog.com/forum/testgear/new-rigol-ds1054z-oscilloscope/msg3613778/#msg3613778 )
Another thing you may want to consider is to use LAN or USB to download the scope printscreen directly into a PC, without an USB pendrive.  That's way faster and easier.  Use something like DSremote, or any other program that can control the oscilloscope remotely (there are many ways to download from scope to PC directly).
« Last Edit: July 07, 2023, 10:26:58 am by RoGeorge »
The following users thanked this post: cheeseburger
« Reply #2 on: July 09, 2023, 08:50:44 pm »
Updated to 00.04.05.02.04, issue still present.
Looks like I will now use DSremote which is pretty awesome over LAN.
Offline ledtester
« Reply #3 on: July 09, 2023, 09:13:20 pm »
I haven't had this problem, but a simple work-around would be to take one more screenshot than you need (i.e. a throwaway one)
I would also try it using a different USB drive - just to rule out a defective USB drive.
Offline ElectronMan
« Reply #4 on: July 10, 2023, 03:23:38 pm »
From your description it sounds like you may be pulling the USB drive before the OS of the scope has flushed its cache to the USB drive.
Rigol might need to add a sync after saving files. Ledtester's suggestion above is a good one, but also make sure you aren't pulling it out as soon as it says it is done saving the screenshot.
