Hi All,
Some of you may know that I built the SDM3065X, SDM3055, SDM3045X calibration file generator site:
https://www.thedefpom.com/siglent_sdm_calibration.phpI haven't had a lot of feedback about it so I don't actually know if all of the files are working correctly.
I am hoping that people out there with the SDM3065X, SDM3055 or SDM3045X that have tried using the site will post the results of trying to use the files here, both good and bad, so I can try to track any problems with the files it is generating.
I want to compile a table showing all of the confirmed working files, and also the ones that are not working, if you have a problem with one not working I may ask you to do further testing when I attempt to modify the file formats.
Unfortunately there are no real examples for all of the files from Siglent and so some are based on guesswork and may not be working, this is why I want to nail this down and be sure that there is a known status for each file and calibration type.
One interesting point is that all the example cal files are 2,400,000 (or 240,000) count based, but the SDM3045X is a 66,000 count meter, so I am really unsure if the files work for it at all.
| Model | Mode | Result |
| SDM3065X | DCV | Works |
| SDM3065X | DCV Auto Zero | Works |
| SDM3065X | ACV | - |
| SDM3065X | ACV 3Hz Filter | - |
| SDM3065X | DCI | Works |
| SDM3065X | DCI Auto Zero | Works |
| SDM3065X | ACI | - |
| SDM3065X | ACI 3Hz Filter | - |
| SDM3065X | 2 Wire R | - |
| SDM3065X | 2 Wire R Auto Zero | - |
| SDM3065X | 4 Wire R | - |
| SDM3065X | 4 Wire R Auto Zero | - |
| SDM3065X | Capacitance | - |
| SDM3055 | DCV | - |
| SDM3055 | ACV | - |
| SDM3055 | DCI | - |
| SDM3055 | ACI | - |
| SDM3055 | 2 Wire R | - |
| SDM3055 | 4 Wire R | - |
| SDM3055 | Capacitance | - |
| SDM3045X | DCV | Works |
| SDM3045X | ACV | - |
| SDM3045X | DCI | - |
| SDM3045X | ACI | - |
| SDM3045X | 2 Wire R | Errror in recalibrated mode or range |
| SDM3045X | 4 Wire R | Errror in recalibrated mode or range |
| SDM3045X | Capacitance | - |
